Old Nov 30, 2014, 08:32 PM
Jezzejamez's Avatar
United States, MI, Commerce Charter Township
Joined Oct 2013
Originally Posted by hubcapsteve View Post
Putting lipstick on a pig still makes it a pig comparatively speaking......especially after flying the formula HV
Can't beat that, in a few weeks I will be in the air. Then the bragging starts.
Not flying the HV but should be phenomenal
Jezzejamez is online now Find More Posts by Jezzejamez
Old Dec 12, 2014, 06:32 PM
United States, NC, Asheville
Joined Nov 2010
Hi This is my X-Plane power : Nue 1115/1y kontronic 4.2-1 gearbox and a GM 9 x 21.5 folding carbon prop. I mounted the Gearbox according to the instructions provided and a post I found here. When I test ran it sounds fine not much noise but the gearbox seems to get fairly warm.
Does anyone know if this is normal ? Do I need to run it on the bench some to break it in ?
I guess I need to get a temp gun and see what the real numbers are. Im using some Lithium Gearbox Grease (Hacker) suppose to be good stuff.
RandyQman is offline Find More Posts by RandyQman
Old Dec 12, 2014, 08:07 PM
Edhs's Avatar
the seventh planet
Joined Dec 2010
I ran an almost identical overall setup (1115-1.5d-5.2 on 10x23) and never measured or noticed any heating of the gearbox alone. I never ran it outside of a fuse either though so don't have temperatures. I posted a video if you wanted to see what your in for.
Do a very good job on the linkages as your going to be knocking on the 200mph door on 5s
Edhs is offline Find More Posts by Edhs
Old Dec 12, 2014, 09:07 PM
Joined Nov 2010
I think I found your Video Edhs looked like you had it flying great . Looked like everything should stay cool up in the great white north. I hope to be in the 200mph range . Planning on testing it out with a 4s before I go to the 5s . My Sunracer runs over 170 and I have had no flutter with it using 450 heli linkage so I was planning on going that route.
Old Dec 12, 2014, 10:33 PM
Joined Apr 2005
I ran NEU Motor 1110-1.5Y-5.2:1 on my Swist on 5S and GM10x23 ... very reliable, no maintenance, every day 200mph flyer. I used ball links with good results. Hope yours performs well! JS
jsnipes is offline Find More Posts by jsnipes
Old Dec 12, 2014, 11:25 PM
Joined Nov 2010
Thanks Snipes always good to know your on the right path . Your prop is a little steeper but I don't have quite as much gear reduction so we should be close to the same. The prop calculator was show a pitch speed of 182 on a 4s and 220 I think it was on a 5s.
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13062 Sep 19, 2014 11:12 AM
Discussion MCP-X thread for people that dont have a MCP-x axelen Micro Helis 186 Apr 01, 2011 02:17 AM
Data mCP X (non chat) setup and tips owners thread Cable Guy Micro Helis 9 Mar 12, 2011 12:50 PM
Build Log Build Log - ARK X-500 series build thread cfrank2005 Electric Heli Talk 30 Jun 29, 2009 01:27 PM
RBC A-4 Skyhawk build thread X.X Willmsy Electric Ducted Fan Jet Talk 6 Nov 22, 2005 11:01 PM
