Old Jul 02, 2014, 07:46 AM
Fly low
silly's Avatar
Joined Jan 2012
I think I need to get a metal bracket fabricated as the muffler sits very close to the bracket.
silly is offline Find More Posts by silly
Old Jul 04, 2014, 06:19 AM
lorhd2005
massachusetts
Joined Aug 2008
Hi guys,I will be starting my build soon, as I've read this whole thread, there are some concerns, I will be using electric power, I think that will alleviate some of the concerns, I will strenghten the nose gear, and what about the fuselage, I've read about it's flexing, is it critical that I strenghten it, is so ,what do you guys think would be the best way,all inputs would be greatly appreciated, I don't want to lose this plane, heard its a great flyer, so have to get over the issues,thanks!
lorhd2005 is online now Find More Posts by lorhd2005
Old Jul 04, 2014, 06:29 AM
*It Ain't Lookin Good*
olezippi's Avatar
Evansville IN
Joined Aug 2004
I have no issues with the fuse. Mine seems pretty strong. If your going electric you should have no problems except the nose wheel. It will be fine with normal landings and even a somewhat hard landing provided you don't hit on the nose gear first.
olezippi is online now Find More Posts by olezippi
Old Jul 04, 2014, 07:03 AM
lorhd2005
massachusetts
Joined Aug 2008
Thanks olezippi
Old Jul 11, 2014, 02:03 PM
Go fast, pull up.
Fidelity101's Avatar
United States, NY, Clarence Center
Joined Nov 2008
Vibration is your enemy...that explains 95% of the problems! Gas engines like to vibrate at idle...a lot!...and some more than others. The plane is designed with fiberglass on fiberglass, which is perfect for electric and a "rookie mistake" for gas. Seriously, Hangar 9 engineers should know better! :-)
But back to your questions...going electic is an excellent way to go with this beautiful plane. It will keep the doors attached and probably prevent the wing failure, which could have been caused by weak glue joints vibration over time. The nose gear will be fine, but since you can't buy the nose gear mount separately, I recommend you take a piece of copper plate and bend it to contour the front center portion of the mount...and JB weld or screw it into place. This will allow some give, but provide much needed support for that "not so perfect" landing. :-)
Fidelity101 is online now Find More Posts by Fidelity101
Old Aug 16, 2014, 05:41 PM
United States, WA, Bellevue
Joined Oct 2010
I'm considering starting a build of this plane. I am weighing my options with the power setup on this thing. I usually like my planes better when they tend to fly faster/with more power. I'm know I'm going to use the power 160 motor on this plane for sure (already have one), but I have some room to play with the ESC and the prop...
So, can I go with a bigger prop - say 19x10, 19x11, 18x11 or a 18x12 prop on this plane for better performance without frying my motor on 10S? Ground clearance might be a problem with 19", so I guess 18" with higher pitch would be better (if the motor will take it).
Also, the specs for the Power 160 motor say it needs upto a 110 Amp ESC. The motor is rated for 60A continuous (max 78A), so shouldnt an 80A ESC always be enough? Why would you ever need a 110A ESC for this motor? Are they implying that the motor can be used to pull more than 80A?
Here is the link: http://www.horizonhobby.com/products/EFLM4160A#t2
coolgg is online now Find More Posts by coolgg
Old Aug 17, 2014, 03:49 AM
Scratch Builder
AlexanderB's Avatar
Braunschweig, Germany
Joined Sep 2006
Actually I would not do that. I have a 3-bladed 17" prop (variable pitch) and with the same Motor and 10s I just cannot use the full power. This plane keeps level with my setup at 5-6 Amps . With 70Amps this plane is a racer.
Just my 2 Ct
Cheers Alexander
AlexanderB is offline Find More Posts by AlexanderB
Old Aug 17, 2014, 02:06 PM
Joined Oct 2010
Wow, thats crazy
Do you know what pitch you're running it on when you get max speed? The thing is that from the videos of this plane online, it doesnt seem to be that fast...Anybody know how many mph on full throttle on the recommeded manual setup for electric this can do?
Article Horizon Hobby Hangar 9 P-47D-40 Thunderbolt 30cc ARF kevin Scale ARF/RTF 43 May 29, 2014 09:48 PM
Discussion Hangar 9 pulse 60 ARF, electric motor won't work? Aaronmathis087 Beginner Training Area (Aircraft-Electric) 23 Apr 09, 2013 06:47 AM
Sold Hangar 9 Edge 540 120 ARF & Hangar 9 Cap 232 120 ARF bbrc77 Aircraft - Fuel - Airplanes (FS/W) 2 Apr 03, 2013 06:36 PM
Sold Hangar 9 Ultra Stick 60 arf cheap-80.00 radman615 Aircraft - Fuel - Airplanes (FS/W) 3 Mar 27, 2013 07:23 PM
Sold Hangar 9 P-40B Warhawk 50 ARF Chaser11 Aircraft - Electric - Airplanes (FS/W) 2 Mar 26, 2013 10:03 PM
