Old Jan 05, 2015, 07:46 AM
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Hi,
i'm so sorry ..... wrong thread - i thought this is the vector thread
cu Thomas
Originally Posted by Fast Guy View Post
Don't remember seeing this option on the OSD Pro. Just distance to pilot. Would be nice.
Thint1 is offline Find More Posts by Thint1
Old Feb 02, 2015, 05:24 AM
Joined Feb 2015
OSD Pro and TX to Seagull
Hallo,
I need help how to obtain conection between my model any my PC during flight.
What I have: I have FDR Seagull, OSD pro.
What I want: I have connected OSD pro and FDR (instead of eLogger) and I need to recieve data in my computer I have conected via Seagull Wireless.
Seagull Wireless needs Tx conected elswhere in model.
In manual of FDR is written, that TX must be pluged in FFC TX socket.
If I use OSD Pro, it is connected in FFC TX socked on FDR.
In manual of OSD Pro is written, that I can connect Tx to the daisy chain male port of the OSD pro.
I am not sure, where it is. Only one four-pin port is described as "microsensor/ powerpowerpanel" so my question is follows:
Where i Should connect my seagull Tx to obtain measuder data from FDR when OSD pro is present?
Thank you for quick answer.
Best regards
Uteri
Uteri is offline Find More Posts by Uteri
Old Feb 16, 2015, 08:14 AM
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
Selling an unused OSD Pro for $65 and a elogger for $45 in FPV classifieds
Thanks!
eroeder is offline Find More Posts by eroeder
Old Feb 20, 2015, 12:01 AM
Joined Dec 2014
Too bad it wont fly the way points on its own...i mean why can't it?
livethrive is offline Find More Posts by livethrive
Old Feb 25, 2015, 03:34 PM
teb1963's Avatar
Canada, SK, Regina
Joined Oct 2011
OSD and guardian
Hi everyone
I am hooking up an Eagletree with guardian on a Twintar, as it is, I have two channels for ailerons on my Taranis to dragon link. When I configure the RTH one of the options is self level, is there any way to use the self level feature,when I use rudder instead of ailerons (like I said above using two channel so that I can use flaperons)
Thanks in advance.
Terry
teb1963 is offline Find More Posts by teb1963
Old Feb 25, 2015, 08:58 PM
Canada, ON, Thunder Bay District
Joined Apr 2007
Originally Posted by teb1963 View Post
Hi everyone
Thanks in advance.
Terry
Don't remember the self level option when I set up my OSD Pro with the Guardian. I'm using the ailerons with a "Y" harness and the elevator. These are recommended for RTH with the guardian installed.
Fast Guy is offline Find More Posts by Fast Guy
Old Mar 01, 2015, 03:49 PM
Joined Jul 2005
OSD Pro And RSSI Numbers
I have an OSD Pro system set up on my multi rotor and have RSSI set up on Temp 1 on the eLogger V4. Testing here in the shop my RSSI numbers are between 95 & 99. Randomly the numbers will just start to change on their on going from the real numbers all the way to 0, the display looks like a random number generator. After a couple of seconds of these random numbers the OSD locks back in and shows 95 to 99 and might stay this way for a few seconds up to a few minutes then does it again.
What I do know is the RSSI numbers coming into the eLogger from my receiver remains steady in the 113 to 127 range because they are recorded in the log and can be easily checked.
Anyone saw this problem before or got any ideas, I have checked and calibrated every thing I can think of.
capman231
capman231 is online now Find More Posts by capman231
Site Sponsor
Old Mar 07, 2015, 08:00 AM
teb1963's Avatar
Canada, SK, Regina
Joined Oct 2011
Thanks for the reply Fast Guy.
I see in the manual you are right, but I would really like to have the flaperons usable.
I would like to know if using the guardian on just one aileron would cause any problems with RTH or self level. When in normal flight the ailerons only deflect a few degrees to maintain a level attitude, so I cant see any issues there. However I am not sure how the turning would be when the RTH activated with just one side deflecting. Any thought would be appreciated, or if anyone has done this I would like to hear how well it works.
Terry
For Sale BRAND New CP Pro/with extra battery stgtech2 Aircraft - Electric - Helis (FS/W) 0 Sep 06, 2006 09:35 PM
New eolo pro glitches with cc60 aschen Electric Heli Talk 24 May 20, 2004 08:12 AM
FS New Piccolo Fun with bearing upgrade and HA tail motor Bud Morrison Aircraft - Electric - Airplanes (FS/W) 1 Mar 21, 2004 06:32 PM
For Sale: NEW Pic Pro rotor head with stiffening mod Eco8gator Aircraft - Electric - Airplanes (FS/W) 2 Jun 02, 2003 09:16 PM
