Old Oct 06, 2011, 01:59 AM
Kazu-kaku is offline
Find More Posts by Kazu-kaku
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Kestrel 17-1 for Acrobatic Flight
Kestrel 17 with membrane wing : New Ornithopter in making.
Pterosaur type ornithopter (Dsungaripterus 5-7v ) will be changed to Bird type ornithopter.
I am happy if it does an acrobatic flight.
wing span about 90cm
weight <130g
The body of this ornithpter is same as Dsungaripterus 5-7.
Receiver: Corona 4Ch Single Conv. Rx 72MHz
Servo: Vtail: elevator & rudder (DM 4.7g servo *2)
Motor:Turnigy 1811 Brushless Indoor Motor 3800kv
Gear:"Main Gear 64P64T Aluminium(shaft3mm, 3mm ball bearing)
Spur Gear M0.4 56T, 64P8TPinionWire(4mm ball bearing)
Pinion Gear M04 14T (=64P14T)
ESC: Castle Creations Thunderbird-9 Brushless ESC or H-KING 10A Fixed Wing BrushlessESC
Battery: Lipo 2cell 240mAh G3
Control: 3CH (a motor, inverted V tail:2 servo)
Film of a wing: Orcon film
Kazu-kaku is offline Find More Posts by Kazu-kaku
Old Oct 06, 2011, 02:20 AM
massimo is offline
Find More Posts by massimo
massimo's Avatar
Joined Nov 2001
Wawww FANTASTIC !!
massimo is offline Find More Posts by massimo
Old Oct 06, 2011, 03:24 AM
KJELL is offline
Find More Posts by KJELL
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Good ilustration.
What kind of strings are you using?
KJELL is offline Find More Posts by KJELL
Old Oct 06, 2011, 03:56 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Originally Posted by KJELL View Post
Good ilustration.
This is PE(polyethylene) line for fishing.
number 0.8-1 ,very fine, strong, and light thread.
EX.
http://www.amazon.co.jp/%E6%9D%B1%E3...7891097&sr=8-2
All combination section of carbon and carbon is restricted by PE line and fixed by SuperGlue.
Old Oct 06, 2011, 05:46 AM
dhyayi is offline
Find More Posts by dhyayi
Joined Jul 2011
could not read japan text. could you please put the amazon.com link ?
dhyayi is offline Find More Posts by dhyayi
Reply With Quote  (Disabled)
Old Oct 06, 2011, 06:30 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
EX
http://www.alibaba.com/showroom/poly...hing-line.html
http://www.alibaba.com/product-tp/11...E_Fishing.html
Old Oct 06, 2011, 08:32 PM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
In making
Work is progressing.
Body weight 104g with New GLDAB
Battery18g
Total weght 122g
Wing span 85cm
Length 46cm
Old Oct 07, 2011, 05:00 AM
therealthing691 is online now
Find More Posts by therealthing691
therealthing691's Avatar
australia
Joined Apr 2007
looking good doctor kazu thank you for sharing regards brian
therealthing691 is online now Find More Posts by therealthing691
Old Oct 09, 2011, 04:30 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
First test Flight
This is first test flight of Kestrel 17-1.
Acrobatic flight is possible.Loop and Roll etc.
For Looping, power is not enough a little.
Gliding is possible.
New GLDAB is now setting.
Please look on youtube and on HD.
Kestrel 17-1 for Acrobatic flight: First test Flight (10 min 35 sec)
Old Oct 09, 2011, 04:49 AM
australia
Joined Apr 2007
great flight good thrust and Acrobatic flying once again great job doctor kazu
Old Oct 09, 2011, 04:57 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Thank you.
Old Oct 09, 2011, 05:30 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
When will we see the orni in the market?
Old Oct 09, 2011, 05:57 AM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
Sorry, I do not think the orni into the market.
Old Oct 09, 2011, 09:33 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
I think many orni-fans would like to have the possibility to make a copy of your fantastic ornis. I don’t think it is necessary to produce ornis ready to fly but many like to have the possibility to be able to build the Kestrel from your instructions.
Old Oct 09, 2011, 06:30 PM
K Kakuta
Kazu-kaku's Avatar
Joined Aug 2006
How to make is same as ---Making of Pteranodon 5-6V.
Material cost without NewGLDAB is about 12000 yen(158USD:1USD=77yen)+Postage.
+Motor(950yen)+reciever+servo*2(5200yen)+ESC(900ye n or 2200yen)+New GLDAB
And your skill.
Discussion Kestrel 17-4.25 Metre span(1/4 scale) Damian Couzoff Scale Sailplanes 38 Mar 19, 2013 07:10 AM
For Sale 2.4 Ghz Radio with Nine Eagles Kestrel Coaxial - $40 $RC ADDICT$ Aircraft - Electric - Multirotor (FS/W) 3 Oct 06, 2011 06:26 AM
Discussion Trial of Making of membrane wing With an articulation which bends to a one direction. Kazu-kaku Ornithopters 49 Jul 20, 2011 04:57 PM
Discussion Simple SK membrane wing isn't simple ..at all !!!??:) khaled_abobakr Ornithopters 7 Apr 04, 2011 05:29 PM
