Go Back   RC Groups > Aircraft - Sailplanes > Slope
Old Oct 24, 2009, 07:55 AM   #46
Double Coat TimTams
That's a nice P6 Jon.
I don't suppose you've got an Estrella as well ;0) ?
As for progress the root ribs are done (hard balsa) and the servo lead runs are marked out ready for melting.
I only wish I had a long piece of piano wire a la Phil Barnes. I might resort to routing a channel with the Dremel then running drinking straws along it.
Chris.
DrFragnasty is offline Find More Posts by DrFragnasty   Reply With Quote
Old Oct 25, 2009, 01:29 AM   #47
Not in Kansas anymore Toto...
cynjon's Avatar
Not yet...
cynjon is offline Find More Posts by cynjon   Reply With Quote
Old Oct 28, 2009, 03:39 PM   #48
Slopejunkie
dav3uk's Avatar
Heres an original phase 6 Pro from around 1980 always had a soft spot for the shape (skinny kipper)
Dave
  • Name: phase6.jpg
Description: Pylon racing with street lamps circa 1980 Pylon racing with street lamps circa 1980 55.8 KB · Views: 48
dav3uk is offline Find More Posts by dav3uk   Reply With Quote
Old Oct 30, 2009, 05:58 AM   #49
Double Coat TimTams
Wip
That cuts a striking profile Dave...still got it?
Here's work-in-progress.
Next-up:
  • reinforce tail pivot with a little more carbon cloth
  • size and cut wing mylars (just top/bottom for 1 side)
  • cut fabric
  • position hinge fabric
  • do layup and in the bag
  • trim flaps ailerons
  • cut hinges
  • cut out servo bays
etc.
Chris
  • Name: 1.jpg
Description: servo lead channels are done...simply drinking straws then backfill with spackfiller. servo lead channels are done...simply drinking straws then backfill with spackfiller. 91.9 KB · Views: 41
  • Name: 2.jpg
Description: e374...sort of a Clark Y with a high Philips entry. Joiner/ joiner box fit is snug. e374...sort of a Clark Y with a high Philips entry. Joiner/ joiner box fit is snug. 80.1 KB · Views: 51
  • Name: 3.jpg
Description: Orange tail still looks foul. Turtledeck done but only after servos installed and pushrods sorted. Orange tail still looks foul. Turtledeck done but only after servos installed and pushrods sorted. 126.4 KB · Views: 43
  • Name: 4.jpg
Description: Lots of travel! I'm quite pleased with the mechanical action of the tail, not much play and not much friction. Note aerial exit. Lots of travel! I'm quite pleased with the mechanical action of the tail, not much play and not much friction. Note aerial exit. 78.5 KB · Views: 42
  • Name: 5.jpg
Description: Spot the tragedy in the making  ;0)
The gold n' rod inner is for the aerial, larger hole for wing servo lead bundle. Spot the tragedy in the making ;0) The gold n' rod inner is for the aerial, larger hole for wing servo lead bundle. 65.5 KB · Views: 55
  • Name: 6.jpg
Description: Schultze 835 and 1600mAh Intellects to go in the snout.
One way to install servo bearers is size them, drill them (with clearance of .75mm from servo) mount servos, attach pushrods postion servos then apply zap and accelerator. Schultze 835 and 1600mAh Intellects to go in the snout. One way to install servo bearers is size them, drill them (with clearance of .75mm from servo) mount servos, attach pushrods postion servos then apply zap and accelerator. 103.0 KB · Views: 54
Old Oct 30, 2009, 07:35 AM   #50
Byte my shiny metal @ss
Hexosex's Avatar
Good stuff! I think there might be some binding when that servo arm is at 20 degrees! How you gonna fix that?
Hexosex is offline Find More Posts by Hexosex   Reply With Quote
Old Oct 30, 2009, 02:37 PM   #51
Slopejunkie
dav3uk's Avatar
Alas no after about 3 wings and new fuz it was totaled in a collision with a large rock just out of sight in the grass at a slope not local to me........funny afterwards all the locals said "didnt you know about the rock we never land there..."
Old Oct 31, 2009, 07:21 AM   #52
Double Coat TimTams
Wip
If you're gonna crash Dave it might as well be a rock, there's no point going in half-arsed.
Pushrod clearance sorted by using slightly larger servo arm.
Fin mount done. Tail pivot entombed but it's easy to re-locate the pivot holes.
Tails sprayed.
Next-up: cut the mylars
Chris.
  • Name: 7.jpg
Description: All balsa to balsa done using this glue. All balsa to balsa done using this glue. 109.4 KB · Views: 34
  • Name: 8.jpg
Description: Too much bench flying not enough building  ;0) Too much bench flying not enough building ;0) 113.2 KB · Views: 41
  • Name: 9.jpg
  • Name: 10.jpg
Description: increased side area should make knife-edge better increased side area should make knife-edge better 87.0 KB · Views: 37
Old Nov 02, 2009, 02:05 AM   #53
Double Coat TimTams
Wip
Did a bit more this am.
I bought a moisture filter for the spray gun and it's working. There's droplets forming in the collecting vessel after only a brief spray.
The little spray gun works well but it is brand new and doesn't have any caked on residue yet...
Next up, cutting the cloth.
Chris.
  • Name: 11.jpg
Description: 14 mil mylar, cut to suit and waxed twice. 14 mil mylar, cut to suit and waxed twice. 104.2 KB · Views: 44
  • Name: 12.jpg
Description: I'm impressed with this gun; smooth and light and holds enough for a wing. I'm impressed with this gun; smooth and light and holds enough for a wing. 117.9 KB · Views: 42
  • Name: 13.jpg
Description: White acrylic down with lots of hairs dammit; I'll gently tease them off with a fingernail. I may have to evict the cats. White acrylic down with lots of hairs dammit; I'll gently tease them off with a fingernail. I may have to evict the cats. 101.9 KB · Views: 35
  • Name: 14.jpg
Description: Matt black acrylic for the underside. Matt black acrylic for the underside. 87.2 KB · Views: 43
Old Nov 04, 2009, 02:03 PM   #54
Very nice job Chris, do you have the plans?
Tks!
Jack
jackdb is offline Find More Posts by jackdb   Reply With Quote
Old Nov 05, 2009, 01:10 AM   #55
Double Coat TimTams
reverse indian ear
No Jack,my father has the original kit which I've "backed-up"
for posterity. I bascially copied the wing/tail moments/ fin profile
and wing planform and took it from there.
If I had time I'd reverse-engineer this version into a vector file.
Chris.
Old Nov 05, 2009, 04:23 PM   #56
Double Coat TimTams
In the bag
In the bag and holding vacuum v. well; 2 secs on for 3.5 mins off.
I'm short of table space so just 1 wing at a time at this stage.
The joiner box got deformed under vac. So, removed the wing and inserted a foam plug into the joiner and re-sealed. It's still not perfect but we'll see how it works out tonight.
Chris
  • Name: 1.jpg
  • Name: 2.jpg
Description: Another shot of Scrooge's bag clips Another shot of Scrooge's bag clips 92.4 KB · Views: 25
  • Name: 3.jpg
Description: Acrylic caulking used to seal the long edge rather than a hot iron. Much more successful! Acrylic caulking used to seal the long edge rather than a hot iron. Much more successful! 101.4 KB · Views: 33
Old Nov 05, 2009, 10:32 PM   #57
Lands upside down
flyonline's Avatar
Interesting that you like the caulk better than sealing the bag. I had trouble with the stuff I used, it pulled too easily and after a couple of uses there were plenty of micro holes I couldn't chase down. I switched to using a soldering iron and L Al bar to hold it nice and tight and at a slow speed it seals and cuts at the same time and I can now get many (10+?) uses from the one bag before it starts to let go.
Looking nice, I've always been a bit of a fan of retro stuff.
Steve
flyonline is offline Find More Posts by flyonline   Reply With Quote
Old Nov 06, 2009, 03:11 AM   #58
Double Coat TimTams
Wip
Sounds like a good solution Steve. I'll keep that technique in mind.
The acrylic caulk is OK but where the clips crimp the edge there's some stress on the bag & clips because of the caulk thickness. I had to move the clips inwards because it cut a leak after my mucking-around with the joiner box insert.
As for lay-up:
1.4 oz kevlar leading-edge stuck on with 3M77.
3/4 oz outside, 1.4 oz 'glass inside and 1.5" wide peel ply strip sandwiched between the 2 on the lower skin for bottom-hinge flaps/ailerons.
It's still a bit green so will trim it more tomorrow am.
Chris.
  • Name: 9.jpg
Description: 3/4 oz & 1.4oz 'glass on a 45 degree bias. See the insert for the joiner box? It actually came out wihtout any effort! 3/4 oz & 1.4oz 'glass on a 45 degree bias. See the insert for the joiner box? It actually came out wihtout any effort! 92.7 KB · Views: 32
  • Name: 8.jpg
Description: Spare resin from the wing was used to secure fin. Spare resin from the wing was used to secure fin. 122.6 KB · Views: 28
  • Name: 7.jpg
Description: Trimmed a bit....more to come off the trailing edge though Trimmed a bit....more to come off the trailing edge though 89.5 KB · Views: 23
  • Name: 6.jpg
Description: The spar is showing....you can see its guts! The spar is showing....you can see its guts! 86.7 KB · Views: 31
  • Name: 4.jpg
Description: Tip courtesy of Phil Barnes; use lots of resin on the kevlar LE fabric and it's give you a good result. I'm convinced. Tip courtesy of Phil Barnes; use lots of resin on the kevlar LE fabric and it's give you a good result. I'm convinced. 67.0 KB · Views: 28
  • Name: 5.jpg
Old Nov 06, 2009, 08:24 AM   #59
Chris.
All right, Tks Chris!
Old Nov 06, 2009, 10:58 AM   #60
You ought to see if you can get Tacky Tape over there, I get ti locally at a roofing supply store. It's 1/16-1/8th inch thick and about 1/2inch wide, and then I use a roller. If I'm careful I can snap it apart and use it over again several time's. At Grumman's Advanced Composites Facility in Georgia we used to bring it in buy the railroad car. I've been using it since 1971. We used to use steel angle iron frame's on our vacumme table's with mixed sucess. I've never used those split tube's, seem's like they create leek issue's. We had a gun shaped device with ear phone's that could detect leak's. I'm retired now and miss it.
prodjx is offline Find More Posts by prodjx   Reply With Quote
Help! How to fly this Phase 6.... satinet Slope 21 Dec 13, 2006 12:54 PM
Sold Chris Foss Phase 6 (2 kits) linklemming Aircraft - Sailplanes (FS/W) 0 Oct 05, 2006 10:27 PM
For Sale UK - Chris Foss Phase 6 Sport kit - aerobatic slope soarer Bill Glover Aircraft - Sailplanes (FS/W) 0 Jan 31, 2006 09:46 AM
Phase 6 HVAC25000 Slope 24 Sep 09, 2005 06:28 AM
Idea Old Skool Sailplane to return to the skys?? Scoobyvroom Sailplane Talk 3 Jan 04, 2004 08:35 PM
