Old Oct 26, 2014, 04:20 PM
bimmerland's Avatar
United States, NC, Cary
Joined Nov 2011
Help!
Visionaire elevator oscillation
Oscillation in flight only occurs in gear position 1. Don't see it happening during full throttle but normal cruising the tale wallows like a whale. Goes away as soon as I switch to gear pos 0. Haven't touched anything yet but was thinking of trying a factory reset. Any suggestions greatly appreciated. Thanks
bimmerland is online now Find More Posts by bimmerland
Old Oct 26, 2014, 05:39 PM
United States, NC, Garner
Joined Nov 2012
U DO NOT fly full speed in 3d mode,,,,,,General flight only ,,,,,,re - read manual
dalecheek1 is offline Find More Posts by dalecheek1
Old Oct 26, 2014, 08:55 PM
Gold Coast Coolangata, Australia
Joined Nov 2003
If you want it wobble-free in 3D mode you need to drop the ar635 gains down a bit. I went from the stock A, E, R = 80,80,90 down to 60,60,80 and this allows me to fly full speed without wobbles but still gives very good stabilisation imho. Also, a well balanced prop helps since vibs can also cause wobbles.
TomC is online now Find More Posts by TomC
Old Oct 26, 2014, 09:24 PM
Wanted: More Time to Fly
Topdogzrc's Avatar
Joined Aug 2014
I disabled the gyros all together to prevent that from happening, but the flip side to that is the VAire could no longer handle wind, so I'm thinking of putting the gyros at 10 or 20%. Just don't forget to remove the prop before tinkering and you'll be fine. Good luck, and keep flying!
Topdogzrc is offline Find More Posts by Topdogzrc
Old Oct 27, 2014, 12:00 AM
bimmerland's Avatar
Joined Nov 2011
@TomC... Thanks for the info. I'll try dropping the elevator gain since no other surface is affected. Just printed out the ar635 user guide.
Sold Parkzone Visionaire AS3X-AR635 Receiver - 3D Aerobatic Plane - $200 Stuart, FL 34997 wilanz Aircraft - Electric - Airplanes (FS/W) 1 Oct 18, 2014 07:53 PM
Help! Max stick causes crazy oscillations in baseflight polizz Scratchbuilt Multirotors 2 Oct 09, 2014 09:07 PM
Discussion visionaire as3x settings deep purple 92 3D Flying 0 Oct 09, 2014 08:21 PM
Discussion DJI Phantom Oscillating and Spinning j437a Multirotor Talk 1 Sep 21, 2014 11:46 PM
Discussion Visionaire Elevator Oscillation dereckbc 3D Flying 0 Sep 07, 2014 02:54 PM
