Old Aug 08, 2014, 04:26 PM
Close enough
AtomicFlyer's Avatar
United States, NM, Los Alamos
Joined Jun 2008
Watt's Up watt meter display contrast issue
Hey guys. I bought this Watt's Up watt meter about 5 years ago. It works fine but about 6 months ago the display started to become unreadable because of the contrast.
I emailed the manufacturer to ask about a solution but I never got a reply. It's out of warranty so I opened it up to see if there was a potentiometer to adjust the contrast. There aren't any pots. So I was wondering if anyone knows which resistor controls contrast.
I found one other post with the same issue but that meter was new and the guy was able to return it.
Thanks in advance.
Marc
AtomicFlyer is offline Find More Posts by AtomicFlyer
Old Aug 08, 2014, 04:32 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Show the rest of the board. You're showing the wrong end of the board.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Aug 08, 2014, 04:36 PM
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
usually a pair of resistors as a voltage divider on pin3....but that doesn't really look like a contrast issue to me.
if you do have to replace it then 2x16 displays are easy and cheap to find and most have the same pinout...find the data sheet for yours and then look around for one that matches pin wise and layout wise.
ZAGNUT is offline Find More Posts by ZAGNUT
Old Aug 08, 2014, 05:02 PM
Close enough
Joined Jun 2008
Andy
Andy,
I've attached a photo of the main board. The display board is soldered to the main board using a .1" pitch pin header. I haven't desoldered the display pcb from the main board, but there are 5 resistors on the display board also. I'm now suspecting one of those may control contrast.
Zagnut,
I removed the LCD display and there is a number printed on it. But I couldn't get a hit when I searched google for it. A photo is attached.
Marc
Old Aug 08, 2014, 05:32 PM
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
that "display pcb" is an integral part of the LCD module, part number and manufacturer will be on the back of it.
if there is any space between the boards i would cut the pins to free the display and then just desolder each pin individually.
Old Aug 08, 2014, 06:50 PM
Close enough
Joined Jun 2008
Zagnut,
Thanks for the tips. I cut the pins and the LCD module is a Xiamen Ocular GDM 1602H. I've attached the data sheet in case anyone else is ever looking for it.
You are exactly right. Pin 3 is used to supply a voltage for contrast adjust. There is a trace from pin 3 to R15 on the main board so I think it's using R15 and R16 as the voltage divider.
Thanks for your help.
Marc
Old Aug 08, 2014, 07:52 PM
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
that's the smaller standard size, bit harder to find than the slightly larger module but still tons out there. if the contrast adjustment doesn't work then a new one might be $5-$10, maybe even cheaper on ebay?
whatever you get just make sure the pinout is the same, some manufacturers run the pins in the opposite direction and one even reverses the ground and +V. also don't be tempted to get a backlit one unless you have lots of spare room in the case as they are usually much thicker.
have fun!
Old Aug 08, 2014, 08:51 PM
Close enough
Joined Jun 2008
have fun!
If I don't mind waiting to have it shipped from Hong Kong to the USA, I can get one for under $4 on eBay. This has been a fun learning experience. Thanks for your guidance.
Marc
Old Aug 12, 2014, 05:14 PM
Registered crasher
cyklopz's Avatar
Germany
Joined Mar 2012
How do you open up the Watts Up?
I tried to pry it open with a knife but that didnt work. On the manufacturers website they sell just the case as a spare, and they mention glueing it together.
Good to see that the lcd can be replaced
cyklopz is offline Find More Posts by cyklopz
Old Aug 12, 2014, 08:44 PM
Close enough
Joined Jun 2008
I used a cutting disc on a rotary tool. I cut right at the seam.
Marc
Old Aug 20, 2014, 11:06 AM
Joined Dec 2004
Hi Marc,
Thanks for the photos showing the internals of the Watts Up meter. I'm thinking of building an energy meter based on the same basic design layout. From what is shown it looks like the black wire (negative) passes current through a .001 ohm current sampling resistor. The photos don't show where the red wire goes, but my guess is it just passes across the board without connecting to anything. Is this correct?
Thx,
Dick
rivers is offline Find More Posts by rivers
Old Aug 20, 2014, 09:31 PM
Close enough
Joined Jun 2008
Originally Posted by rivers View Post
Hi Marc,
Thx,
Dick
Hi Dick,
I was going to repair my Watts Up meter but I ended up just buying this GT Power meter for $20 on eBay.
I did completely disassemble my Watts Up meter but it's at the dump now. I'm pretty sure the red wire has to land on the board somewhere because otherwise you wouldn't have a reference potential to power the electronics.
Good luck with your project.
Marc
Old Aug 21, 2014, 03:21 AM
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
Hi Marc,
Thx,
Dick
this might help with your project:
http://www.bhabbott.net.nz/wattmeter.html
Bruce Abbott is also a member here.
Old Aug 26, 2014, 01:24 PM
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
I had the same issue once the other way, it was too faint to read on hot days.
First, you should have a look at the rubber connector strips, which sit between the glass screen and the contacts on the PCB. Clean those carefully with alcohol on both the glass- and the PCB-side, and reassemble the display correctly.
If this should not solve your issue, you have to change the contrast voltage. The pins with positive voltage and ground as well as the contrast pin have been identified as I understand. Connecting the contrast pin via a 5-10k poti with positive will change the contrast in one direction, maybe darker, maybe lighter, I forgot. Connecting the contrast pin to ground will change the contrast the other way. Alternatively, you can try changing the resistors on the voltage devider already present.
I was able to correct the contrast on mine using this mod.
Julez is offline Find More Posts by Julez
Sold Watt's Up Power meter, Turnigy Charger and lipo bags AtTheCross Aircraft - Electric - Power Systems (FS/W) 8 Jun 19, 2014 06:37 AM
Question Watt meter on external display? ravencsr Power Systems 4 Jun 06, 2014 06:45 AM
Discussion watt's up meter max amps rcalldaylong Power Systems 21 Mar 28, 2014 06:40 PM
Wanted Watt Meter, Watt's up Meter...Working or not! kctrading Aircraft - General - Miscellaneous (FS/W) 0 Nov 17, 2007 10:21 PM
Any difference between a "Watt's Up" meter and the Heli "Watts up" meter? xray328 Electric Plane Talk 1 Oct 17, 2005 11:23 PM
