Old Mar 14, 2015, 02:16 AM
NoLimitRC is online now
Find More Posts by NoLimitRC
I have a degree in crashing!
NoLimitRC's Avatar
United Arab Emirates
Joined Dec 2014
CC3D Vs Naze32?? (as of 2015)
I want to get either one of these flight controllers for completing my 250, I wanna have some good fun, so stability in FFF and turns are very important, I will be using an EMAX 250 Pro OR a Diatone #37, I don't want to spend a lot of time tuning , A lot of people say (or said) that the CC3D is hard to program, But I believe there is a new PC program to set it up which is easier, The Reason I want to get a Naze32 is because many people such as bruce(xjet) and BMSWEB use it!.
Pls state the differences of each.
THANKS!
NoLimitRC is online now Find More Posts by NoLimitRC
Old Mar 14, 2015, 07:43 AM
Granted is online now
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
Honestly no real difference 'tween them, pretty similar hardware-wise. Both will run the same software (with the exception of OpenPilot, and I think that might have been ported to Naze), so I would go with the best deal you can get. I have both running CF, no preference.
Granted is online now Find More Posts by Granted
Old Mar 14, 2015, 09:36 AM
NoLimitRC's Avatar
Joined Dec 2014
Does setup take similar times? thanks
Old Mar 14, 2015, 09:52 AM
Dan Baldwin is offline
Find More Posts by Dan Baldwin
Dan Baldwin's Avatar
United States, CA, Norwalk
Joined Apr 2004
I'm changing my quads from Naze32 to CC3D. I don't like the fact that when you increase PID gains, you reduce stick response. KK2.1 and CC3D don't do that. I was never able to get good crisp response in yaw at fairly high rates with the Naze32. I fly acro exclusively. The naze may be fine for FPV or aerial photography.
Dan
Dan Baldwin is offline Find More Posts by Dan Baldwin
Old Mar 14, 2015, 10:54 AM
NoLimitRC's Avatar
Joined Dec 2014
Ok I think Ill get the CC3D as some local flyers have em too. Does it matter which company I get them from, I want a case and soldered pins(90` Or straight?) Thanks!
Old Mar 14, 2015, 12:10 PM
Neverl8 is online now
Find More Posts by Neverl8
United States, WA, Seattle
Joined Jan 2015
Banggood USA currently selling for $17.59 with case it looks like and straight pins.
http://www.banggood.com/OpenPilot-CC...m_content=xuxu
Neverl8 is online now Find More Posts by Neverl8
Old Mar 14, 2015, 12:45 PM
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
I have a BG one, it works fine. The one I got from everbuying.com is a $20 glue spreader.
Old Mar 14, 2015, 01:05 PM
NoLimitRC's Avatar
Joined Dec 2014
So i should be getting the straight pins one then yeah?, emax 250 and diatone 37 frames... thanks alot for the help
Old Mar 14, 2015, 01:18 PM
NoLimitRC's Avatar
Joined Dec 2014
Alright will be getting the cc3d from banggood . Thanks again u guys
Old Mar 14, 2015, 02:11 PM
these_savages is offline
Find More Posts by these_savages
Joined May 2013
Dan
when you say response, do you mean rates?
Do you use cleanflight?
these_savages is offline Find More Posts by these_savages
Old Mar 15, 2015, 04:23 PM
Joined Apr 2004
Yes, I mean rates; if I get the board set up for the rate of rotation I like (say 500 degrees/second) and I increase the gains, the rate of rotation is decreased.
No, I'm using baseflight.
Dan
Old Mar 15, 2015, 05:26 PM
reelflyt is offline
Find More Posts by reelflyt
reelflyt
Edmonton, Alberta, Canada
Joined Mar 2010
Dan
Hi.
Cleanflight runs on CC3D and Naze32 and Flip32 and others .
You have a choice of 6 different PID controllers . PID 3 is very popular for quick response and good feel . Check it out defore changing over , and there is lots of support for it .
Gordon
reelflyt is offline Find More Posts by reelflyt
Old Mar 16, 2015, 02:02 AM
NoLimitRC's Avatar
Joined Dec 2014
How hard is it to flash the bootloader on the cc3d, I can get a chinese one for 15$
Old Mar 16, 2015, 09:13 AM
Joined Apr 2004
Originally Posted by reelflyt View Post
Hi.
Gordon
Too late. I already changed out the FCs on my scratchbuilt 450 and 200. We'll be changing out the KK2.1.5 in my son's 450 and putting in a CC3D some time this week.
It could be that the problems I had with the PID system in BaseFlight have been fixed in CleanFlight, but I have been very happy with OpenPilot and the CC3D, so I don't see any reason to change at this point. I did download CleanFlight and plugged in an old Naze32 board to play with it. I may stick together a PVC quad to play with it at some point.
Dan
Old Mar 16, 2015, 10:24 AM
Joined May 2013
like reelflyt said.
i just changed over to cleanflight and tried out pid controller 1 (multiwwi "rewrite")
and the difference is crazy. its very responsive and pid is not supposed to affect rates with that controller i think. I didnt need to tune the TPA either, it was just smooth right away, i only had to lower pid`s a bit.
check out oscar liang : http://blog.oscarliang.net/pid-contr...2-cleanflight/
For Sale New in Box! Naze32 Acro, Naze32 Pro, CC3d w/ Case danphillips Aircraft - Electric - Multirotor (FS/W) 32 Feb 12, 2015 01:27 PM
Discussion cc3d vs naze32 Ilay Multirotor Electronics 8 Nov 22, 2014 08:08 AM
Discussion 2015 Subaru WRX STI vs. The Drones commercial jreo Multirotor Talk 2 Apr 14, 2014 09:47 PM
