Old Oct 12, 2014, 10:02 AM
Joined May 2014
esc help
ive been told a 25amp esc will work with my motors but what would happen if i used a 30amp esc
azza1985 is offline Find More Posts by azza1985
Old Oct 12, 2014, 10:06 AM
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Azza,
As long as your ESC can handle the ampdraw of the motor, nothing will happen, other than the motor turning, provided you programmed the ESC properly (if required).
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Oct 12, 2014, 10:08 AM
Joined May 2014
i got told a 20amp will work but a 25amp is better but trying to find a cheap/decent esc
Old Oct 12, 2014, 10:13 AM
Sneek, Netherlands.
Joined May 2004
Hi Azza,
Would this be an ESC for the motors in your twin motor baitboat?
Knowing what your plan is, would make it easier for us to make suggestions on what to get.
Regards, Jan.
Old Oct 12, 2014, 10:18 AM
Joined May 2014
hi yeah i need two esc one for each of the motors then ive got a mixer as the boat doesnt have a rudder and the boat is steered by the jet motors
Old Oct 12, 2014, 10:29 AM
Sneek, Netherlands.
Joined May 2004
Hi Azza,
As I asked in the other thread; measure the motors.
In the picture it looks like 700 size motors with the radio noise filter on top of the connector end.
A pair of callipers would shed some light on the length and .
Regards, Jan.
Old Oct 12, 2014, 10:33 AM
Joined May 2014
does 457 800 mean anything
Old Oct 12, 2014, 11:21 AM
Joined Dec 2004
Azza1985- Judging by the picture you have posted, it looks like the boat in question is around 20 long. Trying to guess as to the size of the motors, I would say, 360 to 400 size motors at the largest compared to the size of the connectors in the wiring in the hull.
A 20 amp speed control would be more than enough to power up both motors in the boat.
frankg is offline Find More Posts by frankg
Old Oct 12, 2014, 11:28 AM
Joined May 2014
I'm planning on running a esc on each motor and having a mixing
Old Oct 12, 2014, 12:47 PM
Sneek, Netherlands.
Joined May 2004
Hi Azza,
If you don't have the tools to measure the boat and the motors, or you can't be bothered to do so, please say so and I'll stop asking for more info in order to help you...
Regards, Jan.
Old Oct 12, 2014, 01:16 PM
Joined May 2014
I was reply to Frankg thank you very much there's no need to be so rude I'm trying to measure bout but can't get to it as my daughter is in bed and it's in the back of my shed so I'm
Not leaving me daughter unattended in the house while I sort through my shed to get at the boat
Old Oct 12, 2014, 05:16 PM
Joined May 2014
Found out I need a 25amp esc with forward reverse has any heard of this and what it be ok in a boat
Old Oct 13, 2014, 03:55 AM
Blackpool, Lancs
Joined Feb 2006
This does say that it is for a car. This implies that it has a brake function. If this cannot be programmed out, it will not work with a mixer. Mixers just apply speed and direction control to two motor controls in proportion to the steering channel setting, so there is no provision for a dab of reverse for braking. The current rating should be just fine, given the usual caveat that car ESCs operate with plenty of air cooling whereas boat ESC tend to be inside a sealed box. There is no mention of its voltage, so I would guess at a max of a 6 cell pack, maybe 7.
mfr02 is offline Find More Posts by mfr02
Old Oct 14, 2014, 05:16 AM
Sneek, Netherlands.
Joined May 2004
Hi Azza,
If asking for information on the subject you're asking about is perceived as being rude, than I was being rude(ish)...
Keep in mind that 'longdistance adviceing' via a forum depends on the information given by the one who asks for it.
The combined knowledge of the forummembers on the matter is vast, but very few have a (working) crystal ball, hence the need to provide information.
Regards, Jan.
Help! Hi, need help choosing motors and ESC's Arvydas Multirotor Talk 2 Sep 28, 2014 04:28 AM
Discussion Help Please-----Naza M V2 and Lumenier 30A Simon K ESC's DesertSportsma Multirotor Power Systems 1 Sep 27, 2014 12:24 AM
Question help with flashing ESC abutcher Multirotor Electronics 1 Sep 26, 2014 10:49 PM
Discussion Help Naza M V2 and Lumenier 30A ESC's DesertSportsma Multirotor Talk 0 Sep 26, 2014 10:27 PM
Discussion Tamiya TBLE-02S ESC Help JimiGibbs Electric Power Cars 5 Sep 26, 2014 08:48 AM
