| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#16 |
A new day, a new gadget
Very nice. Recognise that AMT set up from doing one for my Phase 5! Although the 5 is a little slimmer back there and has 1/16" plywood walls.
#17 |
Double Coat TimTams
joiner boxes
Thanks Garry et al.
Made some joiner boxes this am. 3 oz kevlar plain weave, with thread direction perpendicular to span to prevent bursting open on those massive DS circuits ;0) In hindsight I should have been neater working the fabric to give a clean straight edge at the root. The tip ends can be as rough as guts. You can scroll-saw cut kevlar after it's set but it still ends up fluffy. I'll have to apply a smear of bog afterwards then sand to make it neater. Chris. |
#18 |
Double Coat TimTams
Thought about a Ritz section Tim, but I'll try this first. The DS19 should be good too.
Another wing is an option. With the joiner box set-up multiple wings fit the same fuz. I like the idea of a 2m wing with HN483 for slermalling. Chris. |
#19 |
Double Coat TimTams
joiner boxes done
Joiner boxes cured (still need another 24 hrs though) and joiner ends trimmed.
Chris. |
#20 |
Constantly Amazed
Nice project!
I'm a big Chris Foss fan: got a Middle Phase II sloper (learned to fly with it 19 years ago and it's still going strong!), and also a Wot-4. I always fancied a Phase 6 - Great looking model. Now you mention the all moving tailplane to reduce drag , it looks to me like a good candidate for a wingeron or pitcheron conversion? Flat ply fuselage sides...or maybe it's just a twist-wing 'Phase' I'm going through Cheers, |
#21 |
Double Coat TimTams
WIP, cloth cut for spars
The wide spar allows me to eliminate any shear-web.
Next-up, sanding the trench for the spars and not forgetting servo lead channels. Chris. It's been raining all Sunday...that's 13 ot of 15 weekends unflyable
#22 |
Double Coat TimTams
What servos should I use? Pref. digitals.
13mm depth maximum. Chris. |
#23 |
Byte my shiny metal @ss
I've got these servos for my latest build. They have been tested on a DS plank and are awesome.
http://www.giantcod.co.uk/epower-met...-p-403797.html Hope you can get some for a good price. Don't see much point in buying expensive servos while those bad boys are around!
#24 |
Sorry, that link is for the non digi, they do the digi's for £7.50.
#25 |
Double Coat TimTams
Wip
Had some spare time to move the project along a bit.
Cleaned the spray gun and sprayed the mylars, top orange, bottom black acrylic gloss thinned 40%. The paint is drying, after which I'll wet-out the cloth on the mylars and apply it to the cores making 2 mylar/ cloth/resin foam tacos. Then in the bag for 24hrs. Kudos to Bill Haymaker & Phil Barnes for their vac-bagging DVD which has made this process hassle-free. Chris. |
#26 |
Looking very nice indeed.
I can see you have also watched the bagging video. It looks like you have done everything by the book there! Pasty and I used the methods and got some really good results so far. Please post some more pictures as you go, very interesting to see. |
#27 |
DrFragnasty, when the Kevlar fray's during sanding I was taught to spritz the fray with Ca let it go off and continue sanding and repeat as necessary.
#28 | |
Eric |
#29 |
Double Coat TimTams
Original Phase 6 wing set-up
It was just 1/16th sheet balsa over white foam cores Eric. The wing was built in 1-piece with a fibreglass wrap dihedral brace. 1 wing hold down bolt at the trailing edge and a 3/4" dowel at the leading edge located into F2.
Thanks for the CA tip Prodjx. The vac pump is on for 4 secs and off for 40...there's a leak somewhere ;0) Despite this the vacuum is still around 20- 22". Chris. Last edited by DrFragnasty; Oct 13, 2009 at 08:19 PM. Reason: typodread |
#30 |
Double Coat TimTams
Wip
Shots of the production line.
| Thread Tools | |
| Help! How to fly this Phase 6.... | satinet | Slope | 21 | Dec 13, 2006 12:54 PM |
| Sold Chris Foss Phase 6 (2 kits) | linklemming | Aircraft - Sailplanes (FS/W) | 0 | Oct 05, 2006 10:27 PM |
| For Sale UK - Chris Foss Phase 6 Sport kit - aerobatic slope soarer | Bill Glover | Aircraft - Sailplanes (FS/W) | 0 | Jan 31, 2006 09:46 AM |
| Phase 6 | HVAC25000 | Slope | 24 | Sep 09, 2005 06:28 AM |
| Idea Old Skool Sailplane to return to the skys?? | Scoobyvroom | Sailplane Talk | 3 | Jan 04, 2004 08:35 PM |
