Old Mar 16, 2016, 08:40 PM
flatus antiquus is offline
Find More Posts by flatus antiquus
Yep - that's what it means.
flatus antiquus's Avatar
United States, WA, Parkland
Joined Feb 2015
your reeka
That hobby king 600 that that had a flybarectomy flew today. This is the first time it went through an entire battery nonstop (actually two). All it did was hover first flight, and then a little slow side to side stuff on the second one.
Thank you jetplaneflyer, atomic skull and 2doggs for the help.
flatus antiquus is offline Find More Posts by flatus antiquus
Old Mar 16, 2016, 11:40 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
Did you ever get the problem with the washout arms solved? FYI there should be no problem with putting a small 3x4.5x0.5mm washer on the outside of the arm between the screw head and the bearing.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Mar 17, 2016, 11:42 AM
Joined Feb 2015
I just put put blue loctite on 'em, tightened to where it just started to bind then backed off and let it sit for a day to cure.
Old Mar 17, 2016, 11:45 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Great that it's flying. Was the tail hold ok, none of the slow rotation you experienced before?
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Mar 17, 2016, 01:56 PM
Joined Feb 2015
Tail was great. I still don't trust it, a few wind gusts made it drift a little left and scared me but it came right back on it's own.
Cyclic was a bit more sensitive than I'm used to - turned down agility for the second flight and it feels better.
It is a bit intimidating.
Old Mar 17, 2016, 05:27 PM
Aberdeen
Joined Mar 2006
The tail should be locked solid, so probably you need to increase the tail gain.
The great thing about FBL is you can adjust the responsiveness as easily as moving a slider in the software, so you can quickly have the heli responding exactly how you like it.
New Product KiCad on Umbuntu your FREE eltronic design solution for making your own electronic treehog Life, The Universe, and Politics 0 Aug 02, 2015 06:06 AM
Discussion What's your DC source for your charger? SlowJeff Batteries and Chargers 40 Jul 23, 2015 03:20 PM
Discussion Your quadcopter rankings or ratings of your collection. ttakata73 Mini Multirotors 1 Jul 15, 2015 09:31 AM
Discussion Your employer helping you with your health plan? UlteriorModem Life, The Universe, and Politics 94 Jul 04, 2015 01:25 PM
