Old Mar 01, 2012, 10:08 PM
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Build Log
Guillows Hellcat 32-3/4", 1st big build...
Got started on the fuse today, asked for some opinions about putting all the stringers in on the fuse. The experts say go with the stringers so that's what I'm set up for now.
Certainly not a laser cut kit but going together pretty well, so far. Two things I learned reading through a bunch of build threads, I've put to use today; I got a big hypodermic needle syringe and now am using it for my wood glue dispenser, works great.
Also saw "dmccalgon" using magnets to hold the half former pieces together in his Guillows 1004 Corsair build, this really makes glueing the halfs together an easy task.
I just need to take my time and THINK, "measure twice---cut once"
Bill
Bill Smudge is offline Find More Posts by Bill Smudge
Old Mar 01, 2012, 10:31 PM
San Bernardino California U.S.A.
Joined Dec 2009
It's ...
... well, NICE!
Laramie.
Laramie is offline Find More Posts by Laramie
Old Mar 02, 2012, 02:21 AM
Spitfire1954's Avatar
United Kingdom, England, East Riding of Yorkshire
Joined Jan 2011
Looking good – keep up the good work!
Spitfire1954 is offline Find More Posts by Spitfire1954
Old Mar 02, 2012, 05:54 AM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Looking good Bill.
4 grams saved at the tail meens almost a half ounce less weight at the nose to keep the cg in the same spot.
About the 'snakey', don't glue the formers to the horizontal keel until everything is in alignment. Also, make sure the keel just slides in the notches without forcing any formers out of line. Open up the notches if necessary even if it seems like a lot. You can fill the gaps later.
Looking at your pic, the 7th or 8th former back is has the vertical keel bowed a bit. You might need to 'move' the horizontal keel notch on those formers to bring everything into alignment.
Glenn
glewis is online now Find More Posts by glewis
Old Mar 02, 2012, 10:44 AM
Joined Jul 2011
Spit and Laramie, thanks for your comments, jump in any time with any help or suggestions.....
Originally Posted by glewis View Post
Looking good Bill.
Glenn
Thanks for the tip Glenn.
This is the first balsa model I've ever built using half formers and keels, so it's all a learning process
Soooooooooo next time I'll know about the loose keel notch thing.
Now I'm pondering servo placement before I jump into putting stringers in.
I'm thinking ailerons and elevator, no rudder. But I can go full house if you guys think that would be better.
See this pics for my proposed servo location. Probably will use lightweight plastice tubing and small music wire for pull rods.
I belive I'm going with the removeable wing route. Having the wing come off gives all kinds of access, but I suppose you sacrifice strength.
Decisions, decisions......
Bill
Old Mar 02, 2012, 11:19 AM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
It's not too late to straighten the fuse by cutting a sliver of wood out of the notch. Much better to have everything nice and straight to start with instead of trying to force it into alignment later.
If you are not adding landing gear I would skip the rudder. I use it mostly for landing and taxiing.
I like to attach the wing with magnets, makes for easy removal.
Glenn
Old Mar 02, 2012, 11:42 AM
Canada
Joined Nov 2000
As above
IMO you Must straighten the thing out. Before going Any further.
What seems like 'too much work' now will give invaluable result ..in a few days
Banana models neither look good nor fly well.
Bare is offline Find More Posts by Bare
Old Mar 02, 2012, 06:51 PM
Joined Jul 2011
Glenn and Bare I did what you suggested, get the chalkline out I think shes pretty straight now.
Boy am I learning alot on this build, everything I've done before has been box and former. These long fuses with keels add a whole new area to screw up...
I hope I don't offend the balsa purest out there but I like to use a block of blue foam to mount my servos, very light and strong, best of all easy.
I also used a little block of foam to help hold everything in alignment.
Starting to run my stringers now going back and forth one side to the other this will take a while.
Bill
Old Mar 02, 2012, 08:51 PM
conrad907's Avatar
China, Guangdong, Shenzhen
Joined Feb 2012
Looking good Bill. I have one of these I started, but put asside to enter the multi-engine Fun-Build. I'll be following your build closely though.
conrad907 is offline Find More Posts by conrad907
Old Mar 02, 2012, 08:54 PM
Canada
Joined Nov 2000
Good on You Mate!
Willingness to effect needed repairs/changes is the signature of a competent builder. Yer on well your way :-)
Old Mar 02, 2012, 09:00 PM
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
That looks a lot better Bill, now she's straight!
Foam? Who cares man, foam, wood, paper, heck I don't care if you use concrete.
The fact is you are building the model, not dumping 5 parts out of a box, screwing them together in an hour and call it a 'build'.
Glenn
Old Mar 03, 2012, 07:29 AM
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
Looking good Bill. I like to use rudder even though my models don't have gear because I like to do stall turns and snap rolls. Lack of a rudder limits some of the aerobatic maneuvers you can make.
It will be interesting to see how much yours weighs vs my enlarged 16" version. Good luck and I will be watching.
Jim
JIMA is offline Find More Posts by JIMA
Old Mar 03, 2012, 09:15 AM
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Nice start. Subscribed!
Steve
Steve85 is offline Find More Posts by Steve85
Old Mar 03, 2012, 09:42 AM
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
AMEN!
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Mar 03, 2012, 11:41 AM
Joined Jul 2011
Glenn and Fuzz,
Amen-Amen on building vs. "assembling", of course different strokes for different folks.
Thanks Jima and Steve, think I'll leave the rudder off on this one. Hope to be as light as possible, probably no LG either.
Next big decision:
I have built using all the stock stringers, not quite finished yet.,
Which has a greater chance of working well for a newby sheeter/planker?
Strip-planking with 1/16 and sand the heck out of it or go for my first sheeting job using 1/32?
Better yet If I could just convince Jima to plank mine I'll just drop it in the mail to him, he has done a great job on his H-cat.
Mulling over a possible removeable front cowl/motor mount assembly held on by magnets. I did this on a Coment SR-7 I built last December and it worked very well. You pull the cowl off, motor and all, and have a nice big 'ol area for your battery to go right in the front of the bird.
Bill
Discussion 32" Guillows Hellcat fuse decisions... Bill Smudge Scale Kit/Scratch Built 7 Mar 03, 2012 10:55 AM
Build Log Fun Build 4 Guillows Hellcat JasonG Scale Kit/Scratch Built 23 Apr 15, 2011 06:40 PM
Build Log Guillows F6F-3 Hellcat Build (Kit 1005) Ashhash Scale Kit/Scratch Built 39 Jan 12, 2011 05:29 AM
Discussion First build Guillows F6F-3 Hellcat BlackAce13 Fuel Plane Talk 9 Jul 25, 2010 06:12 PM
Discussion Guillows Hellcat build scigs30 Free Flight 40 Jan 11, 2010 09:04 PM
