Old Jan 18, 2016, 12:12 PM
Hugo Flynow is offline
Find More Posts by Hugo Flynow
Fond of Foam
Hugo Flynow's Avatar
United States, MD, Ridge
Joined Oct 2015
The groove is in both the fuse and wing. maybe I compromised the wing...maybe not. Time will tell I guess...but the groove is only 1/4 inch deep and the wing feels very solid. I like the gasket idea, but it's not what I thought of at the time. that's the beauty of this board...hearing other people's ideas. I have learned more in the last 3 months on this board than the last 10 years of flying.
Hugo Flynow is offline Find More Posts by Hugo Flynow
Old Jan 18, 2016, 09:19 PM
riggerdood is offline
Find More Posts by riggerdood
Joined Jul 2015
Put everything back together, and all seems to be well. Had to scrape a bit of silicone off of the servo contacts on the rx to get them to make good contact, but otherwise all is well. Will fly again once we are done with our "one week of winter" ... <grin>
riggerdood is offline Find More Posts by riggerdood
Old Jan 24, 2016, 06:11 PM
RexGalore is offline
Find More Posts by RexGalore
Out Standing In The Field
RexGalore's Avatar
United States, CT, Middletown
Joined Feb 2014
Throttle/Elevator "Trim Mix"
I was just flying the Tidewater off of the snowy hayfield (we had about a foot of powder yesterday - the first real snowfall of the season). There was a light North wind, easily compensated by the Lemon stabilized receiver (no annoying wing rocking). But when doing landing approaches, cutting the throttle back resulted in the plane nosing up to the point that "bad things will happen" if either some down elevator or some up throttle didn't get applied.
A while back, d_toolman posted that he'd programmed a throttle/elevator mix in:
http://www.rcgroups.com/forums/showp...&postcount=423
I think I'd like to give it a try, and wondered if anyone else had experimented with this as well. Any hints or tips? (d-toolman is certainly very welcome, too!).
RexGalore is offline Find More Posts by RexGalore
Old Jan 24, 2016, 08:38 PM
Fond of Foam
Joined Oct 2015
I flew my Tidewater off snow today too! When I cut throttle, it sort of just wallows in the sky and has no glide slope at all. It flew like it was tailheavy, so I checked CG and found it very noseheavy, so go figure. I just think that high up motor pod really messes up the weight distrubution. No Stab on mine BTW. Other than that it flies OK and taxis great off 10" of snow!
I think you just need to keep throttle up on landing...almost like a warbird.
Old Jan 24, 2016, 08:58 PM
roversgonemad is offline
Find More Posts by roversgonemad
roversgonemad's Avatar
United States, ID, Idaho Falls
Joined Feb 2013
The high thrust line definitely contributes to some interesting flying characterisitcs. What you are both describing seems a bit extreme; are your power pods tight? Mine climbs a little on initial throttle chop, but not so extreme that it seems tail heavy. The tall power pod adds a lot of drag as well, likely contributing to the tail heavy behavior. Honestly, with power off, the glide isn't too bad, but it's definitley a plane that prefers a little throttle on landing. I have found that the tidewater has to be flown at all times. It's not really a "hands off" flyer.
roversgonemad is offline Find More Posts by roversgonemad
Old Jan 24, 2016, 09:20 PM
oscarmok is offline
Find More Posts by oscarmok
Canada, ON, Toronto
Joined Jun 2013
I took the Tidewater out for snow flying this morning. The flight time needs to cut short (from 7 mins down to 4mins). One thing I like about Tidewater is the ability to fly during winter time.
Tidewater snow flying (2 min 50 sec)
oscarmok is offline Find More Posts by oscarmok
Old Jan 24, 2016, 10:22 PM
RexGalore's Avatar
Joined Feb 2014
Good points, guys! My problem is almost all the places I can fly (water or snow) have tall trees not that far away. It's kind of like STOL time all the time. The other option is low altitude/tight turn to final, but that doesn't leave much room for error - and error is my co-pilot. I do like landing it, just trying to figure out a way to lower the "pilot load" (and lessen the chance of a splashdown (snowdown?)).
Oscarmok, you've got way less snow than we do! I remember the 2014 video of you flying while it snowed - liked that one, too. Do you want some of our nice, new snow? I'd like to get rid of some! The snowmobiles carved deep ruts all over the field.
Old Jan 25, 2016, 08:43 AM
Fond of Foam
Joined Oct 2015
If possible your best chance is to take off and land in a headwind...that should help!
Sold Flyzone Beaver, Flyzone C350 Corcalis, TH P-51 JimVanLoo Aircraft - Electric - Airplanes (FS/W) 0 Jan 08, 2013 02:15 PM
For Sale Anyone in the tidewater VB area interested in a slightly crashed E-flight Edge 540. Speedfreak Aircraft - Electric - Airplanes (FS/W) 1 May 12, 2006 03:13 PM
For Sale Tidewater Pronto jimmycashley Aircraft - Electric - Airplanes (FS/W) 3 Jan 15, 2006 05:45 AM
Discussion "Hardy Souls" contest, January 1, Tidewater, VA. D_Ryan Thermal 2 Dec 28, 2005 07:35 PM
Discussion "Hardy Souls" contest, January 1, Tidewater, VA. D_Ryan Sailplane Talk 1 Dec 28, 2005 11:30 AM
