Old Mar 02, 2014, 07:24 PM
theguyJames
1970IHTA's Avatar
United States, NY, Port Jefferson Station
Joined May 2013
Help!
HobbyKing PQ battery plugged in backwards
I'm wondering if someone can tell me if there is a chance, after plugging the battery in backwards, if my HK PQ can be repaired or if its done. It still shows up and seems to function properly in the MultiWii program as if everything is ok. However, with the battery plugged in properly, now only the red led lights up, no blue led or receiver led.
BTW, I've purchased my first ever set of reading glasses since then.
1970IHTA is offline Find More Posts by 1970IHTA
Last edited by 1970IHTA; Mar 02, 2014 at 08:31 PM. Reason: changed from discussion to HELP!
Old Mar 02, 2014, 10:16 PM
United States, MD, Stevensville
Joined Jun 2013
Does it fly?
Waterbound is online now Find More Posts by Waterbound
Old Mar 03, 2014, 09:37 AM
theguyJames
1970IHTA's Avatar
Joined May 2013
nope
Old Mar 03, 2014, 05:06 PM
Joined Jun 2013
What happens when you arm it? Are the end points set as necessary (1000-2000 and everything close to 1500 at neutral )? Have you calibrated each esc?
Old Mar 03, 2014, 10:29 PM
Btnewman's Avatar
Joined Oct 2013
Edit: this should help http://www.rcgroups.com/forums/showp...&postcount=971
Just blew the dc to dc pump. Let me see if I can find the link to help you fix it...
Btnewman is online now Find More Posts by Btnewman
Old Mar 03, 2014, 10:57 PM
theguyJames
1970IHTA's Avatar
Joined May 2013
It was flying great with both my OrangeRX T-Six and my DX8 with the ORX R100 until I plugged in the battery backwards. Then it would show up in MultiWii, but once unplugged from my computer, would not arm at all.
THAT IS FANTASTIC!!! I'll post my results as soon as I can attempt the repair, hopefully by tomorrow afternoon. I'm really looking forward to it. I don't know what it is about that little guy, I just love it.
THANK YOU VERY MUCH!!!
Old Mar 03, 2014, 11:34 PM
Btnewman's Avatar
Joined Oct 2013
This one started my fleet of 7 quads... And growing. Its still one of my favorites.
Old Mar 04, 2014, 12:01 AM
theguyJames
1970IHTA's Avatar
Joined May 2013
here I go too... I ordered the Turnigy Micro X quad, and also a NQX board along with the Chaoli motors for my Ladybird frame. Can't get enough of this micro stuff. I also read somewhere around here that they might be making the Chaoli motor for the Proto-X. If they do, then I'll just have to get the proper contoller to really wake those little guys up.
Last edited by 1970IHTA; Mar 04, 2014 at 12:17 AM. Reason: Turnigy Micro X..... looks like an H to me
Old Mar 04, 2014, 02:35 PM
theguyJames
1970IHTA's Avatar
Joined May 2013
So... I tried the jumper repair... I thought it looked great (with my new 2.5x reading glasses and under my workbench light with a magnifying glass) until I took a picture and zoomed in
When I plugged it into the computer, all 3 LEDs light up, it seems to be functioning properly in the MultiWii program and will even respond to Tx input.
When I disconnect it from the computer and plug in the battery, only the red and receiver LED light up, no blue LED.
Just to see what would happen, I then tried uploading a sketch file again with the same results.
So then I was wondering about the bootloader. I'm guessing if it functions properly in MultiWii, I should not have even had to bother with the sketch file, let alone have to upload a new bootloader. So while I was pondering things and poking around on HKs website, I noticed 1 PQ was in stock. Talk about impulse buying...
Old Mar 04, 2014, 11:44 PM
theguyJames
1970IHTA's Avatar
Joined May 2013
I read on the PQ thread somewhere that indeed a sketch file can be loaded without the bootloader. Waiting on a FTDI tool to try one last attempt. Wish I had the tool before I added the jumper. If uploading the bootloader works I can continue practicing my soldering skills when I order the replacement component I removed. Maybe its time to get a hot air station
Old Mar 05, 2014, 01:53 AM
Btnewman's Avatar
Joined Oct 2013
The bone stock quad works with the gui really good without the Bootloader. To upload the bootloader you will need a usbasp (from ebay, its faster and in stock) they are also a good tool to have around if you plan on keeping going with the quads
Old Mar 05, 2014, 07:03 PM
theguyJames
1970IHTA's Avatar
Joined May 2013
ah, I thought it was the FTDI tool. I need to read a bit more thoroughly!!! Going to order the usbasp tool... thanks for the heads up.
Old Mar 11, 2014, 08:25 PM
theguyJames
1970IHTA's Avatar
Joined May 2013
GIDDY UP!!! Got it working... THANKS FOR THE HELP!!!!!!
Old Mar 11, 2014, 10:07 PM
Btnewman's Avatar
Joined Oct 2013
Did you end up getting the usbasp to get it going again?
Discussion Can plugging a servo backwards into the receiver, short out an esc? Cwupilot Electric Flight Events 1 Dec 14, 2013 08:20 AM
Help! esc reads 5 cells once video tx battery plugged in jimbo24 FPV Equipment 1 Sep 22, 2013 04:25 AM
Discussion Plugged TX battery in backwards... SpyHawkFPV Radios 9 Oct 20, 2008 01:28 PM
Help! 6EXHP plugged battery in backwards now its not working BowerR64 Radios 5 May 09, 2008 12:23 AM
dont plug the batteries in backwards! hermperez Batteries and Chargers 16 Apr 30, 2005 01:13 PM
