Old Jun 19, 2011, 04:49 AM
nick30head is offline
Find More Posts by nick30head
nick 30
nick30head's Avatar
Joined May 2009
need some help figuring out a few things
i've got an old mono 1 hull (twin step fast electric hull) that i'm turning into a narrow hull sail/racing boat, the hulls about 28" long with a beam of about 8", the mast will be 3 feet long
so my question is this :-
1 - keel length ( i was thinking 12" - 14") or any other idea's ??
2 - keel weight, what should this be (4lb or something)
thanks guys, nick
nick30head is offline Find More Posts by nick30head
Old Jun 19, 2011, 05:39 AM
nick 30
nick30head's Avatar
Joined May 2009
a few photo's
photo 1= side view of over all length
photo 2= front view to show the beam
photo 3= view to show servo's placement, front servo will be a 1 turn sail winch and running line (old servo case and output gear used for mock up's) and rear servo is for the rudder
the rx and battery will be placed either side of the keel box, the hole at the front is for pulley access and will be covered over when painting is to be done, no super structure will be made just a sliding hatch for access
Old Jun 19, 2011, 07:20 AM
wallis_100 is offline
Find More Posts by wallis_100
build like there is no 2moz
wallis_100's Avatar
United Kingdom, England, Bristol
Joined Apr 2009
Nick...
Certainly a random idea. Good luck with it, you may find you have a few luffing up/bearing away problems.
Keel depth, the deeper the better! try 12-24 inches, and see how you go. A deeper keel means more power(sail) carrying ability.
Weight wise. I would try to get it to sit on an even keel nose up slightly, with the chines (assuming it has small vertical sides to the hull) on the WL, go with weight to suit that.
Else, bring it along to the next meeting, and i can have a look
Scott
wallis_100 is offline Find More Posts by wallis_100
Old Jun 20, 2011, 02:54 AM
nick 30
nick30head's Avatar
Joined May 2009
thanks scott
underneath it has 2 steps at the rear and 3 strakes (both sides) running 3/4 of the hull length (from bow to first step)
will bring it to the next meeting just to show everyone else, i'm waiting on sail winch some ally tube for the jib boom
Old Jun 20, 2011, 12:55 PM
wallis_100's Avatar
Joined Apr 2009
A fairly standard high performance FE hull then.
I look forward to seeing it.
I will be bringing along my LB, as i think i'll offer it within the club (i don't really feel the urge to build it any more)
ANd have given myself a challenge (1/400th scale plastic Aircraft carrier to rc conversion, for the fun of it
Scott
Old Jun 20, 2011, 09:10 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Wonder if it could carry enough sail as a trimaran to plane?
DT56 is offline Find More Posts by DT56
Old Jun 21, 2011, 03:45 AM
nick 30
nick30head's Avatar
Joined May 2009
once the sail winch gets here and installed, its a case of finding out how much keel weight i need then, i have sail rig (its the big rig with a 3 foot mast) already setup that i use on my star baby cabin cruiser to sort the boom and jib setup and then see how she sails
Discussion need some help out getting info madmikeyreturns Indoor Pattern/F3P 3 May 31, 2011 11:34 PM
Discussion Okay time to change things out, need some opinions sherlockshah Electric Ducted Fan Jet Talk 31 Mar 24, 2011 10:25 AM
Discussion Help figuring out some things on my FF BAE Hawk??? CSI Foamy EDFs 5 Jul 28, 2008 01:59 AM
Discussion Need some advice on a few things MX400 Shadrack Mini Helis 3 Oct 09, 2006 10:07 AM
Need Some Advise On A Few Things AzJason Flying Wings 4 Aug 05, 2004 12:07 PM
