| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#46 |
Confused? Who, me?
What I meant was I didn't remember servo covers being in the kit so I used some from my stock, which I bought off ebay. I used hot melt glue which has shock absorbing properties and which is easily cut away if you need a servo change - two features not applicable to superglue, as you have discovered. I used a 9g servo for the elevator, offset to one side and with the z bend coming up from beneath the servo arm. I fitted a dubro type adjuster at the elevator end - not the right place to keep the weight down but it works well. I had to dremel away just a tiny bit of the lip of the underwing recess to get clearance for the servo.
I started out out with the plane balance close to 60mm using a 300mah 4.8v battery. I've changed to using a 210mah so the CG has moved back but I'm not sure by how much, and I sense it could go back further. I'd suggest you start out at 60-65, bearing in mind the "nose heavy flies badly, tail heavy flies once" rule. |
#47 |
Unregistered User
go to 75mm.
It will be fine |
#48 |
Don't milquetoast me!
mine came with two servo cover that are perfect for the job. I glued the servo to the good one and screwed it into the wood. 9mm servo for the elevator.
75mm eh? the recommended 55 does seem very far forward.......... |
#49 |
Ronnie - Sheffield UK (G0NJD)
where do you fly?, I''m in Sheffield and thinking about joing SAA
Ronnie Ive got the Speedo and Ptero-X (still got to make them of course) |
#50 |
me? I fly down in Warwickshire. I'm from Yorkshire though. My sister used to live in Sheffield.
I don't know much about soaring round there, I've only started since i moved "dahn saaath" My speedo is nearly finished. Just need to make something to hold the canopy down and balance her...... |
#51 |
Had everything out the box today to get a good look at what needs doing. On the inside between the wing and canopy the GRP isnt quite finished so will have to do a repair on the inside. I cannot find any instructions, so will rely on posts from here.
Ive tried a 4 x AAA pack and it justs fits but I prefer to put some kind of foam round so will be looking at a flat 4 x AAA pack Im also thinking of using my Spektrum DX6 but am a bit wary with the 'carbon' canopy, may just use standard 35mhz until I know everything works Ronnie btw if I keep buying Chinese planes I'll never get round to building my 2m Raven! Last edited by mallettron; Jun 09, 2007 at 01:32 PM. |
#52 |
i'm not sure how you're going to fit a flat AAA pack into the fuse. I'd love to see pictures! do you mean a 2+2?
the instructions are worse than useless anyway don't worry. Most people have joined the wings. bin the metal screw and replace it with a plastic bolt and wing nut. CofG seems to be in the range of 65 to 75mm from what i can gather. The servos need to be installed ONTO the servo covers or they won't fit into the wing. not sure about the carbon canopy and your radio. test it, i guess........ control throws seem to be as far as you can get on the ailerons (not far down) and not that much elevator (depends a bit on your CofG etc of course). |
#53 |
Just found these
http://cgi.ebay.co.uk/SANYO-6V-1000m...QQcmdZViewItem With the cells being offset slightly I think they may go in better. Also they are 1000mah so should last longer I wont buy from them but at least I know what to ask for Ronnie |
#54 |
don't buy that for sure - it's got three cells on the bottom and two on the top - i.e it's wider than a AAA square pack. I don't see that having 6 volts will be much of an advantage anyway.......
5AAA cells are bigger than 4 AAA cells....... |
#55 |
I was hoping that with them being offset that they would be slightly slimmer in width (a few mm I know), I really wanted something 'snug' but witha bit of gap for some foam. 4.8v or 6v, difficult to decide, maybe the extra ballast will help, maybe not
Ronnie |
#56 |
it's still wider than a 4 cell pack and a 4 cell only just fits in....... i don't see your reasoning, but it's your money.....
#57 |
Im obviously not explaining it right
Looking at batteries in a diamond formation rather than a square pack (where the 2 side ones touch and the bottom and top ones rest in the hollow formed by the others), this should give a bit more space at the side and still leave room for some foam We will get there in the end Ronnie |
#58 |
funnily enough i've got a diamond pack for another plane. I tried it, and like you say you get a bit more room at the side. the only trouble is that you can't push it very far into the nose, as it's a bit too high (it has to sit in the canopy opening).
#59 |
builder , flyer,repairer
just waiting on the Passer Thermo its a little bit larger hope the quality is the same as the speedo's Ive seen ,although a bit of carbon tow under the wing saddle is an improvement,
SteveW |
#60 | |
I suppose final decision will be when cog needs to be sorted out Ronnie |
| Thread Tools | |
| Discussion 1.2m Speedo Thermal Glider | bray | Slope | 7 | Nov 24, 2008 03:24 AM |
| Sold Great Planes Fling 1.2M RTF | Christian_C | Aircraft - Sailplanes (FS/W) | 5 | May 02, 2006 03:51 PM |
| Art Hobby Zuni 1.2M @ Cape Blanco | ScaredyCat | Slope | 1 | Dec 17, 2005 12:04 PM |
| Zuni 1.2M build thread. | Botterii | Slope | 35 | Apr 01, 2004 04:37 PM |
| Art Hobby Zuni-V 1.2M | Botterii | Slope | 1 | Feb 17, 2004 04:57 PM |
