Old Oct 04, 2012, 10:51 PM
Joined Apr 2005
Recomend me a fan for my meteor
I have melted the stock motor and then had a velocity fan blow up. Both were fine on 5s but when I put 6s in it I have problems. Looking for the most powerful motor/fan that could run on 5s and 6s For $100 or less. I'm running a hw100a in it so shouldn't have a problem there.
jesse is offline Find More Posts by jesse
Old Oct 04, 2012, 11:05 PM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
If your wanting to run 6s, I'd suggest a HET 6904 or Wemotec Minifan pro EDF.
but your looking at 100+ amps for 6s setups. I'd use a Castle ICE 100 ESC
For 6s motors I have the......
Velocity 2900kv (4mm shaft)
http://www.effluxrc.com/Velocity-Hig...28-60-2900.htm
Mega 16/40/1 3150 kv (3.17 or 4mm shaft)
http://www.effluxrc.com/MEGA-16-40-1...6-40-1-4MM.htm
HET 1W-40 3300kv (4mm shaft)
http://www.effluxrc.com/HET-1W-40-Motor-HET1W40.htm
Sorry it's not $100 or less for a complete setup. These are all quality products. No junk.
efflux RC is online now Find More Posts by efflux RC
Site Sponsor
Old Oct 05, 2012, 01:16 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Gary,
That airframe is also just 65mm. He may be looking for the 65mm Velocity or HET.
Eric B.
AirX is offline Find More Posts by AirX
Latest blog entry: T/A 37 Tweet/Dragonfly
Old Oct 05, 2012, 01:25 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
the Dynam Meteor from nitroplanes is a 70mm platform I think this is the one he is talking about
jcdfrd is offline Find More Posts by jcdfrd
Old Oct 05, 2012, 05:45 PM
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Ok I thought it was 65mm.
Eric B.
Old Oct 05, 2012, 09:47 PM
Joined Apr 2005
Thanks for the replys, I don't wanna go over 100 amps as I'm limited on battery size. I've been running 5s and 6s 3300 mah 30 packs. I was getting 4 min. with a mix of full throttle and 3/4 throttle flying. 3 min. full throttle flights. I have 6s 5300 but I just don't think I can get them far enough back to balance or even come close. As far as castle In the edf world they may be fine but I come from a heli background and once you have one go up and take out 2000 in heli it will leave a bad taste in your mouth for a life time.
Old Oct 05, 2012, 09:48 PM
Joined Apr 2005
Oh yeah it is a meteor with a 70mm fan didnt know there was a smaller one.
Old Oct 07, 2012, 09:30 AM
Wichita, KS
Joined Apr 2003
I have had good results using the Ammo 28-35-3900 in the 65mm Wattage fan, nothing earth shaking, but 18oz. static at 265 watts on 3S. The motor is available from Tower Hobbies. The MPJet small prop adapter (3.2 mm shaft M5 hole in fan) converts the Wattage fan to the 3.2mm notor shaft.
William E Brown is offline Find More Posts by William E Brown
Old Oct 11, 2012, 06:07 AM
designer,builder,flyer
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
The easiest way to install a large battery up front and get it to balance is to install a really big motor in the back! Get a hold of a JS1400 outrunner on the extention, it will move some weight to the rear, take 5s and go like stink. Only thing is about 115 amps. A couple fellows have a 6904/JS1400 on 4000 65c 5s packs. They land like a feather too!
ApexAero is offline Find More Posts by ApexAero
Old Oct 11, 2012, 03:03 PM
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
Motor extension? Plz elaborate.
WhalleyB0Y is offline Find More Posts by WhalleyB0Y
Old Oct 14, 2012, 06:31 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Apex, meant its a outrunner on a standoff adapter
D_FAST is offline Find More Posts by D_FAST
Old Oct 15, 2012, 08:49 AM
WhalleyB0Y's Avatar
Canada, BC, Surrey
Joined Jul 2011
Ah ok, I get it now. Funny though because on the some of the motor threads they focus on getting the fan and motor close together as to help with rotating mass... I do like the idea of shifting weight back with the use of motor extension.
Discussion Recomend me an RC truck with the following specs SARCFAN Off-road Cars 7 Aug 03, 2012 01:48 PM
Discussion recomend a motor esc battery for my weston couger 2000 RyThEm Electric Plane Talk 15 Jun 06, 2012 12:31 PM
Cool My Dynam Meteor 4th Flight thndr1mj Electric Ducted Fan Jet Talk 0 Jun 03, 2012 12:30 PM
Discussion Please help me decide the right motor and prop for my hexa for greater flight times joy4u Multirotor Talk 2 May 02, 2012 10:34 AM
Build Log New GAD Meteor F4 for twin 64 fans Adrianh Foamy EDFs 26 Dec 17, 2011 11:46 PM
