Old Today, 09:41 AM
In Training
Joined Oct 2014
Originally Posted by GuessWh0oo View Post
I've got some spare motors just for a couple of bucks from Ebay, works fine. You should look @ the size of the shafts, some have longer shafts..(I need/want the shorter ones).
So wouldn't be bad if you got some laying around for that price
You could upgrade motors from micro
They are fast! but will cost you some bucks. And you'll be needing a other board, thought stock board couldn't handle these motors..(but not sure)
Hey GuessWh0oo; LOL that kills me... sarasota FL here.. I read changing out the board can also let you bind to a differnt radio giving better control.. once i get some experianced built up I wanna try the Micro motors with the new board and radio.. there is a single prop flight area near me that i want to visit and see if they chase me off... flying in the neighborhood hear is getting risky with all the trees,,
Does the short or long shaft of the motors affect flight or just a personal preference?
Ive noticed when i go expert mode and full throttle forward that i have to spin her around 180 and full throttle to stop her.. pulling back kinda works but but shoots me up higher altitude...
DarkAngel74 is online now Find More Posts by DarkAngel74
Old Today, 10:37 AM
Joined May 2009
Has anyone managed a double flip? I have no idea how this even happened, I was trying to do a normal flip. Instead of dropping down, as it usually does after a flip, it instead went higher up and performed a second flip.
See here, at 1:55:
http://youtu.be/zP4O73pZ4wI?list=UUc...OPpm_oSYooF8_Q
Arakon is offline Find More Posts by Arakon
Old Today, 11:19 AM
The Netherlands, FL
Joined Aug 2014
Haha, GuessWhat.. They will hunt and chase you
It doesn't affect flight, but the shorter ones keeps the motor in better condition. If you will land on the props, and you got a longer shaft it will be pushed inside. If you got shorter shaft it won't hit that hard because of the prop is pushed against the motor shell(sorry if there's some bad English).
And some after marked Hubsan have got other frames so they would need a longer shaft to fit.
That's odd, don't know what the issue is there.. Maybe one of the motors is bad and turn her around because lack of power and can't compete with the good motors..
GuessWh0oo is offline Find More Posts by GuessWh0oo
Old Today, 11:22 AM
The Netherlands, FL
Joined Aug 2014
See here, at 1:55:
I know if I hold flip button on one of my quads it will make flips(downwards) continuously
Old Today, 03:30 PM
Joined Aug 2014
Oké! Maybe considering to buy them my mistake thx!
The one to ask more questions is Link69. I know he hangs out in this thread.
http://www.rcgroups.com/forums/showt...42561&page=282
He uses 8.5mm motors on his roll your own frame with Hubsan boards. He even experimented with two stock motors per connection (making a hexcopter) with the Hubsan stock board and it even handled that.
BillW50 is offline Find More Posts by BillW50
Old Today, 03:39 PM
Joined Aug 2014
Changed the props though they didn't look bad, but if they get a small nick or the tip goes flat i reshape with a smooth emory board, .. was making due till extras arrive.. maybe i messed it up b rinning like that cause it still has a noticeable noise when lightly flicked and if i hold the housing of the motor and spin it i feel a little "tick" for lack of a better word.. gonna try some dry lubricant, ive hit wet grass a few times(just shooting blind on that one)
Nice to know about bad video recorde on the FPV was gonna, could the C HDcam be replaced with the FPV cam... Making the FPV a HD video? Could order a replacement and switch it if they are compatible.. (again shooting blind)..
Whats the farthest you have gone with your FPV, they still only fly about 7-10 min yeah?
Oh that is what my bad motor did, tick. I dunno, but I don't know if that is fixable.
Well trying to merge a C with a D... that isn't very doable. You are better off having both and using them for what they do best. Or wait until mid-December and maybe this one would be much better. Estes and Hubsan are very compatible with each other controllers.
http://www.towerhobbies.com/products.../este4716.html
There is a thread started for this one at:
http://www.rcgroups.com/forums/showthread.php?t=2260014
Old Today, 03:43 PM
Joined Aug 2014
As for max range... well I haven't tested this very much yet since I didn't plan on going far yet. But I do have the Hubsan SpyHawk transmitter which adds far more range for the D. Most reports the range is at least 3 times over the stock D transmitter (usually 100M max for the D).
Old Today, 03:45 PM
Joined Aug 2014
Flight time for the D is less. Heavier and larger motors and it has a cam and that video transmitter to power. So I usually get 6 minutes with those 500mah batteries.
Old Today, 03:47 PM
Joined Oct 2014
Which Hubsan X4 model
Hey Guys,
Last week I bought myself my first quadcopter, the X4.
The first upgrade I'd like to get is a protection cover. I noticed there are different models for the cover, such as the a-12, and a-19. I'd like to know how to identify which set to buy.
On the package it says I have the new controller.
Also, where would someone recommend buying these parts in Canada?
Cheers!
Any tips for a beginner x4 flying welcomed!
arazumien is offline Find More Posts by arazumien
Old Today, 04:03 PM
Joined Aug 2014
Originally Posted by arazumien View Post
Hey Guys,
Welcome to the world of X4! For the protector, check the box carefully. As sometimes there is one taped under the package tray. If there isn't one, you need the one for the L model. Yours is the V2 L model if that makes a difference.
Old Today, 04:46 PM
Joined Oct 2014
Thanks! I checked under the package tray - no luck. I think I will order a set from AliExpress. Cheers!
Old Today, 05:02 PM
The Netherlands, FL
Joined Aug 2014
107c is copter with camera
Discussion The Hubsan X4 youxif Multirotor Talk 62 Today 02:08 PM
Discussion Hubsan x4 6axis scousethief Mini Multirotors 295 Jun 21, 2013 07:22 AM
Discussion Hubsan X4 Mini Quad dc9guy Mini Multirotors 32 Feb 04, 2013 10:14 PM
Discussion Hitec X4-80 eighty 4 port chager review search Timewarp Batteries and Chargers 4 Jun 22, 2012 04:20 PM
