Old Jul 05, 2015, 09:09 AM
Jimmy Z is online now
Find More Posts by Jimmy Z
Plattekill, NY
Joined Aug 2007
Fan-Tastic Models Gee Bee
Finished this thanks to Woody on this forum for providing the instructions. I won this on auction and unfortunately it was missing the manual. Woody took the time to scan the instructions and email them to me. Not a difficult kit by any means but has some interesting build features that, for me, made the manual a necessity. Hoping to maiden within the next couple of days.
Jimmy Z is online now Find More Posts by Jimmy Z
Old Jul 06, 2015, 08:20 PM
W. X. Davis is offline
Find More Posts by W. X. Davis
W. X. Davis's Avatar
United States, OH, Reynoldsburg
Joined May 2004
Glad to be of help.
Good luck with the maiden.
Woody
W. X. Davis is offline Find More Posts by W. X. Davis
Old Jul 09, 2015, 07:48 AM
Alien_Tech is online now
Find More Posts by Alien_Tech
Pile-it
Alien_Tech's Avatar
United States, CA, Palmdale
Joined Nov 2007
Great looking airplane! How did you finish it? I have an AT-6 kit that I need to build one of these days.
Alien_Tech is online now Find More Posts by Alien_Tech
Old Jul 09, 2015, 04:32 PM
Plattekill, NY
Joined Aug 2007
The finish was interesting to say the least. The kit included paper masks and the thought was to use double sided tape and attach it to the masks. Then cut the masks out and when you removed the other piece of backing from the tape, you'd have an adhesive mask for painting. (Hope that makes sense). I decided to go a different route and cut the masks. Then I sprayed the back of the masks with a spray adhesive. I let it dry until it was tacky and placed them on the model. So far so good. I sprayed it with a can of Tamiya red, doing the body, wings and wheel pants separately before they were glued together. When removing the masks, it left a bit of adhesive on the model. Not a big deal really, since it's easily removed with orange oil or WD40. However, after the paint dried, I noticed that it had gone hazy and flat in areas. So far, not so good. Guess I should wear my glasses more often because I grabbed polycarbonate spray by mistake. So anyway, I airbrushed on a couple light coats of microscale micro gloss after the paint dried for a couple days. Overall, it gave a nice shine to the red and the unpainted white foam areas.
Old Jul 09, 2015, 05:31 PM
Pile-it
Alien_Tech's Avatar
Joined Nov 2007
Great effort! Sounds like it was worth the hassle though
Old Jul 09, 2015, 06:28 PM
Plattekill, NY
Joined Aug 2007
It was definitely worth the effort. Haven't had a chance to maiden yet due to weather and work schedule but it really does look sharp for a fairly inexpensive foamy.
Old Jul 10, 2015, 05:18 PM
doc-e is offline
Find More Posts by doc-e
Live to fly!
doc-e's Avatar
United States, NJ, Fair Lawn
Joined Nov 2002
Good luck with the maiden!!!
Btw, which motor/ESC/battery did you opt for?
doc-e is offline Find More Posts by doc-e
Old Jul 10, 2015, 08:38 PM
Plattekill, NY
Joined Aug 2007
I actually went with the recommended power plant of the GWS set up. I had everything as spares. I did set it up though, so that if i find that it's not to my liking, I can pull stuff out without ripping the whole plane apart. I am using a 3s 1050 Mah lip and it appears to be spot on with CG. Seems to be plenty of power but been a long time since I used a brushed motor!
Old Jul 12, 2015, 07:40 PM
Plattekill, NY
Joined Aug 2007
Maidened the Gee Bee today. What a great flying little plane. Thought the brushed system would be weak but it really flew well. Took a little bit to get used to not having a rudder on the stick but it worked well. To save weight on this model both ailerons and rudder are controlled by one servo. Very happy with this one.
Old Jul 13, 2015, 07:04 AM
Joined May 2004
Congrats on the maiden.
Woody
Old Jul 17, 2015, 01:50 AM
gnduoxiey is offline
Find More Posts by gnduoxiey
Joined Jul 2015
gnduoxiey is offline Find More Posts by gnduoxiey
Question Fan-Tastic Models Gee Bee R1 Instructions doc-e Foamies (Kits) 13 Jun 23, 2015 05:25 PM
Discussion Fan-Tastic Models Gee Bee matthew954 Foamies (Kits) 2 Feb 21, 2009 03:09 PM
Wanted Fan-tastic Models Gee Bee R1 hyperknight Aircraft - Electric - Airplanes (FS/W) 21 Feb 12, 2008 03:32 AM
Wanted Fan-tastic models Gee Bee R1 Flyin Brick Aircraft - Electric - Airplanes (FS/W) 6 Aug 17, 2007 12:59 PM
FS: Fan-TasTic Models Gee Bee R-1 Racer hubdave Aircraft - Electric - Airplanes (FS/W) 3 Feb 07, 2004 03:54 PM
