Old Nov 20, 2014, 12:11 AM
Joined Feb 2010
Questions about data-loggers
I am trying to build a test bench to gather information on power systems
(propellers, motors, ESC's, batteries) and I have a couple of questions regarding the capabilities of Data-Loggers.
Can a data-logger show Throttle-Position?
Maybe from 0-256-bits or 0-1024-bits or 0-100-percent.
And would there be any way to add a load-cell or weighing-scale to one of the channels to measure thrust in units that can be converted to grams?
Thanks in advance
JD
JD-Slow-Thumbs is offline Find More Posts by JD-Slow-Thumbs
Old Nov 20, 2014, 12:41 AM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
The Medusa data logger did exactly that. It has a converted postal scale that functions as an accurate load cell and it records a whole bunch of parameters including Throttle position. Unfortunately they got out of that business some years ago due to the Chinese manufacturing Juggernaut. If you can find one second hand they are an excellent piece of kit.
I'm not parting with mine.
John
jj604 is online now Find More Posts by jj604
Old Nov 20, 2014, 03:06 AM
Joined Feb 2010
Originally Posted by jj604 View Post
The Medusa data logger ... I'm not parting with mine.
Sounds like a happy customer
The Medusa data logger did exactly that. It has a converted postal scale that functions as an accurate load cell and it records a whole bunch of parameters including Throttle position. Unfortunately they got out of that business some years ago due to the Chinese manufacturing Juggernaut. If you can find one second hand they are an excellent piece of kit. John
Sounds like exactly what I am looking for,
hopefully there is a modern equivalent.
JD
Old Nov 21, 2014, 08:29 PM
Joined Jun 2011
An Eagle tree data logger can do what you want, you will also need an A/D expansion module and a load cell which is powered by a 5V supply voltage. The recorded data will be mV. You will not be able zero or calibrate the data in Eagle Tree, you will need to down load the data to a spread sheet then manipulate the data with your own calibration constant.
http://www.eagletreesystems.com/inde...&product_id=92
A suitable load cell might be
http://au.element14.com/measurement-...sor/dp/9638717
gliderhg is offline Find More Posts by gliderhg
Old Nov 24, 2014, 05:00 PM
Joined Feb 2010
Sounds like the perfect solution for building a comprehensive test-bench.
JD
Old Today, 10:04 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Here is my test bench:
Pulling Power Testing Station @ R2Hobbies - http://www.rcgroups.com/forums/showthread.php?t=1442088
And the details on the Arduino based thrust measuring system for the static testing:
Arduino Prop Testing Thrust Gauge - http://www.rcgroups.com/forums/showthread.php?t=2112595
The eLogger is pretty hard to beat for this, it works static, gets all the data except the thrust reading recorded for you, and can go for rides in the airplane too...
Jack
jackerbes is offline Find More Posts by jackerbes
Discussion what micro control EagleTree Data logger used? lazy-b DIY Electronics 2 Oct 10, 2014 03:12 PM
Discussion Rookie question about data loggers for batteries NAP1947 Beginner Training Area (Aircraft-Electric) 1 Sep 04, 2014 04:29 AM
Discussion Tech Stuff about Altitude\Data Loggers MikeHLG Hand Launch 33 Apr 27, 2007 04:13 PM
Question BNB data logger question- or any shunt for that matter johnrobholmes Power Systems 1 Dec 16, 2006 09:56 AM
Discussion question for those useing flight data loggers Dennis C Batteries and Chargers 12 Oct 20, 2006 11:27 AM
