Old Aug 14, 2013, 06:50 AM
rimshotcopter's Avatar
Joined Aug 2009
It's even possible to make a stable bicopter without using gyroscopic precession, if you understand the forces involved.
Ha!! that is called an FAAT Bicopter that does not use the gyroscopic force of the spinning props. aka Mollie II
http://bicopter-forum.forumchitchat.com/?forum=211298
So what's next on your agenda?
rimshotcopter is offline Find More Posts by rimshotcopter
Old Aug 14, 2013, 01:16 PM
tazzmann's Avatar
United States, WA, Vancouver
Joined Jun 2013
Originally Posted by rimshotcopter View Post
yea, it can get somewhat confusing because the define servo number is off by 1 in the servo array. Servo[4] is SERVO_5 etc.
I know this is a older post, but I didn't see a response to this anomaly. In short, in most programming languages array's are zero based (i.e. the first item in the array is item zero: item[0]), so when looking at code like this that has an array, just keep this in mind and it will all be ok. This is normal and not an error.
tazzmann is offline Find More Posts by tazzmann
Old Aug 16, 2013, 04:24 AM
RCvertt's Avatar
Joined Aug 2007
Originally Posted by tazzmann View Post
...This is normal and not an error.
If (#define SERVO_1_PINMODE) in one file relates to servo[0] in another file, it seams less confusing to name it (#define SERVO_0_PINMODE) instead.
A relatively small inconvenience though.
RCvertt is offline Find More Posts by RCvertt
Old Aug 16, 2013, 10:07 AM
tazzmann's Avatar
Joined Jun 2013
THAT part is true and is a programmers poor choice of naming convention, but the servo[0] is normal for an array. As a programmer of 7 different programming languages, it has always been a sore point for me to have zero based arrays, but have everything else 1 based. It can get confusing in more complicated code.
Old Aug 16, 2013, 10:18 AM
Joined Aug 2009
And that was my initial point. Wow.
Old Aug 16, 2013, 11:03 AM
tazzmann's Avatar
Joined Jun 2013
That's cool, I just wanted folks who don't know to understand that the array's are zero based instead of one based, that THAT part was not in error, and that is something the programmer couldn't control. His naming convention is another story however. The post I was referring to in my quote above made is sound like the array numbering was off and not the naming convention so I was trying to clarify. Wasn't trying to offend, just offer an expanation to those who don't know.
Old Aug 16, 2013, 01:06 PM
RCvertt's Avatar
Joined Aug 2007
Good point with the clarification. Just another reason why I refer to code as a necessary evil.
I'm really happy with the stability of this aircraft. Still room for making it even more stable so don't change that dial.
Old Aug 17, 2013, 05:25 AM
onlyifamppowered's Avatar
brisbane
Joined Jul 2005
HI
I have been playing around with my first bicopter . Has anyone got one to fly on a kk2 board?
Rob
onlyifamppowered is online now Find More Posts by onlyifamppowered
Old Aug 17, 2013, 02:34 PM
RCvertt's Avatar
Joined Aug 2007
Hi. I have seen them on youtube but I don't own a kk board so I'm unable to help with the set up
Old Aug 17, 2013, 06:40 PM
brisbane
Joined Jul 2005
I have the beastie set up correct. Right motor layout loaded and the servos when tested directly to the Rx move freely with motors running however when running through the KK2 it does not move correctly.
I have re-flashed to try other firmware but no luck.
Is everyone here using multiwii?
I have a spare homebuilt wii fc spare..
Be nice to get the kk2 going as it's simple to make field adjustments....
Any one else got a thought?
Rob
Old Aug 20, 2013, 11:12 AM
CSU Chico, Flight Club
Test Pilot Mafia's Avatar
United States, CA, Chico
Joined Sep 2012
Rob
I have used both MW 1.7-2.2 and HK2 (with LCD) for Bicopter purposes, and would say that MW is preferred, as it has better options for making changes specific to bicopters but either could be used. (the Minsoo kim kk2 seemed worthless though with its 3 pots.)
Test Pilot Mafia is offline Find More Posts by Test Pilot Mafia
Sold **Sold**Avatar Style BiCopter - $125.00 shipped jkrause528 Aircraft - Electric - Multirotor (FS/W) 4 Jan 30, 2013 08:30 PM
Discussion scorpion gun ship sphericalone VTOLs 4 Jan 22, 2012 10:38 AM
Question Avatar Scorpion RDA Gunship MiniChopper4Me Coaxial Helicopters 82 Nov 22, 2011 02:03 PM
Discussion Avatar Scorpion Bill Bergman Foamies (Scratchbuilt) 11 Jun 24, 2010 09:00 AM
Build Log Avatar Scorpion Gosa77 Coaxial Helicopters 20 May 09, 2010 04:51 PM
