Old Feb 17, 2004, 01:38 AM
ron_sb is offline
Find More Posts by ron_sb
UFO
ron_sb's Avatar
United States, FL, Jupiter
Joined Dec 2003
Idea
Attach RX antenna to airframe
As a newbie I was unaware of the danger of having the RX antenna just dangling out of the model.
While doing a vertical stall the prop caught the antenna and snapped about 2/3 off it. Luckily I had the Berg-5 RX so the plane was unaffected by the loss of antenna length. Only after landing I saw that it happened.
If the antenna would have ripped out of the reciever instead of snapping my plane would have been toothpicks.
Lesson for today, tape that antenna to your model so it can't reach the prop.
ron_sb is offline Find More Posts by ron_sb
Old Feb 17, 2004, 01:29 PM
nupeswv is offline
Find More Posts by nupeswv
St. Catharines, Canada
Joined Mar 2003
Another thing to do is to write down what your original antenna length was so you can solder on a proper replacement when your done your midflight snipping. The length is very important for optimum operation. 1m (39") is the norm for most but I think the frequency and type of tx can alter this.
nupeswv is offline Find More Posts by nupeswv
Old Feb 17, 2004, 01:45 PM
ron_sb is offline
UFO
ron_sb's Avatar
Joined Dec 2003
I'm not sure what length of the Berg antenna is (hence your hint ) luckily the antenna wrapped it self around the prop shaft and stayed there without doing harm. So I soldered it back together with minimal loss of length. (maybe 1-2 mm).
Old Feb 17, 2004, 02:40 PM
potifar is offline
Find More Posts by potifar
san marcos, ca
Joined Jun 2001
antenna length
all our receivers come with a 1 meter long antenna.
peter berg
potifar is offline Find More Posts by potifar
Hitec 555 RX Antenna Came out! Tram Power Systems 4 Nov 23, 2001 12:19 AM
Where to run RX antenna on Ky F16? DeanW Electric Ducted Fan Jet Talk 0 Nov 18, 2001 08:32 PM
Rx antenna re-attachment? cold boy Power Systems 3 Jul 04, 2001 12:14 AM
Increasing rx antenna length. Erik Johansson Power Systems 9 Jun 19, 2001 11:35 PM
Rx Antenna routing on an F5B fuselage avalanche Electric Sailplanes 3 Apr 22, 2001 11:50 PM
