Old Jul 10, 2015, 11:16 PM
speedactyl is online now
Find More Posts by speedactyl
Scratchbuild Aviation
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
Flying Metal
I find very few guys build aluminum plane , especially on the fixwing category
when you reach up to a certain size (from what I know when planes get up to 1500mm size and above ) , this is where building from metal make more sense. to top it all its a retractable membrane wing.
I was flying on an old Brushed 300 Motor 3s less power than a similar size Brushless motor. back in jun 27 on the test frame.
So far I have build both multirotors and fixwings in aluminum
speedactyl is online now Find More Posts by speedactyl
Old Jul 31, 2015, 12:57 AM
alexraz is offline
Find More Posts by alexraz
Philippines, NCR, QC
Joined Apr 2014
The Headplay HD has arrived!
It's more than I expected.
I've only tried it via HDMI playing FPS and simulator games on the Xbox One and PC. It's very immersive and the slightly curved picture helps create the illusion of 3D.
"more than I expected" also includes the weight. It's heavier than I thought it would be and the straps keep slipping from the back of my head (I have long hair).
More on the bad side...
The resolution doesn't appear to be true HD. This maybe due to the fact that it doesn't display in 24 bit color. 3D smoke appears layered, water isn't shiny etc. After a while you don't notice these things when you're trying to avoid getting hit by hiding behind rocks which seem to be really "there".
I'll try this with the toy quad with a 5.4ghz vid over the weekend.
alexraz is offline Find More Posts by alexraz
Old Jul 31, 2015, 01:24 AM
Stringer is online now
Find More Posts by Stringer
Stringer's Avatar
Joined May 2013
I guess it's a matter of expectations then. I expected it to be heavier than it actually is, so I was pleased. I don't know much about its HD qualities since I've only tested it once on the Xbox.
It was also slipping initially, then I placed the 2200mAh 3S that powers it at the back of the strap, attached to the Velcro there. That balanced it well and I can now launch a plane with the HP on my head, like on this video:
Banshee Chase (3 min 8 sec)
Stringer is online now Find More Posts by Stringer
Old Jul 31, 2015, 05:30 AM
alexraz is offline
Joined Apr 2014
Not really heavy but heavier than I thought. This is because I thought it's made of standard epp foam. The foam is tougher than I magine which is a pleasnt surprise. Have you tried the other lens? I might give it a go as I'm slightly far sighted.
Btw, there's a nut and bolt on the strap by the velcro which looks like it was made for the gopro. What's that for?
EDIT: Have you updated the firmware?
Old Jul 31, 2015, 06:46 AM
Stringer's Avatar
Joined May 2013
I've not tried the other lens since I'm quite happy with the default one on wide format. It's really very immersive. I'm near sighted though so maybe YMMV. That part of the strap is indeed a GoPro accessory. They just used that rather than design their own.
I'll be doing the firmware upgrade this weekend. Hopefully it'll be uneventful.
Old Aug 01, 2015, 12:19 PM
alexraz is offline
Joined Apr 2014
Looks like mine shipped with the firmware factory updated. I get snow when I turn off the vTx.
Old Sep 02, 2015, 01:20 AM
speedactyl's Avatar
Joined Jun 2012
Large Scale Ultralight
http://www.rcgroups.com/forums/showthread.php?t=2388412
After weeks on the workbench finally see some air time
1800mm large scale ultralight (1 min 20 sec)
AUW 1.3Kg
950KV motor on 10x45 SF Prop
2600mah 3s
1800mm WS
dub the tarpaulin aircraft which is infact is not exactly tarpaulin but a plastic membrane but holds true that sport pilots called them tube and fabric aircraft.
maiden Aug 15, 2015
for a aircraft of that size and build in take a beating on belly landings
have two near misses with a 250 Quad and a nearby Tree
maiden last july and a 2nd flight in aug31 ,15
PX37 (2 min 28 sec)
another update now on a 850KV and still too small.
Looks like im into heavy metals now
still keep the Foamies available for you guys
EPP , Depron/PS , XPO ,EPP wing cores and Carbonfiber boards
at www.Synerflight.com
Old Sep 02, 2015, 11:27 PM
speedactyl's Avatar
Joined Jun 2012
Yak55 150g AUW
Flash back to 2009-2010
as most would struggle to get more power in their build with bigger motors
one of the lightest build out of a PS depron 3mm 24"x36" board
this is w/o paper
this guy does it with one really small motor for a 32" WS and a incredible 150g AUW , I have not beaten that yet. at most im at the 230g mark.
Scratch Build Yak 55
3mm Foam Board (www.synerflight.com)
One Dime 2204/14 Brushless Motor
GWS 8x4DD or 8×3.8SF prop
10A Emax ESC
Futaba S3153 for aileron
Hitec HS 50 for elevator
Tower pro 5g for rudder
Rhino 2S 20C 360mah lipolies
AUW 150 grams
yak55 rc philippines (1 min 28 sec)
Discussion RC flying in the Philippines neoradix 3D Fuel Heli Flying 23 Sep 02, 2015 01:25 AM
Discussion Philippine Aerial Photos mykmaspogi Aerial Photography 16 Aug 18, 2012 01:06 PM
Discussion Our Flying Field (Philippines) mykmaspogi Your Plane Photos 3 Aug 20, 2008 03:28 PM
Question RC Frequency Band in the philippines athrun4211 Radios 1 Apr 21, 2008 10:47 AM
Flying field in Manila, Philippines??? Any one? Butch777 Electric Plane Talk 2 Sep 26, 2004 08:14 AM
