Old Jul 29, 2014, 10:19 AM
Joined Jul 2014
Help!
NEED help locating needle valve
I posted this yesterday but perhaps in the wrong section.I recently purchased a mccoy .049 diesel model plane engine. My intention was to just run it for fun however the needle valve is broken. So my question to you is where do i find a replacement needle/ or would a spray bar/needle from another manufacturer fit? Thanks, here is a pic of said engine.
Thanks-
therealmccoy is offline Find More Posts by therealmccoy
Old Jul 29, 2014, 02:54 PM
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
PAL Model Products.
http://www.palmodelproducts.com/McCoyDiesel
RyanNX211 is online now Find More Posts by RyanNX211
Old Jul 29, 2014, 06:11 PM
Joined Jul 2014
thank you, ill give them a shot
Old Jul 29, 2014, 06:46 PM
Joined Feb 2013
If the spraybar is still OK, it might be a better idea to get a repro needle made up, especially as I think the McCoy spraybar is pressed in. Jon Fletcher in Australia does superb work and his repro's are indistinguishable from the originals
Twin Stack is offline Find More Posts by Twin Stack
Old Jul 30, 2014, 08:50 AM
Joined Jul 2014
This is starting to sound expensive hahaha, The webiste above didn't seem active so i dropped them an email. How do i get in contact with jon? Yes its just pressed in.
Old Jul 30, 2014, 09:49 AM
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
FWIW, I've got a few "new old" original spraybars.
Should you need one, please contact me.
Gluehand is online now Find More Posts by Gluehand
Old Jul 30, 2014, 11:41 AM
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
You may need to replace the special type o-ring on the contra-piston, they don't last long and if they leak, engine won't start.
E-Challenged is offline Find More Posts by E-Challenged
Old Jul 30, 2014, 06:14 PM
Joined Feb 2013
Another possibility is Woody Bartelt here - http://www.woodysengines.com/
Old Jul 30, 2014, 06:26 PM
Joined Jul 2014
The spraybar seems to be in good condition and I was able to remove the broken needle. So I think I just need a new needle valve(and o-ring), thank you.
Old Jul 30, 2014, 06:30 PM
Joined Jul 2014
You are correct, i dissasembled the engine and some white shavings fell out. I later realized these were parts of the o-ring.
Old Jul 31, 2014, 01:50 AM
central AZ
Joined May 2002
I've been looking for a McCoy .09 diesel needle (the first version) for months, with no luck. I may have a spare needle I can send you, but I'll have to check. That way, at least ONE of us can get an engine running!
KnifeEdge51 is offline Find More Posts by KnifeEdge51
Old Jul 31, 2014, 09:40 PM
Joined Jul 2014
That would be awesome if you do, i would be more then happy to pay you for shipping plus whatever its worth.
-thanks
Old Aug 04, 2014, 03:43 AM
Joined Jul 2014
bump
Old Aug 04, 2014, 05:26 PM
Ian Easton's Avatar
United Kingdom, Scotland, Fife
Joined May 1999
I've got lots of the correct o'rings you need. They're actually a flat fibre washer.Send me a message with your address and how many you need.
Ian
Ian Easton is offline Find More Posts by Ian Easton
Old Aug 04, 2014, 06:29 PM
central AZ
Joined May 2002
-thanks
Sorry for the delay, I got your PM. I'll check tonight to be sure and let you know, but I'm 99.9% positive I have a spare. I'll shoot you a PM when I get home from work.
Found need needle valve and prop nut and washer for os bgx1 1.08 HUGH DURDEN Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 30, 2014 10:32 AM
Question K&B 6.5 Front Needle Valve Needed propaplace Control Line 3 Apr 27, 2014 08:54 AM
Help! Need ID on needle valve bribtb Engines 9 Feb 12, 2014 06:04 PM
Sold Price RThunder Tiger .Reduced 20 Model 7701 need muffler & Needle valve $7. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 28, 2013 02:18 PM
Help! broken valve needle thing need help on identifying rc_pro_86 Fuel Plane Talk 5 Feb 18, 2009 08:55 PM
