Old Jun 15, 2015, 08:43 PM
FreakonFlight is offline
Find More Posts by FreakonFlight
Joined Jun 2015
Programs or ways to Scale up and Print Plans???
Hey i'm just wondering if there is an easy way to scale up and print plans easily all cut up on multiple pages. I want to create a prop and slot F9F-2 Panther with these plans I found but the only way of doing this that I have found is by using visi and going around the plane but that takes hours. these are the plans I want to print.
http://www.hippocketaeronautics.com/...her_-_rev1.jpg
FreakonFlight is offline Find More Posts by FreakonFlight
Old Jun 15, 2015, 09:03 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
You could try this : print the plans on your home printer , take that to FedEx Office and ask them to scan it , scale it up to ??? , and then print it on their large format printer . The last time I did that it cost me about $8 .
balsa or carbon is offline Find More Posts by balsa or carbon
Old Jun 16, 2015, 06:39 AM
ec121connie is offline
Find More Posts by ec121connie
CG =Airplanes .. COG's = Gears
United States, CA, Sacramento
Joined Dec 2005
There are a few free programs out there that may help you when manipulating bit map graphics like jpegs.
GIMP is one my neighbor uses ... Give it a try.
https://en.wikipedia.org/wiki/GIMP_2.6.2
ec121connie is offline Find More Posts by ec121connie
Old Jun 16, 2015, 07:25 AM
Mac50L is offline
Find More Posts by Mac50L
New Zealand, Canterbury, Rolleston
Joined Oct 2011
What about dropping the picture into a page in Word(?) or LibreOffice Write. Drag a corner of the picture to size it to fill the page. Tell it the page size is A3, (or bigger?) turn it into a PDF and take it to the nearest printer with an A3 size printer.
NOTE - if using Write, hold the shift key down while dragging a corner of the picture to keep the aspect ration the same as you drag.
Mac50L is offline Find More Posts by Mac50L
Old Jun 16, 2015, 07:39 AM
PaulB is offline
Find More Posts by PaulB
Mike's Ma Maaaaaaaaan
Paderborn DE
Somewhere somebody (Dave Reap???) explained how to do this in Sketchup. As I remember you just open the drawing using Skechup, pick any line or draw a line from, for example, wing root to wing tip and enter the required dimension. The program then asks if you want the whole thing resizing.
Sorry that I canít find a link or be more precise but a few minutes searching the Sketchup threads should tell you all you need.
Paul
PaulB is offline Find More Posts by PaulB
Old Jun 16, 2015, 08:04 AM
PaulB is offline
Paderborn DE
http://www.rcgroups.com/forums/showthread.php?t=920416
Old Jun 16, 2015, 08:29 AM
Dave Barrow is online now
Find More Posts by Dave Barrow
Dave Barrow's Avatar
United States, KY, Covington
Joined Feb 2003
I use a free program called Tile Print. You can print plans tiled at any size you set.
http://softadvice.informer.com/Tile_Print_Software.html
Dave Barrow is online now Find More Posts by Dave Barrow
Old Jun 16, 2015, 10:56 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
FREE Adobe Reader: Scales, tiles and prints PDF's .. Easily.
Lotsa freebie Image to PDF converters about If that' s a stumbling block.
Bare is offline Find More Posts by Bare
Old Jun 16, 2015, 12:30 PM
sconnie is offline
Find More Posts by sconnie
a random dude
sconnie's Avatar
Joined Nov 2014
Hopefully, you have a higher res copy of that as it's a pretty small image, I'm seeing 280x198 - that's not a lot of resolution to work with. It seems to me, if you scale that up, even after converting to .pdf, there will be lots of pixelation. Unless you can convert it to vector somehow, then you're good in a .pdf viewer to print at whatever size.
The other thing to watch out for is that the horizontal stab and fuse look to have slots that are designed to be the thickness of whatever foam this is designed for and if you scale up those slots, they're going to be too big when you go to put the parts together.
sconnie is offline Find More Posts by sconnie
Old Jun 16, 2015, 12:55 PM
Joined Jun 2015
Yea I downloaded a higher res image somewhere but it was a pdf download so there was no way of showing it
Old Jun 16, 2015, 01:05 PM
potshot is online now
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Hey i'm just wondering if there is an easy way to scale up and print plans easily all cut up on multiple pages...
I downloaded that file and it's already a PDF and that's the easy method right there. From tip to tail on the top left view it measures 10.7" and the wing half shown spans 5.8". Give me the final measurement you want for either one of those items and I'll post a tiled PDF for you. The process is simply printing it to a new PDF with Adobe Reader and applying the scale factor at that time.
potshot is online now Find More Posts by potshot
Old Jun 16, 2015, 04:17 PM
basicguy is offline
Find More Posts by basicguy
Dream it...Build it...Fly it!
basicguy's Avatar
United States, MO, Macon County
Joined Dec 2014
Running Linux here.
I have imported pdf files into GIMP.
Go to Image/Guides and create guide lines.
Then go to Image/Guillotine and by running that command, it makes a page per section. You can print pages to fine tune the scale or what ever size you want.
basicguy is offline Find More Posts by basicguy
Old Jun 16, 2015, 07:27 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
http://www.pdfill.com/
birdofplay is offline Find More Posts by birdofplay
Old Jun 18, 2015, 06:36 AM
Sixter is offline
Find More Posts by Sixter
Flying Models for 52 Years!
Sixter's Avatar
Georgia, United States
Joined Oct 2002
MS Paint will Resize and Tile your plan.
Sixter is offline Find More Posts by Sixter
Old Jun 28, 2015, 03:05 PM
low flying cat is offline
Find More Posts by low flying cat
Joined Jul 2014
Here is an alternative suggestion. I have a projector at work. I project the full sheet plan to the size I want and draw straight onto the material. This allows me to view the project at size before committing to build. Actually, I tend to make dots on corners and join them with a straight edge. Not perfect as projected lines become thicker when enlarged, but works well enough. It is now possible to buy cheap projectors for gaming and home cinema use. Has anyone any experience of these?
low flying cat is offline Find More Posts by low flying cat
Sold Plans, Plans, Plans, Plans, and More Plans! Scale, Classics, Pattern, & More! stevster Aircraft - General - Miscellaneous (FS/W) 13 Jun 08, 2016 07:24 PM
Discussion wanted concept 1/4 scale Fleet biplane kit or plans Jon Thompson Scale Fuel Planes 17 Oct 26, 2015 10:11 PM
Help! Seeking P/F 82 plans .46 size or up Scrtchbuildr6 The Builders Workshop 2 May 11, 2015 05:08 PM
Discussion seeking F/P 82 plans .46 size or up Scrtchbuildr6 Balsa Builders 5 May 11, 2015 05:01 PM
For Sale Plans, Plans, Plans, Plans, and More Plans! Scale, Classics, Pattern, & More! stevster Aircraft - Fuel - Airplanes (FS/W) 0 Apr 29, 2015 06:12 PM
