Old Aug 26, 2015, 02:49 AM
floquet is online now
Find More Posts by floquet
Hugh Blackburn
floquet's Avatar
Melbourne, Australia
Joined Jun 2005
The "yellow thing" in the build photos is a sheet of fibreglass that pads the thickness of the horn. It's typically CA'd to the top of the horn before the whole lot is glued inside the flaperon. (I'm not sure why the slot in the flaperon is wider than the horn - maybe a fabrication/tooling issue or to minimize the thickness of foam between the horn and the skins.) Anyway the sheet is not flexible...
It's quite possible that the horn itself is breaking up. There have been a few reports of this, though it is very uncommon (maybe there was some prior damage/hard landing). Replacement is the only real option in that case. The best approach is to get/buy a new horn and remove the old one using a heated knife blade. If you search back in this thread you'll find such a repair documented, and I have seen it done without it making a visually appalling mess (in fact it was hard to tell).
Hugh
floquet is online now Find More Posts by floquet
Old Aug 26, 2015, 09:51 AM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
I had one that the glue came loose from the skin causing a flutter. I just wicked in some medium CA and pinched the area until it cured. Problem solved.
I also had a friend that had one horn break at the bend. This is a plane that I owned and smacked pretty hard into a tree. He repaired the wing but it's possible that the horn got damaged in that incident and nobody noticed until it let go in a hard launch.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Aug 26, 2015, 10:35 AM
Blaster is online now
Find More Posts by Blaster
Dallas, TX
Joined Aug 2004
Control Horns
We have spare control horns in stock if needed.
Barry
Blaster is online now Find More Posts by Blaster
Old Yesterday, 04:28 AM
mikeff is offline
Find More Posts by mikeff
mikeff's Avatar
Joined Mar 2008
Originally Posted by RED_HLG View Post
Ok, I'm getting flutter I my left aileron... Upon closer inspection, the torque horn is flexing inside the aileron. If I hold the aileron against the fixed TE, the horn will move maybe 1/8 inch fore and aft.
RED
I think the horn is failing like the one pictured below.
We had this on a friend's Snipe with aileron flutter. We tried putting thin CA into the failed fibres but it didn't last more than a couple of launches.
I broke my horns (one pictured) in a heavy nose to ground impact that shortened the front end by 40 mm!
With care and patience and perhaps a hot knife blade, you can get the horns out without too much further damage - see pictures. My wing is now ready for the reinforcement to go back over the support axles. See third picture.
Good luck!
mikeff is offline Find More Posts by mikeff
Old Yesterday, 08:39 AM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
I think if you wicked laminating resin into that horn you would have a good chance at a solid repair. CA can be very brittle.
samc99us is offline Find More Posts by samc99us
Old Yesterday, 08:49 AM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
I think wicking anything into the broken fibers of that horn is a Band-Aid fix at best.
Build Log Blaster 3 DLG from Kennedy Composits simages Hand Launch 4 Jun 04, 2013 10:38 PM
Sold ELF X tail from Kennedy Composites mgroves Aircraft - Sailplanes (FS/W) 1 Feb 10, 2013 01:26 PM
Discussion Take a break from the sniping ... and enjoy a greate father son moment ... logan5 Life, The Universe, and Politics 3 Oct 04, 2012 10:09 PM
Wanted Snipe Composite, Wingeron davonat Aircraft - Sailplanes (FS/W) 2 Mar 30, 2008 09:15 PM
Discussion Snipe Composite davonat Sailplane Talk 5 Mar 30, 2008 04:30 PM
