Old Oct 30, 2014, 10:13 PM
I live my life 12oz at a time
arnav's Avatar
United States, FL, Miami
Joined Nov 2011
Fine, fine. Page 146 in the new AMA magazine...
arnav is online now Find More Posts by arnav
Old Oct 31, 2014, 03:24 PM
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
United States, VA, Hamilton
Joined Jul 2012
What's happening on page 146 of the new AMA Magazine?
Pray tell!
ChinoDiablo is online now Find More Posts by ChinoDiablo
Latest blog entry: RCG Plus Membership
Old Oct 31, 2014, 04:26 PM
arnav's Avatar
Joined Nov 2011
Opps, wrong magazine.
Here we go, the Edge is making a appearance:
Old Oct 31, 2014, 04:55 PM
No Static
proving gravity's Avatar
United States, AZ, Gilbert
Joined Mar 2012
That was funny...bahaba!
proving gravity is online now Find More Posts by proving gravity
Old Nov 23, 2014, 09:25 PM
Joined Jul 2012
Busted at the wing tube
Dorked my Edge... boo hiss.
Firewall is messed up.. easy fix.
but the wing tube framing on both the left and right of the fuselage are busted.
Seems like a pretty critical area.
Pics:
Any suggestions?
Old Nov 23, 2014, 09:30 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Yup......here.. Then you have plenty of spares...
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Nov 23, 2014, 09:49 PM
Joined Jul 2012
Are you saying not to bother trying to fix it?
Old Nov 23, 2014, 09:51 PM
arnav's Avatar
Joined Nov 2011
Def try and fix it.
Other then Steve's suggestion (which has merit), it is an easy fix. I had a similar incident here (in fact much much worse). And here are the "after" pics.
1. Peel off the covering from the damaged area (former to former).
2. Glue the broken balsa pieces back in (you did keep them right?). Always take every shred of broken balsa from the field. In the aftermath of a crash it is easy to overlook but it makes life much easier when you have it. If you don't have the missing pieces just make new ones.
3. Glue the wing tube back in. This is a tricky part.
You want to get it in the same place as it was before. 3dhs design the frames with the wing tube precisely where it is. The broken pieces can make it easy. Make sure it is perpendicular to the support "beams" and the fuse.
4. While repairing, test for accuracy often by putting the wings on. Look for a gap between the fuse and the wings root. Don't sweet it if at the end there are a few mm gap. It will not effect flight performance.
5. Try not to get glue inside the wing tube sleeve, so it is not hard to slide the wing tube back in.
6. Sand the balsa down. If necessary, cover any blemishes with lightweight Spackle (available in HD/Lowes) and send it down (easy).
7. Recover
Old Nov 23, 2014, 10:07 PM
arnav's Avatar
Joined Nov 2011
Here is what my "interior" looks like after that crash/fix. You can tell I was missing quite a bit of pieces so I had to make my own (outlined by the blue pen marks). Can you tell my skills improved by the time I got to the second side?
New Product 3DHS 41" Edge "$99 Buck Huck" Ducati Mechanic 3D Flying 17299 Mar 27, 2012 04:37 PM
Sold 3dhs 41' edge buck huck bnf JBuck Aircraft - Electric - Airplanes (FS/W) 7 Jul 02, 2011 07:58 AM
Sold 3DHS 41" EDGE - ORANGE - 99 Buck Huck 6L6Amp Aircraft - Electric - Airplanes (FS/W) 14 Aug 22, 2010 08:45 PM
