Old Mar 30, 2013, 10:00 AM
TheTick is offline
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
Energic Build Thread.. Added speed passes on radar
Hi Guys,
I've been ready for a new project so I stopped by SUSA to see what Bob had these days. Kinda had something big in mind, but was open to anything f5b size as well. Turns out he had way too much for my indecisive self to choose from.
Shout out to Gary for spending hours answering my questions and listening to me talk to myself as I try to figure out what I wanted. He is a very patient man. Thanks Gary!
Ended up with the Energic. The fit and finish is top notch. I've already started the build and will post pics of my progress. Will report back soon.
TheTick is offline Find More Posts by TheTick
Old Mar 30, 2013, 02:43 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
Motor mount glued in with JB weld.
Old Mar 30, 2013, 05:56 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
Just posted this pic in my thread about soldering directly to the board. My solder did not flow well with whatever solder castle used, but it seems to be pretty solid. Will make sure to test the hell out of it before maiden.
Old Mar 30, 2013, 11:29 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
5 min epoxy for control horns. I really like the full fairings.
Old Mar 30, 2013, 11:33 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
The supplied servo mounts fit the MKS servo's nicely. Had to sand them a bit thinner to make the servo sit flush against the wing when mounting. A bit of grease on the servo arms makes it easier to install and remove the clevis when dry fitting.
Old Mar 30, 2013, 11:37 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
The servo bay is nice and big. 5 min epoxy for servo mounts.
Old Mar 31, 2013, 12:37 AM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
Anyone with a Futaba 10C flying throttle on a switch? I was hoping to use my 7 ch rx and just realized the aux channel is only available on channel 6 which I need for flaps. I'm using parameter 2 ail and 2 flap. In this mode, it will only let me assign a switch to channel 6
Old Apr 07, 2013, 07:47 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
Kit came with a nice pushrod for the elevator. Needs to be mounted very low on the servo arm to fit in the tail.
Old Apr 07, 2013, 08:28 PM
Dbox is online now
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Originally Posted by TheTick View Post
Kit came with a nice pushrod for the elevator. .
I bet I know what they are in a former life.
Energycless Yuri.
Dbox is online now Find More Posts by Dbox
Old Apr 07, 2013, 08:51 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
Energycless Yuri.
LOL.. thats brilliant!
Old Apr 08, 2013, 10:45 AM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
So this hole should be plenty for cooling, but it was really helpful when installing the rx and eneloops. I'm normally against using switches of any type, but I've had good luck with these in my sailplanes with eneloops. Makes it so much easier to charge.
I initially planned on using a 2s A123 1100 mah rx pack, but I was told that these MKS servo's do not like 6+V. I've read a lot of good things about MKS so I decided to go with a 4s AA eneloop pack and avoid a regulator. The eneloops pack weighs slightly more than my A123, but they are both pretty heavy compared to a small 2s lipo and regulator. I figured it wouldn't make too much difference in a plane this size.
Old Apr 08, 2013, 10:48 AM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
So what do you guys use for battery stops? I ended up inserting this small carbon rod. I'll shave it flush with the fuse, but I should have asked before drilling into the fuse. There probably is a better way.
Old Apr 20, 2013, 03:11 PM
TheTick is offline
Spoooooon!
TheTick's Avatar
Joined May 2003
Not a whole lot of interest in this thread so I focused on finishing and getting it in the air. Please feel free to ask any questions about the build. It was very straight forward.
Getting around 5700 watts with 1512 2.5D on 10S 2200 18x23. Have about 5 flights getting more aggressive on the throttle each flight and everything stays cool including the 30C Turnigy packs. My questionable soldering job on the controller is holding up fine so far.
Got a couple speed runs on radar. My buddy had a hard time filming at the same time, but we got some good numbers. Does a solid 185-190mph level. I'll try to get a better flight video now that I'm confident she'll hold together. Got 205 mph out of a mild dive with zero flutter.
Energic High Performance Motor Glider (1 min 39 sec)
Old Apr 20, 2013, 04:07 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Nice work, looks and sounds awesome
jackosmeister is online now Find More Posts by jackosmeister
Old Apr 21, 2013, 12:42 AM
Dbox is online now
Dbox's Avatar
Joined Jun 2005
What is AWU?
Thanx.
Yuri
Build Log DTV Devastator - Quick Build thread chip.greely Slope 17 Jun 27, 2013 09:26 PM
Build Log titan build thread micro pusher dr rc Pusher Prop Jet Models 11 Apr 11, 2013 03:53 PM
Discussion VA Models Katana from EPPhobby Build Thread airbagit13 3D Foamies 60 Feb 18, 2013 03:31 PM
Build Log Build Thread or not to Build Thread? - Redback malachite Slope 35 Feb 28, 2006 12:12 AM
