Old Mar 03, 2014, 12:20 PM
TahoeDirk is offline
Find More Posts by TahoeDirk
Used Registerer
TahoeDirk's Avatar
United States, CA
Joined Mar 2010
4 in the pod?
Hi again, is anyone having luck with four servos in the pod/fuse?
I believe I have finally recovered from the sound of "pristine DLG meets granite at 70mph" so I'm in the building mode again. I have two new pod designs and I don't like either. Once again I am contemplating trying to stuff all my servos in my pod, even if it means yet another design. I can't help thinking it could shave hours off the build process, omit the wiring harness and make changing wings easier. Someone must have tried this right? Please help persuade or dissuade me.
This years new resolutions/wisdom? are 1. no switchjack 2. charge battery regularly, even if it is a 1400mah.
Here's a picture of my latest, 11oz ,oops
Thanks, Dirk
TahoeDirk is offline Find More Posts by TahoeDirk
Old Mar 03, 2014, 12:48 PM
MikeHLG is offline
Find More Posts by MikeHLG
London
Joined Apr 2004
Blaster, Snipe, XXLite, TWEagle, Fireworks, all use 4 servos in the pod.
MikeHLG is offline Find More Posts by MikeHLG
Old Mar 03, 2014, 01:26 PM
DLGjunkyard is offline
Find More Posts by DLGjunkyard
Now fortified with carbon
DLGjunkyard's Avatar
Canada, ON, Cambridge
Joined Apr 2010
Welcome back Dirk.
4 in the pod has become quite common since your last build and rightly so.
You better get something going, that young man of yours should be about ready for some DLG action
DLGjunkyard is offline Find More Posts by DLGjunkyard
Old Mar 03, 2014, 01:39 PM
Used Registerer
TahoeDirk's Avatar
United States, CA
Joined Mar 2010
Should I just scour the build threads? Is there a preferred or common aileron/pushrod connection technique? Does the pod or just the access hatch need to be huge? Are pull/spring tails still cool? thanks guys
Old Mar 03, 2014, 01:58 PM
Joined Apr 2010
Yes, Pull strings are also pretty common.
One very cool method of keeping things clean with 4 in the pod is used on the snipe.
Kind of like a extended Taboo style pod with all the linkages for the wing within the pod
http://www.rcgroups.com/forums/showp...8&postcount=83
Old Mar 03, 2014, 02:20 PM
Used Registerer
TahoeDirk's Avatar
United States, CA
Joined Mar 2010
Great, thanks Jeff, I guess I'll study up.
My 8yr old Storm is flying a nearly indestructible foamy now, he and my girlfriend are just getting the hang of a rudder.
Problem is I can barely keep myself with an operable DLG, I have too many bad, inverted, 3d foamy, simulator, antic/habits.
Your pod/fuses must be near perfect by now, huh
Old Mar 03, 2014, 02:42 PM
VintageFan is online now
Find More Posts by VintageFan
a.k.a Frank Campbell
Long Beach, CA, USA
Joined Jan 2007
The XXLite does it differently from the Snipe. The linkage is entirely inside the fuselage with an access hole on the bottom to get at the wing end of the linkage.
It's all in the XXLite build manual linked to in the first post of the XXLIte thread
http://www.rcgroups.com/forums/showthread.php?t=1531670
I've used both and the Snipe is a bit easier to deal with but both work fine.
Frank C
VintageFan is online now Find More Posts by VintageFan
Old Mar 03, 2014, 02:59 PM
G Norsworthy is offline
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, CA, San Jose
Joined Sep 2008
See my Skinny Pickle thread and the two Japanese threads referenced.
http://www.rcgroups.com/forums/showthread.php?t=1853766
My next step is a wider mold to hide the linkage inside, in process now.
G Norsworthy is offline Find More Posts by G Norsworthy
Old Mar 03, 2014, 03:02 PM
Used Registerer
TahoeDirk's Avatar
United States, CA
Joined Mar 2010
thanks Frank.
As I suspected, all these connections are different.
It seems like a lot of work to conceal the connection in the fuselage, I guess a little drag from the pushrods tucked in close to the pod can't be much worse than the top mount method that I have been using.
If I enlarge my hatch cover I think I can work it all out. I think I can ditch my 45g 3000mah 18650 battery/ballast too!
Old Mar 03, 2014, 03:24 PM
Used Registerer
TahoeDirk's Avatar
United States, CA
Joined Mar 2010
thanks G,
The Japanese is a bit tough for me, but I get the idea. The less skinny pickle is what I was thinking. I may just use what I have in my dlg junkyard and introduce my brain to the 4 in the pod and pull/spring tail concepts.
What lb test fishing line or beading wire do people use?
I appreciate the feedback. I am kind of alone in the dark up here, but it seems like I'm on track.
Old Mar 03, 2014, 03:34 PM
Long Beach, CA, USA
Joined Jan 2007
Originally Posted by TahoeDirk View Post
thanks Frank.
Yeah, the Karisma has the servos in the pod and it just pokes the aileron pushrods outside. Works fine too.
Old Mar 03, 2014, 04:33 PM
Thermaln2 is online now
Find More Posts by Thermaln2
Transplant Chey WY from Reno
Thermaln2's Avatar
Reno Nevada
Joined Oct 2007
A local put the Karisma Wing on a XXlite fuselage and everything is inside. A fiend now is flying it down in Southern Cal.
It was originally flown up here near Reno and did great.
Chris
Thermaln2 is online now Find More Posts by Thermaln2
Old Mar 03, 2014, 06:08 PM
elkski is online now
Find More Posts by elkski
elkski's Avatar
United States, UT, Sandy
Joined May 2013
There is a thread about what beadalon wire folks are using. Many folks are sticking with pushrods. I like how 4 in the pod alleviates the need to cut out parts of the wing in the most critical root stress area.
elkski is online now Find More Posts by elkski
Old Mar 03, 2014, 10:26 PM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
4 in the pod is worth 2 in the wing??? ;-)
Airman74 is offline Find More Posts by Airman74
Old Mar 18, 2014, 05:11 PM
Used Registerer
TahoeDirk's Avatar
United States, CA
Joined Mar 2010
I did it, what a pain!! 273 grams ready to go with 900mah. The pull /spring set up was surprisingly easy . Cramming 4 servo in a tiny space and making the arms avoid each other was very tedious and difficult. I'm not very proud of my aileron linkage either, but I did it. Time to fly
For Sale Repost: Selling pods, E-pods, booms and V-mounts. All pods are 2.4 GHz friendly. ClmPro Aircraft - Sailplanes (FS/W) 0 Feb 02, 2014 06:54 AM
For Sale Repost: Selling pods, E-pods, booms and V-mounts. All pods are 2.4 GHz friendly. ClmPro Aircraft - Sailplanes (FS/W) 0 Jan 25, 2014 09:57 AM
For Sale Repost: Selling pods, E-pods, booms and V-mounts. All pods are 2.4 GHz friendly. ClmPro Aircraft - Sailplanes (FS/W) 0 Jan 19, 2014 05:35 AM
For Sale Selling pods, E-pods, booms and V-mounts. All pods are 2.4 GHz friendly. ClmPro Aircraft - Sailplanes (FS/W) 0 Jan 11, 2014 09:01 AM
For Sale 15% off on Composite Pods and E-Pods, 20% off for fuselage pod sets ClmPro Aircraft - Sailplanes (FS/W) 0 Sep 24, 2013 09:45 AM
