Old Apr 06, 2014, 10:45 PM
Gopher huntin' stick jockey
turboparker's Avatar
East Bethel, MN USA
Joined Jul 2009
Yes it will work. The Beast & Gee Bee use the same form-factor brick, and they also use the same AS3X settings. As Twinyfly noted, Beast 3D bricks have the upgraded 4.9A continuous/5.8A peak ESC, which means that you can slap on a 5030 prop & try 3s without worrying about hitting OCP or OCP.
Joel
turboparker is online now Find More Posts by turboparker
Old Apr 07, 2014, 06:37 AM
I'd rather be flying!
rcflyer40plus1's Avatar
Joined Jul 2010
Excellent, thanks for the confirm.
rcflyer40plus1 is online now Find More Posts by rcflyer40plus1
Old Apr 14, 2014, 05:32 PM
Joined Jul 2011
Just got myself a used busted up umx gee bee from a friend.Told me if I could fix it I could have it.I fixed her all up and flew 3 batteries with it.My question is if i move the aileron servo rod to the outer hole on the aileron will that make it less aggressive?I fly it with a dx4e so not much adj.It was on the 2nd outer hole when I got it so I assume that is stock set-up.It was a bit of a hand full I thought.Has anyone tried this set-up and found it easier to fly?
airwoods is offline Find More Posts by airwoods
Old Apr 14, 2014, 08:48 PM
East Bethel, MN USA
Joined Jul 2009
Great! How badly was it damaged?
Yes, moving the pushrods further out will reduce aileron throw. However, I suggest that you start with expo, instead. In case you're not aware, the DX4e does have fixed expo - 25% on aileron, elevator, and rudder. The activation instructions are (oddly) in the Hyper Taxi manual. See page 10. If the expo doesn't tame things down enough, then reposition the pushrods. BTW - the Gee Bee needs all of the elevator & rudder authority that it can get, due to its true-scale empennage. You'll probably want to move the rudder & elevator pushrods all the way in before you activate expo.
Be sure to mechanically center the surfaces after moving the pushrods. Power-up the plane & let AS3X initialize (but don't touch the throttle), then disconnect the batt. This ensures all servos are centered. Next, adjust the U-bends until all surfaces are centered.
Joel
Old Apr 14, 2014, 10:29 PM
Raikkonen for President
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Joel
Correct me if I'm wrong cuz I don't have one but doesn't the Gee Bee need a bunch of right rudder permanently mechanically trimmed in?
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Apr 15, 2014, 12:36 AM
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
^ correct.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Foamie Resurrection
Old Apr 15, 2014, 07:41 AM
Joined Jul 2011
Thanks guys.I did do the expo adj on my dx4e and going thru the gee bee manuel I did see that they recommended 1mm to the right for rudder adj.That explains why when I first flew it it need all the trim I could give it to the right to keep it from drifting left and it also centers the rear wheel.When I got the plane the left wing was ripped off not in a pretty way and a few carbon rods were broke.I didn't want to put no money into it and glued the wing on with ca and then ran a thin bead of clear dap silicone tub caulking along the the seem of both wing.That stuff works great,strong hold and has some flex to it.Iv'e used it many times for my other micro repairs.Anyways the plain does fly true and straight.
Old Apr 17, 2014, 07:51 AM
Joined Jul 2011
Just bought a new dx6i so now have the adj to tame down my gee bee.Has anyone tried their gee bee's with dual rates turned down below 70% and a low expo rate to see how it fly's.I'm not really into super responsive rc planes but I do like how this planes looks fying by and it was given to me so I would like it to fly to my liking.This weekend I'm going to try it at 60% dual rate and 30% expo.I don't want to get to crazy with the adjustments and have it not flyable so does this sound like a good starting point?The last time I flew it was with my dx4e that I think has a fixed expo of 25% when activated and on low rates which i think is 70% and it still turned on a dime.
Old Apr 17, 2014, 11:18 AM
bhoov128's Avatar
Joined May 2012
Sounds good to me - the rates & expo in the manuals are just suggestions after all. Radio settings are another step in trimming, you set them to what YOU like them to be at.
Old Apr 18, 2014, 06:07 PM
Joined Jul 2011
Went out this morning to test fly my gee bee with my radio settings.I ended up going with 50% dual rate with 25% expo.my first battery was 60% dual rate with 30% expo,felt a tad slow to react.Fly's the way I like it now.
Help! Adrienne Paige Gee Bee R2 Plans Eric Giorgiantonio Fuel Plane Talk 5 Jan 29, 2012 11:02 PM
For Sale Herr Gee Bee R2 (NIB) 25" wingspan pdawg Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Oct 12, 2011 10:20 AM
Wanted Adrian Page Gee Bee Z 1/5th and/or Gee Bee R2 1/5th (looking for) Xanix Aircraft - Fuel - Airplanes (FS/W) 0 Jul 23, 2007 06:16 PM
