Old Dec 06, 2014, 06:21 PM
Fly and let Fly!
Cocg's Avatar
United States, CO, Grand Junction
Joined May 2010
Shasta.. Mixes are good.. Back off on it a little.. Like education.. Just the power of knowledge..
And .. Love the dog..!! ..And.. Great wet ground, no obtrusive background photo.. !!
Cocg is offline Find More Posts by Cocg
Old Dec 07, 2014, 11:00 AM
shastamike's Avatar
United States, CA, Mt Shasta
Joined Jun 2010
Ya...I reset for today and hope to fly between rain showers. I measured the flap to elev. movement but on the TX it was a pretty big number in the mix.
I like your appreciation of un-obtrusive backgrounds. Backgrounds are a big part of composition for me. Usually for background we have a 14,000ft. volcano. What I want to learn is how to take RC plane photos that make the model look real, but I"m too busy flying!
The pilot and co are cartoon characters, Tintin and Snowy. I build all my pilots myself.
shastamike is offline Find More Posts by shastamike
Old Dec 07, 2014, 12:04 PM
Fly and let Fly!
Cocg's Avatar
Joined May 2010
"Build" the pilots?
Like carve from balsa or so?
Old Dec 08, 2014, 11:12 AM
shastamike's Avatar
Joined Jun 2010
"Build" the pilots?
I make them from modeling clay. "Sculpy" to be precise. To save weight and give me a frame as my pilots are cartoon characters with thin necks, I start with aluminum foil. I twist it into the basic shape and then start pinching clay onto it. The clay is actually about 1/4 in. thick. When done the sculpy goes in the oven at 275 degrees for 15 mins. and it's as hard as a rock.
I'm no artist by any means. I print out the charater off the Internet to size and start with that. I'm a ski bum here in N. Cal. and we haven't had any snow. Last year our ski area never even opened. Lots of spare time.
Old Dec 08, 2014, 11:45 AM
Fly and let Fly!
Cocg's Avatar
Joined May 2010
Well... Cool..!!!
Old Dec 16, 2014, 11:46 AM
Iflyrc_vic's Avatar
USA
Joined Dec 2004
I would consider putting some pilot figures in my plane but unfortunately, the windows are in and the cabin is inaccessible. I could take out the lightly tacked in window but its not worth the effort.
Got a break in the weather and took the Piper out for a few flights yesterday. With calm winds (less than 5 mph) she flew just great. With my power system, she will do rolls and loops if desired. Its just great looking in bright sunlight. The red color really pops.
I programmed in some elevator flap mixing that worked pretty good to minimize ballooning. Although you can slow this pane down to a crawl for landing, that stiff landing gear produces a bounce - nearly impossible to grease a landing..
Iflyrc_vic is offline Find More Posts by Iflyrc_vic
Old Dec 17, 2014, 01:32 AM
shastamike's Avatar
Joined Jun 2010
I'm big on pilots. Some of my planes with clear bubble canopies look weird to me without a pilot. They do add weight and on this Pacer they are behind the CG which is not good the way this plane balances out IMO.
I got to fly for about 3 minutes when the sun came out, and yes the red really pops. It was like a whole new looking plane. The first few flights have been in such dark, stormy weather. Nice for me as I put a lot of time into the nav. lights on the plane and they really look great on the taxi and landing. Not going to be that great in the bright summer, but I can switch them off.
The plane is really stiff on landing and yes greasing a landing will be challenging, but I'm up to it. A perfect landing is something I try and practice for.
Old Dec 17, 2014, 06:09 AM
Iflyrc_vic's Avatar
USA
Joined Dec 2004
Great photos Mike! Looks like a full scale. I like to grease my landings as well so I will be doing a lot of practice to get this one right. It is definitely a head turner at the field. Everyone likes it. It is a great looking little plane.
I was a little concerned about the 2200mah battery but I got in nearly 10 minutes with some aerobatics and only used 900mah.
Old Dec 17, 2014, 06:26 PM
shastamike's Avatar
Joined Jun 2010
Ya...I went with an 1800mAH batt as I like to fly slow and the landings seem a little easier for now with less weight. I think my timer is set for about 10 mins. even with the 1800mAH. I haven' t gotten in enough flights to get the time set.
Looking forward to that first "perfect landing". I mostly do "the walk of shame" after the plane ground loops off the tarmac to retrieve the plane. Out of 6 landings I've only had one straight and maybe 3 that looped but stayed on the tarmac. She's a tough one.
Old Jan 03, 2015, 11:02 PM
Joined Nov 2013
A great of majority of the linkages, cleaves-es, in this kit as well as the straps for the wheel mounts etc. Are simply none compatible they simply fall off I had to glue mine in place. I also had to make all of servo arm holes bigger, as well as the holes in the control horn. However, it is great flying model. If you let the plane get up to speed take offs seem fine.
ell198679 is offline Find More Posts by ell198679
Old Jan 04, 2015, 11:42 AM
Gil Weiss's Avatar
Bensalem, PA.
Joined Sep 2001
I have just completed, what appears to be, a later version of this model. The manual is dated 2013 and the CG info in the manual is the correct updated version. My struts were long enough and most of the hardware worked OK.
I have been building models for 30+ years so it was not a big deal for me to correct the few minor issues. Overall this model is beautiful and the detailed instructions, including the exact pushrod lengths and control horn setups were great.
That being said, a newbie could get into trouble if an experienced RC'er didn't preflight this aircraft. My two biggest issues were designing a suitable battery tray to facilitate inserting and removing a 2200 mah 3C battery as far forward as possible and installing two pilot figures along with the windows and windshield.
My aircraft turned out well and I'll post some pics soon.
Gil Weiss is offline Find More Posts by Gil Weiss
Old Jan 04, 2015, 11:45 AM
Fly and let Fly!
Cocg's Avatar
Joined May 2010
As a presumed "later version".. Where did you purchase yours from... IE Fresher inventory perhaps.. Like fruit.!!
Old Jan 05, 2015, 09:34 AM
Gil Weiss's Avatar
Bensalem, PA.
Joined Sep 2001
LHS, the Recreation Depot in mount Holly, NJ.
Purchased in October, 2014.
Sold E-Flite Ultimate 20-300 10e Long Island Local Pickup Only LICobra Aircraft - Electric - Airplanes (FS/W) 5 Apr 06, 2013 06:24 AM
Sold Stearman PT-17 15e ARF by E-flite Local in Philadelphia,PA Big Fran Aircraft - Electric - Airplanes (FS/W) 0 Jan 17, 2011 03:49 PM
Sold NIB E-Flite Ultimate 20-300 10e ARF plus electronics tsever00 Aircraft - Electric - Airplanes (FS/W) 6 Mar 28, 2009 11:11 PM
Discussion E-flite Ultimate 20-300 10e ARF Gonzo007 3D Flying 2 Apr 02, 2008 11:31 PM
