Old Aug 17, 2015, 06:34 AM
FlyingPancake is offline
Find More Posts by FlyingPancake
Joined Jul 2013
GIve me smart ideas for easiest way to push mechanic button remotely?
I need minimalistic and simple setup to press mechanic button remotely (few meters away)
What i've figured so far is to use one of those remote electric circuit switches
http://www.dx.com/p/4-channel-wirele...85-260v-128683
to power up a servo that presses the button.
But how to give the servo the necessary signal without complicating the setup too much? (radio tx, and rx, binding and so on..)
any ideas are welcome, it just needs to be simple
FlyingPancake is offline Find More Posts by FlyingPancake
Old Aug 17, 2015, 07:32 AM
wolfiniron is offline
Find More Posts by wolfiniron
Joined Apr 2015
Here's one similar to the one you linked to but it's run on 12volt.
http://www.allelectronics.com/make-a...control/1.html
And another that triggers from a key chain transmitter.
http://www.allelectronics.com/make-a...-15-amp/1.html
Also check surplus electronics stores. I've found some interesting things there at a way reduced price.
wolfiniron is offline Find More Posts by wolfiniron
Old Aug 17, 2015, 08:55 AM
phil_g is offline
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
Instead of having a servo physically press the button, can you get to the wiring to connect a relay contact in parallel with the button?
phil_g is offline Find More Posts by phil_g
Old Aug 17, 2015, 04:59 PM
jakestew is offline
Find More Posts by jakestew
United States, ID
Joined Sep 2011
What the hell is a "mechanic button"?
If you mean "mechanical button" you still need to clarify. There are many types.
jakestew is offline Find More Posts by jakestew
Old Aug 17, 2015, 05:09 PM
phil_g is offline
phil_g's Avatar
Joined Jul 2007
I'm out
Old Aug 17, 2015, 05:16 PM
jakestew is offline
United States, ID
Joined Sep 2011
Originally Posted by phil_g View Post
I'm out
Out of "mechanic buttons"?
Old Aug 18, 2015, 04:26 PM
Joined Jul 2013
yeah it's a mechanicAL button that has to be physically pressed. There is no electric circuit there.
dx has 12v version of the remote switch i've linked. But the main problem is how to give the servo a signal to move without setting up rx and tx?
Old Aug 20, 2015, 11:06 AM
Plantoflap is online now
Find More Posts by Plantoflap
Joined Sep 2003
Servo tester.
Plantoflap is online now Find More Posts by Plantoflap
Old Aug 20, 2015, 11:18 AM
Ernst38 is online now
Find More Posts by Ernst38
Joined Jan 2007
Open the servo and connect directly to the motor
Ernst38 is online now Find More Posts by Ernst38
Old Aug 21, 2015, 03:38 AM
Joined Jul 2013
Originally Posted by Plantoflap View Post
Servo tester.
that might actually be just perfect!
Old Aug 21, 2015, 03:40 AM
Joined Jul 2013
in that case what would happen when just powered?
I need it to do the full motion every time it's powered.
Like press the button and then return back. Actually 90 degrees motion will be fine.
Is there a way to make it do that without supplying signal to the signal wire?
Old Aug 24, 2015, 05:39 AM
Joined Jan 2007
In that case I would use an Arduino solution, either a pro mini or ATtiny85, but I guess there are readymade solutions out there,
Old Aug 24, 2015, 11:14 AM
Joined Jul 2013
That would be an overkill for my needs.
Can't those servo testers with 3 modes (auto, manual and one more i forgot) do that upon powering them up?
Old Aug 24, 2015, 03:13 PM
Ole Joe is online now
Find More Posts by Ole Joe
Joined Oct 2007
I have one like that shown at this link;
http://www.hobbyking.com/hobbyking/s...vo_Tester.html
It does have three modes of operation, manual, neutral and auto. Mine always defaults to the manual position upon power up and moves the servo according to the last position that the pot (adjust) was left in.
Ole Joe is online now Find More Posts by Ole Joe
Old Aug 25, 2015, 03:10 AM
Joined Jul 2013
ah thanks for telling me that because i was about to order it
and it will not work that way for my needs
is there a servo tester that just goes back and forth upon powering up?
Sold FPV pod all-in-one 200mw 32ch (push button) Tx and camera. bluemeane FPV Equipment (FS/W) 6 Aug 14, 2015 09:02 PM
Discussion Can anyone give me ideas about my motor? tipup Electric Plane Talk 3 Dec 03, 2013 12:39 PM
Discussion Server as remote push button emailbvd Radios 0 Oct 30, 2012 12:22 PM
Discussion Best/easiest way to remote trigger NEX5N? aForcefulThrust Multirotor Electronics 2 Jul 18, 2012 07:54 PM
Wanted 12v push button remote starter nitro22 Non R/C Items (FS/W) 3 Aug 29, 2010 11:29 AM
