| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Double Coat TimTams
Old Skool Phase 6
Chris Foss's Phase 6 is a fave of mine and I thought with a deeper fuz and lower frontal area, vac-bagged wing with live-hinged flaps and ailerons and an all-moving tail I could reduce drag and make it go a bit faster and have better knife-edge performance.
Other mods: 2 piece wing with joiner/ joiner box and plug in mpx connectors. e374 and 1.7m span. HT13 tail section. Chris. Last edited by DrFragnasty; Sep 11, 2009 at 05:52 PM. Reason: Extra crunch |
#2 |
Chuck it off a cliff
a phase 6 1/2 !
interested to know how this goes Phil. |
#3 |
Double Coat TimTams
Progress
Next up;
joiner box |
#4 |
Double Coat TimTams
It should be more rigid and faster I guess Phil. No real change to the moments/ aerofoil just lower drag. The flaps will add to versatility and the live hinging and wipers should help lower drag too.
AUW about the same as the orginal. |
#5 |
Lands upside down
Looks nice Chris!!
What's that BAT (big ass thing) in the background? Steve |
#6 |
Double Coat TimTams
ex-Modelfight 1/4 scale Discus Steve.
Flown once in unfinished state off the slope at Stanley (it goes really well) but currently shelved unitl I find time to finish it off properly. Chris. |
#7 |
the 2-piece wing is an excellent idea - the big one-piece wing on mine was a pain to transport & store
Phil. |
#8 | |
Stay calm and carry on
S |
#9 |
Double Coat TimTams
Thanks for the encouragement...it makes doing the tedious jobs that little less unpalatable ;0) I'm off to sand the tips.
Chris. |
#10 |
Byte my shiny metal @ss
Makes me want to get my phase 6 back in the air!
Good work, cant wait to see the results and fingers crossed on the knife edge!
#11 |
Double Coat TimTams
Wip
Spent 2 hrs sorting out slop-free tail crank and rudder pushrod.
This setup is not ideal. If you pull the tail joiner out, the crank falls inside. It's a bit of a pain to re-locate. I have to remove it to finish off the fuz. Next up is plank the fuz turtledeck, bag the tails. Chris. Last edited by DrFragnasty; Sep 18, 2009 at 10:28 AM. Reason: Illogical Spock |
#12 |
Double Coat TimTams
FYI I'm using West Systems resin with the fast hardener. This gives a 6hr cure.
Also the pivot blocks were reamed out to give a clearance, the hole then filled with bog mix then the waxed joiner inserted and left to set. Remove joiner and you have a solid mount. |
#13 |
I'm using that west systems resin and its so far been a joy to work with.
Good work! |
#14 |
You sure that joiner's big enough? Don't be taking any chances now!
S |
#15 |
Its not IF... Its WHEN.
Lovely Job!
Phase 6 is a classic and your update looks great. If I were to try something like this I might be looking at a more modern section than E374 though - say, DS19? Best of luck with it anyway, I just love Chris Foss designs and its great to see them still inspiring people to build in a traditional way Tim |
| Thread Tools | |
| Help! How to fly this Phase 6.... | satinet | Slope | 21 | Dec 13, 2006 12:54 PM |
| Sold Chris Foss Phase 6 (2 kits) | linklemming | Aircraft - Sailplanes (FS/W) | 0 | Oct 05, 2006 10:27 PM |
| For Sale UK - Chris Foss Phase 6 Sport kit - aerobatic slope soarer | Bill Glover | Aircraft - Sailplanes (FS/W) | 0 | Jan 31, 2006 09:46 AM |
| Phase 6 | HVAC25000 | Slope | 24 | Sep 09, 2005 06:28 AM |
| Idea Old Skool Sailplane to return to the skys?? | Scoobyvroom | Sailplane Talk | 3 | Jan 04, 2004 08:35 PM |
