Old May 16, 2015, 07:15 PM
Eddie500 is offline
Find More Posts by Eddie500
Joined Nov 2011
Can I run this 27mm edf on 3s?
I think I read someplace a while back that I shouldn't run it at 3s.
I own this exact 27mm EDF.
http://www.hobbyking.com/hobbyking/s...Assembled.html
What will happen if I run it at 3s? I'm using a 30 amp ESC to run the fan.
Thanks.
Eddie500 is offline Find More Posts by Eddie500
Old May 16, 2015, 11:01 PM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Joined Oct 2009
30amp esc may be over-kill as this fan draws under 6amps max.
You should also take a look at the reviews, seems some may not be well assembled or balanced so wherever you read do not use on 3S was on the money...as far as what will happen, im betting the fan will grenade itself before the motor cooks.
nighthawk0077 is offline Find More Posts by nighthawk0077
Old May 17, 2015, 12:07 AM
Eddie500 is offline
Joined Nov 2011
I'm only drawing 2.2 amp full throttle at 8 volts with this fan. Why am I pulling so little amps compared to the specs at 5 amps?
Old May 17, 2015, 01:34 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
You might ask this here: Micro EDF Jets and Power Systems
http://www.rcgroups.com/micro-edf-je...r-systems-650/
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old May 18, 2015, 11:22 AM
Bare is online now
Find More Posts by Bare
Canada
Joined Nov 2000
Couple of possible reasons:
. Your batteries are not delivering?
. There is something faulty in the motor?
. Your ESC cannot manage the RPMs that 11,ooo kv motor 'could' generate
Bare is online now Find More Posts by Bare
Discussion Can I run 11.1 volt 3s lipo on stock losi micro sct? Dante DAngelo Micro Cars 18 Aug 23, 2014 11:53 AM
Question Can I Run This on a 3s Pack? SubaruMike 3D Foamies 4 Jul 17, 2014 10:03 PM
Discussion Can I use 3S lipos on this setup? canadien007 Multirotor Talk 2 May 02, 2014 06:43 PM
Discussion 1.3 800mw transmitter , 3s for sure but can I run a 4s lipo on it zackthrills FPV Equipment 3 Mar 27, 2014 02:39 PM
Discussion Can I run 6S motor on 3S? milo12 Power Systems 17 Dec 18, 2013 05:01 AM
