Old Oct 20, 2010, 07:54 PM
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Build Log
ASW 22 BL by Baudis
ITS HERE and it was worth the wait.
Thanks goes out to Bob and Annette at Soaring USA
This ship is amazing. The fit and finish is near perfect. The wing appears to be quite strong and the flex is very uniform. I don't think I'll have to worry about slapping wing tips. The retract unit opens and closes so easily I think I could get away with a HS 85 running it (I won't). The trailing edge is wider than I thought it would be from the pictures I looked at. The forward hinging canopy is nice and works great but will need some type of lock mechinism to hold it in the upright position. The nose is so pointy I may have to cut a slot in the bottom a half inch behind the nose for the tow hook release. The cockpit is sparce and has a stick on photograph of the instruments. My 1/5 scale pilot needs some clothes but I have all winter to get that done.
davidjensen is offline Find More Posts by davidjensen
Old Oct 20, 2010, 09:19 PM
Ranfred Radius's Avatar
Central Point, OR.
Joined May 2002
Sweeeet!!!
Ranfred Radius is offline Find More Posts by Ranfred Radius
Old Oct 21, 2010, 12:23 AM
Will fly for food
Bellevue WA,
Joined Dec 2003
This ship is advertised to be 176oz ready to fly. I just weighed the entire airframe at 125 oz. That gives me 50 oz for the 12 servos, wiring, batteries, radio, linkages and nose weight.
Old Oct 22, 2010, 07:55 AM
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
David,
So what exactly is there to build? Just kidding. It looks great!
Brian
cpdude is offline Find More Posts by cpdude
Old Oct 22, 2010, 08:37 AM
Central Point, OR.
Joined May 2002
David
Maybe you should have saved your money and instead bought a new wheelbarrow!
Randy
Old Oct 22, 2010, 09:02 AM
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
There's somthing very elegant about the 22. The fuselage styling is, IMO, much nicer than later, more rounded designs.
Best of luck and looking forward to the flying pics,
S
Shedofdread is offline Find More Posts by Shedofdread
Old Oct 22, 2010, 09:29 AM
Don't ask me anything...
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Originally Posted by shedofdread View Post
there's somthing very elegant about the 22. The fuselage styling is, imo, much nicer than later, more rounded designs.
S
+1!
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Oct 22, 2010, 09:30 AM
Joined Dec 2005
Originally Posted by rocketman47 View Post
David
Randy
....or, have the left side of his yard jacked up !
Old Oct 23, 2010, 02:05 PM
Will fly for food
Bellevue WA,
Joined Dec 2003
David
Randy
It's all a matter of prioities. Although I may use the wheelbarrow to jack up the left side of my back yard.
Old Oct 23, 2010, 05:20 PM
Central Point, OR.
Joined May 2002
Excellent idea! Thats what McGyver would do!
Back to the model.. Are you going to start putting it together or just admire it hanging from your ceiling?
Randy
Old Oct 23, 2010, 05:55 PM
Will fly for food
Bellevue WA,
Joined Dec 2003
I need to gather the 12 servos, receiver and the rest of the stuff needed. I should start on her right after the first of 2011. I have 2 ships to build/rebuild prior to the ASW
Old Oct 24, 2010, 07:26 PM
Joined Oct 2007
Hello David, Alex "the Schleppmeister" towed my Baudis ASW 22BL up into the blue skies of Pennsylvania yesterday. It was my second flight with it. This ia a thoroughbred! It flies fast and slow. It tracks cleanly and it is a fabulous image to behold, with its gorgeous wing plan. It does simple aerobatics well enough to encourage a little play on good thermal days. With speed, I was able to do a passable roll on those 5+ , thin meters. Building this baby was one of my more complex projects, partly because of my building habits, and partly for the the specific kit I received. My kit came with no instructions. Did you find the building and setup instructions on the Baudis site? http://www.baudismodel.com/asw22bl-technical-data.php
Götz Unger is offline Find More Posts by Götz Unger
Old Oct 24, 2010, 07:48 PM
Will fly for food
Bellevue WA,
Joined Dec 2003
Yes thanks. I've printed it several times. What servos did you use? I've just ordered 4 JR DS378 for the flaps and I'm going to try to get DS 368 in for the ailerons. I still don't know what I'll use for the elevator. I have an HS 82 that is slightly better than the spec'd HS 81.
Old Oct 25, 2010, 11:37 AM
Look out! The lever!
bobthenuke's Avatar
United States, AZ, Peoria
Joined Feb 2005
David,
I'm no expert but I'd most definately be putting a digital servo on the elevator. I've given up on HS-81's especially after ending up with a box of them that don't work or have stripped gears. Now, any analog servo I use for anything has to have metal gears.
-bob
bobthenuke is offline Find More Posts by bobthenuke
Old Oct 25, 2010, 11:50 AM
Joined Dec 2005
I'd agree, and go further and say that the 82 seems to have a poor reputation around here (a lot worse than the 81). I would really avoid it for such a nice ship, particularly for what is arguably the most critical control surface....
Wanted Astroflight asw-15, asw-17, Californian Thomas Cummings Aircraft - Sailplanes (FS/W) 2 Oct 19, 2010 08:25 PM
Gallery 1/2 scale asw 22 @ white sheet chris williams Scale Sailplanes 56 Oct 01, 2010 07:02 AM
Discussion Baudis ASW 22 davidjensen Scale Sailplanes 8 Oct 03, 2009 08:53 PM
Build Log ASW-22 BL from Icare Just for the Heck of it. :):):) jcstalls Scale Sailplanes 39 Jun 19, 2009 11:23 AM
Discussion 2.8 meter ASW-22 BL bobthenuke Sailplane Talk 6 Jan 05, 2007 02:42 PM
