Old Oct 14, 2014, 04:18 AM
Joined Aug 2007
Single aileron operation
I have a foamy custom build F 104 ,
can I loose one aileron servo and aileron
I mean I only just struggle around level flight
Would saving the weight justify the small lack of control , I still have rudder ,
and yes speed cures wing rock , thanks
NX-687 is offline Find More Posts by NX-687
Old Oct 14, 2014, 04:58 AM
It can work, it just won't work well. You will still have some large asymmetry in the form of adverse yaw. Add to that the fact that the rudder on the F104 has a strong adverse roll component, and that the F104 has built in anhedral (it's there to compensate the dihedral effect of the T tail). I'd work out a way to drive both ailerons with a single servo instead.
Brandano is online now Find More Posts by Brandano
Old Oct 14, 2014, 05:31 AM
Joined Aug 2007
for the lesson , , it helps
Old Oct 16, 2014, 10:27 AM
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Some racing planes use a single aileron.... it's usually on the side the plane will be turning towards when racing. Leaves the other wing drag-free.
But with the short span on the -104, both are probably needed.
Sparky Paul is online now Find More Posts by Sparky Paul
Old Oct 16, 2014, 08:17 PM
Joined Feb 2014
it works there was a time some could only afford to have 1 on there plane but it seam pointless now with $3 servos if you worried about weight get some 4g servos then you can have 2 and save 1g
bcredneck is online now Find More Posts by bcredneck
Old Oct 17, 2014, 01:40 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Well, racing planes only turned in one direction so using one aileron could actually become an advantage instead of hindrance.
These days with cheap servos new folks to the hobby forget or never learn that in the "old days" we used one aileron servo all the time and used linkages to run two ailerons from one servo.
But then the new servos can be obtained that are so light that using one with linkages to run two surfaces weighs as much as using two smaller wing mounted servos with short and light connecting rods. So these days it's a tossup for which way to go for light weight and enough power.
BMatthews is offline Find More Posts by BMatthews
Old Oct 17, 2014, 05:07 PM
I am not old enough, but I remember reading articles about how the pioneers got two axes to work controlled by a single channel. And the transmitter only had a button
[edit] Like this:
Galloping Ghost Radio Control (2 min 3 sec)
Old Oct 17, 2014, 05:37 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Bonner compound escapements had rudder, elevator and motor control on single channel radios, with 3 escapements.
Clever use of a ratcheting speed control wheel on the primary escapement permitted selecting rudder, or elevator, or motor depending on the button pushing.
It did work.
Video of one such..
Vintage Single Channel RC Bonner Cascaded Escapements (2 min 14 sec)
Discussion Single Servo Torque Rod Aileron Servo Installation ThermalSniffer Vintage & Old-Timer Designs 7 Sep 03, 2014 01:42 PM
Discussion Single Aileron Input to Receiver vs Dual Bob6831 Beginner Training Area (Aircraft-Electric) 15 May 09, 2014 11:07 AM
Video ☜★☞ tecbus Highone+GH4 4K Single operator,Faster than 70km/h tecbus Multirotor Talk 1 Apr 21, 2014 09:49 PM
For Sale CineStar 6 / 2-Axis Single Operator RTF for sale gbaum Aircraft - Electric - Multirotor (FS/W) 1 Mar 01, 2014 08:48 PM
Rcvr, Servos for Single LiPoly Operation? Jim Miller Radios 3 Sep 03, 2002 06:24 PM
