Old Mar 04, 2015, 03:12 PM
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Originally Posted by mwrzesinski View Post
i understand, but, i put this idea on my mind.... is it correct? do you think it can do the work?
No not really. . . It's the swept back bent angle of the 767's elevator themselves that makes connection them to one servo rather difficult.
. . . . Not impossible. . . But difficult.
demondriver is offline Find More Posts by demondriver
Old Mar 05, 2015, 02:51 PM
Trabado por las importaciones
mwrzesinski's Avatar
Argentina, CABA, CF
Joined Jan 2015
Originally Posted by demondriver View Post
Now I'm adding the main wing fastening Bolt & nuts to the Fuse & wing Box of the MD-80, these are Teflon Toilet set bolts. . . .Light-N-strong!
Ahhhhhhh!!!!! thats it! to the toilet!
i was looking plastic screws in hardware stores and the people looked at me weird, now i know that they are made off teflon and holding the toilet lid, you save me sir!. Now i know what im looking for correctly.
mwrzesinski is offline Find More Posts by mwrzesinski
Old Mar 05, 2015, 02:54 PM
Argentina, CABA, CF
Joined Jan 2015
yeah! you are all right.
I'm going to complicate myself unnecessarily
Old Mar 05, 2015, 03:49 PM
Up-Out-&-Gone
Joined Mar 2007
Hey maybe you can make it work. . . Or come up with an idea. . . All it takes is one good idea.
Old Mar 05, 2015, 08:16 PM
I make stuff
cwrr5's Avatar
United States, AZ, Marana
Joined Dec 2011
If youre going to use seperate elevator halves, it might be better to use torque rods on each elevator as I did on my C-5. Pretty easy to setup, even with a sweep back and in my case, annehedral.
cwrr5 is offline Find More Posts by cwrr5
Old Mar 05, 2015, 08:30 PM
Up-Out-&-Gone
Joined Mar 2007
That looks good and will work for your Galaxy . . there but might be a tad tricky in the tail section of a 767. . . Or maybe not. . . .
. . . I tried this several years ago with a fighter and my BAC-111 & couldn't get the elevator surfaces to ling-up or move the same amount on either side.
Old Mar 05, 2015, 08:34 PM
Up-Out-&-Gone
Joined Mar 2007
But for these MD-80's and bigger Mad-Dogs the flying tail arrangement should suffice.
Old Mar 06, 2015, 09:39 AM
Argentina, CABA, CF
Joined Jan 2015
yes...! i will test firts!
Old Mar 06, 2015, 09:43 AM
Argentina, CABA, CF
Joined Jan 2015
I'll keep that in mind...thanks for the tip.
Old Mar 06, 2015, 09:58 AM
Argentina, CABA, CF
Joined Jan 2015
maybe it can work, but i think that if i use this system, i will make it very very perfect and accurate to avoid what happened to you in your frieghter and BAC-111 thinking in all possible variables. But Chris, beware!, i do not say that you've done wrong, simple just didnt work, i imagine. You're a mentor, your advice is highly valued
The truth is until i doesnt work with the fuselage and tail, everything are ideas and fears in order to not lose time and money. Well...in a lot of parts of ours lives, time is money.
Old Mar 06, 2015, 05:43 PM
Up-Out-&-Gone
Joined Mar 2007
maybe it can work, but i think that if i use this system, i will make it very very perfect and accurate to avoid what happened to you in your fighter and BAC-111 thinking in all possible variables. But Chris, beware!, i do not say that you've done wrong, simple just didnt work, i imagine. You're a mentor, your advice is highly valued
lots of people have ideas & advice & experience here on RCG. . . That's why I never think I know everything about RC flight. . . Because I don't.
In the end the only real way you can't test an idea is to test it in flight.
it was the maiden "Hop" of my MD-80 that showed me I needed a greater sized elevator on these flying pencils. . . I really learn things during flight.
Old Mar 09, 2015, 09:32 AM
Argentina, CABA, CF
Joined Jan 2015
yes sir!
haha! flying pencil! the best definition of the md80-82-dc9
Old Mar 09, 2015, 01:00 PM
Up-Out-&-Gone
Joined Mar 2007
yes sir!
The MD-90 is even longer of a pencel. Lol
Discussion A little MD-80 with gws edf 40's flying_g Scratchbuilt EDFs 12 Sep 11, 2011 08:17 PM
Question McDonnell Douglas T-45 Goshawk - 70mm or 90mm version? cloaked Foamy EDFs 2 Jul 21, 2011 10:29 AM
Discussion McDonnell Douglas MD-11 3 view drawings Nykolo54 Fuel Jet Talk 2 Dec 11, 2007 07:40 PM
Northrop/McDonnell Douglas YF-23 Black Widow II Esprit440 Pusher Prop Jet Models 12 Jul 31, 2006 12:47 AM
McDonnell Douglas A4 skyhawk john_hess Scale Kit/Scratch Built 5 May 05, 2005 12:21 AM
