Old May 09, 2015, 12:57 AM
magrinsi is online now
Find More Posts by magrinsi
magrinsi's Avatar
Florence Italy
Joined Dec 2009
Kontronic kpg oil
I have see that in the kpg 27 there is a oil like standard..but what kind of oil is this?
Grease is better or not?
magrinsi is online now Find More Posts by magrinsi
Old May 09, 2015, 01:01 PM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, WA, Redmond
Joined Dec 2007
You need high velocity grease, not oil. Does your kpg27 have plastic race holding the needle bearings?
la528it is offline Find More Posts by la528it
Old May 09, 2015, 02:52 PM
Christian Lucas is online now
Find More Posts by Christian Lucas
Germany, BY, Gräfelfing
Joined Jan 2003
Hi,
one of the best gears in Germany come from Andy Reisenauer. One part of his succses is the geargrease. You need only very less and most modeler have never service there gear for a second time as it stay real long . For competition you will find no better grease.
http://www.reisenauer.de/artikeldeta...1577&sprache=2 .
Christian Lucas is online now Find More Posts by Christian Lucas
Old May 10, 2015, 02:23 AM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
But i not understand because kontronic use in kpg gear only oil?
I think that if grease will be better for kontronic not is expensive add a bit of grease in his gearbox...
Old May 10, 2015, 09:27 AM
Joined Jan 2003
How old is your gear and is there real oil . i have 3 kpg 27 gear and every gear has grease for lubrication . For oil you need a simmerring or spezial ballbearing to get it seal .
Old May 10, 2015, 11:18 AM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
I have one kpg27 4,2:1 lubed with isoflex grease ( with 50-60 fly) and a new kpg 27 5,2:1 and a reading kontronic instruction i ask myself if a specific oil like this used of default from kontronic instruction is better to hi rpm..
Sold Kontronic Kira with gearbox seng30904 Aircraft - Electric - Power Systems (FS/W) 0 Feb 26, 2015 12:06 PM
Wanted kontronik kpg 5:2:1 XtremeWingRC Aircraft - Electric - Power Systems (FS/W) 0 Mar 27, 2014 09:48 PM
Kontronik gear system model KPG-25 marcv Aircraft - Electric - Power Systems (FS/W) 0 Mar 03, 2014 07:49 AM
Wanted I need a kpg 25 or 26 gearbox for Kontronic fabmaster911 Aircraft - Electric - Power Systems (FS/W) 6 Jul 25, 2011 11:07 PM
