Old Jan 23, 2015, 02:16 PM
Just your average 3D pilot
RCmaster823's Avatar
United States, AZ, Scottsdale
Joined Jan 2015
Careful!
Programming the Sukhoi SU-29MM
Hey all,
This is my first thread post, I joined earlier today.
But what I really wanted dot talk about was that if you are buying a new Parkzone Sukhoi SU-29MM, it is IMPERATIVE that you read ALL the programming instructions for the SAFE technology, especially if you have a DX6i transmitter. If you don't follow all the directions EXACTLY as described, the plane will be unflyable. I wish that the AR636 receiver would have a little more leeway regarding programming, but oh well, what're ya gonna do. If you didn't read the manual, I'll just put how to program the SAFE flight modes here. This is for DX6i users. Anyway, I have about 3 flights on my Sukhoi, and it's quite the plane. Parks one really outdid themselves this time around, but they could have used a different receiver.
Step 1: Reverse the gear channel.
Step 2: Go to Adjust List Menu and go to Travel Adjust.
Step 3: Set Gear/F mode (switch position 0) to up 100%.
Step 4: Set Gear/F mode (switch position 1) to down 40%.
Step 5: Go to flaps and and set the normal position to 100%. Then set the landing position to down 100%.
Step 6: Go to Mix 1 and set it to ACT; Go to Gear and set it to Gear ACT, set Rate D 0% U, + 100%, SW Mix, Trim INH
And you're done. The Gear and Mix switches now operate the SAFE modes and the Flap switch operates Panic Recovery. Hope this helps. All in all, The Sukhoi SU-29MM is a pretty good plane, but programming is a pain.
See ya!
RCmaster823 is offline Find More Posts by RCmaster823
Old Jan 23, 2015, 09:12 PM
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
Welcome Rcmaster to Rcg
This is a very big site and your Suki has its own thread of 300+ pages. I bet your info is in there and if not you should add it to the thread. Happy flyin.
mcnowhere is offline Find More Posts by mcnowhere
Old Jan 23, 2015, 09:49 PM
Joined Jan 2015
Thanks for the reply.
Alright, I will post it to that thread. Thank you!
For Sale PARKZONE SUKHOI SU-29MM PKZ8050 with 2 batteries new2hobbybarn Aircraft - Electric - Airplanes (FS/W) 1 Jan 23, 2015 02:42 PM
Sold Parkzone sukhoi su-29mm pkz8050 with 2 batteries new2hobbybarn Aircraft - General - Miscellaneous (FS/W) 0 Oct 30, 2014 07:45 AM
Question Sukhoi SU-29MM with SAFE technology tomer568 Electric Plane Talk 2 Oct 17, 2014 06:28 PM
Help! Sukhoi SU-29MM tomer568 Parkflyers 1 Oct 17, 2014 05:58 PM
Sold Parkzone Sukhoi SU-29mm with SAFE -BNF. Stuart,FL 34997 wilanz Aircraft - Electric - Airplanes (FS/W) 2 Sep 26, 2014 09:11 AM
