Old May 20, 2015, 04:17 PM
mcm1303 is online now
Find More Posts by mcm1303
mcm1303's Avatar
Houston, Texas
Joined May 2007
Question about boiling water and depron
I've seen references to thermoforming depron using boiling water. What I don't understand though is depron is polystyrene, the same material as used in expanded bead foam drink cups which can safely hold boiling water. Am I missing something?
Edit: Hmm, seems that whatever the case, many folks have thermoformed depron using boiling water. Even in hot tap water seems sufficient. I have an idea in the works and will expand on it here after running some experiements.
mcm1303 is online now Find More Posts by mcm1303
Old May 21, 2015, 11:36 AM
ruzam is online now
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
It's the 'same material' but it's not the 'same material'. Like all plastics, variations in chemical composition and additives can be tweaked to provide different properties, like flexibility, UV protection and melting point. The foam drink cup formula is tweaked to stand up to boiling temperatures without deforming. The formula used to make flying aircraft is not. I don't know why. Maybe it allows for manufacturing of more complex shapes. Maybe it's just a cheaper way to form and mold EPS.
ruzam is online now Find More Posts by ruzam
Old Yesterday, 10:09 PM
Plantoflap is online now
Find More Posts by Plantoflap
Joined Sep 2003
MacDonalds foam food boxes have plenty of expansion left to build a cambered airfoil wing by bending some Al sheet metal into the camber you desire, then sandwich your foam between the upper and lower metal cambered plates, place rubber bands around it and place in boiling water. The foam gets stronger and stiffer too. The camber is permanent.
Plantoflap is online now Find More Posts by Plantoflap
Question Questions about water planes dragonblade Waterplanes 2 Oct 05, 2014 02:22 PM
Discussion Foam&Boiling Water trick...........blowdryer? RCAddict16 Electric Plane Talk 6 Jul 10, 2012 10:57 AM
Discussion The Old Boiling Water Trick ... gpw Foamies (Scratchbuilt) 2 Dec 07, 2011 05:36 AM
Discussion Boiling water & Depron LiPoSly Foamies (Scratchbuilt) 5 Jul 19, 2008 10:47 PM
