Old Apr 23, 2015, 01:18 PM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
Wow, that looks awesome!!
Castel101 is offline Find More Posts by Castel101
Old Apr 29, 2015, 04:00 AM
crasha is offline
Find More Posts by crasha
Terrain......PULL UP!!!
crasha's Avatar
Joined Feb 2011
Thanks for following the build Castel!
More painting. Lots of masking and airbrushing.
I had trouble getting a perfect finish with the decals using decal pro. Some of the smaller ones are OK but it is no good for the large ones. After lots of wasted time I decided to do it the old fashioned way and printed out the stars and bars on sticker paper then hand cut each one out to make an airbrushing mask.
Very happy with the result. Way better than any decals I have seen and surprisingly less work than I first thought.
Also started some weathering. It will not be totally finished in time for the next jet event which is in 3 days so I will soon give it a coat of clear and get it ready to fly again. Then get back to the detailing after the event.
crasha is offline Find More Posts by crasha
Old Apr 30, 2015, 07:54 AM
crasha is offline
crasha's Avatar
Joined Feb 2011
More masking and decal painting. Not finished yet but getting ready to fly again. Will have to finish off the decals later. The drop shadow on the tail lettering was quite a challenge to cut by hand!
Old May 03, 2015, 07:25 AM
crasha is offline
crasha's Avatar
Joined Feb 2011
Had 5 perfect flights at the WA jet rally. The F-22 performed flawlesly and looked great with the new paint.
Still need to fit the gear doors and finish the decals. Probably take a short break on the raptor build while I work on a sport jet I am designing.
Jetlegend F-22 at Western Australian jet rally 2015 (7 min 12 sec)
Old May 08, 2015, 01:23 PM
gunradd is offline
Find More Posts by gunradd
KingtechUSA
gunradd's Avatar
United States, FL, Spring Hill
Joined Apr 2009
Fantastic work Crasha!! It really looks great. Looks like the same colors as mine. Its nice to see someone paint one right
BTW on my raptor I went ahead and did the RDS linkages and they are working great. Just did flight number 496 at topgun.
gunradd is offline Find More Posts by gunradd
Old May 10, 2015, 01:59 AM
crasha is offline
crasha's Avatar
Joined Feb 2011
Thanks Gunradd
I copied your colours using the model master paints. Instead of using lots of tiny bottles I bought 2 and had them colour matched in acrylic automotive paint. Very happy with the result. Your posts in the sport jet paint thread saved alot of guesswork
Glad to hear the RDS works well. It sure must help to improve your static scores at Topgun! The rudder links especially look pretty bad on the JL F-22
I am still keen to try the RDS but may wait until I mold new fins with the rudder actuator bulges like the full size. New wings with the bulges and leading edge flaps would be great too. Just need to find the time to do it all
Old Jun 03, 2015, 10:05 PM
juanjulian is offline
Find More Posts by juanjulian
juanjulian's Avatar
Guatemala, Guate
Joined Jul 2007
Super build.
To me both planes are gray
Cheers
Juan
juanjulian is offline Find More Posts by juanjulian
Old Jun 10, 2015, 04:15 PM
Rossi63 is offline
Find More Posts by Rossi63
Sandnes, Norway
Joined Nov 2007
Crasha. Please see the short video I make filming my Raptors deflection on elevator, aileron and taileron. To much?
Jetlegend F-22 Raptor (1 min 12 sec)
Rossi63 is offline Find More Posts by Rossi63
Old Jun 10, 2015, 11:32 PM
crasha is offline
crasha's Avatar
Joined Feb 2011
Hi Rossi
You throws look fairly close and should work fine. Of course it all comes down to personal preference. Once you have a few flights you can adjust to suit your flying style.
Here is a video of the throws I am using. The numbers for all the deflections are on post #30 of this thread.
Good luck with your maiden. Hope you enjoy your F-22. They are a great jet once set up.
Hope you can post a vid here of your maiden!
Jet Legend F-22 flight controls (2 min 17 sec)
Old Jun 17, 2015, 01:54 AM
Rossi63 is offline
Sandnes, Norway
Joined Nov 2007
F-22 rudder throw
Crasha. Thanks for video. Do you have a short video of throws when applying aileron at full up/down elevator? Deflection continue or reduce?
Old Jun 18, 2015, 10:47 PM
crasha is offline
crasha's Avatar
Joined Feb 2011
Hi Rossi
My radio automatically sets the mix.
When applying aileron the tailerons should move at the set aileron rate regardless of elevator position. For example if at full up or down elevator the tails will increase in travel with the aileron mix.
The servo may not have enough travel to give full alieron and elevator throw at once. This is not really an issue with the throws I use. I do have a few mm less aileron throw at full down elevator due to servo travel but it would not be noticeable in flight.
It would be highly unlikely that you would ever use full elevator and aileron at the same time. It would over stress the airframe and probably break the wings
You mix seems to be working fine in the video.
Jl F-22 tail mix (1 min 5 sec)
Old Jun 19, 2015, 08:09 AM
Rossi63 is offline
Sandnes, Norway
Joined Nov 2007
Thanks for the video. It helped a lot
Build Log F-22 Depron Detailed Build, Plans and Video. Super easy F22 restie Foamies (Scratchbuilt) 307 Jun 29, 2015 05:46 PM
Discussion Andrew's F-22 Raptor andrewboktor Foamies (Scratchbuilt) 8 Apr 09, 2013 06:19 PM
Sold JetLegend F-16C 1:8 Fighting Falcon ARF Molded Jet w/scale Retracts hobbyclub Aircraft - Fuel - Jets (FS/W) 1 Jan 06, 2013 09:13 PM
Alert JetLegend F-16C Fighting Falcon ARF Molded Jet w/scale Retracts hobbyclub Fuel Jet Talk 0 Jan 05, 2013 07:32 PM
Help! Can you help me?[JetSet44's F/A-22 building] D@CMOS Pusher Prop Jet Models 2 Sep 18, 2007 07:28 AM
