Old Today, 12:44 AM
Joined Jan 2014
1.It is with more features:Charge, Discharge, Balance Charge, Form Charge, Storage Charge, Cycle Charge, Battery Monitor, as well as useful power supply for hot wire foam cutters, soldering irons and electric motor tune in.
2.It is NO.1 in safety:
Reverse polarity and short circuit cut off. Unique battery charger design with internal and external temperature cut off safety. Timer and capacity limit settings, as well as many more user set safety features.
3. It can display data on screen
Display Battery Voltage, Input Voltage, Current Draw, Capacity, as well as Per Cell Voltage and Resistance (in balance model). Make your decision based on exactly what is happening with the battery.
4.It contains PC connectivity
It is PC compatible for easy firmware upgrades, as well as integration with software for accurate analysis, comparison and trouble shooting of any battery.
And the following data is the main specification:
DC Input voltage range : 11~28V
Max charge power : 500w
Max discharge power : 40w
Max charge current : 20A
Max discharge current : 5A
Balance tolerance : +10mV
Max balance current : 300mA
Max lithium batteries "S" : 7
Max NiMH/NiCd "S" : 16
Max Pb "S" : 12
Firmware upgradable : Yes
Temp sensor : option
Internal resistance measuable
olivia zou is offline Find More Posts by olivia zou
Old Today, 02:29 AM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
I've reported the spam.
When will they learn? This just pisses people off, Olivia.
Particularly since you can buy the highly regarded, well proven, and better specified Hyperion 730 NET for a lot less money.
jj604 is online now Find More Posts by jj604
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
