Old May 10, 2015, 02:23 PM
LRFitch is online now
Find More Posts by LRFitch
Pasco Tri Cities, Washington, United States
Joined Aug 2004
Question
Base Flight VS Clean Flight
Just ordered a couple full Naze32 boards. Is there a difference between the Clean Flight and Base Flight firmware? I understand they are both available on Google Chrome, but don't know why one should be used instead of the other. Can anyone shed a little light on the differences?
Larry Fitch
LRFitch is online now Find More Posts by LRFitch
Old May 10, 2015, 07:57 PM
waltr is online now
Find More Posts by waltr
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
Yep, BF has little support as only TimeCop works on this code and he is typically very abusive to users that make suggestions. While CF's development has been much more active, has much better documentation, code developers actually listen to users about bugs and desired features, and now has many more and better features.
Both use a configuration App that runs in Chrome. The config App is NOT BF or CF which are the firmware that runs on the FC board in the copter.
waltr is online now Find More Posts by waltr
Old May 10, 2015, 08:12 PM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Cleanflight has more features that you may find useful. Like being able to set range values so you can assign multiple functions to a single channel (frees up channels for other use, you can put autolevel and alarm on the same channel for example). I've also only been able to get bluetooth to work on cleanflights softserial.
Hajile is online now Find More Posts by Hajile
Old May 10, 2015, 09:06 PM
Joined Aug 2004
Sounds like Clean Flight it is. Thanks for your time and insights,
Larry
Discussion Openpilot vs. Clean flight Fixed wing Jman841 FPV Racing 0 Apr 04, 2015 10:08 PM
Wanted Qav 400 clean base plate. aerorynamic Aircraft - Electric - Multirotor (FS/W) 0 Mar 16, 2015 06:39 PM
Wanted QAV500 V1 "Clean Frame" Base Plate uffe40 Aircraft - Electric - Multirotor (FS/W) 5 Dec 19, 2014 07:40 AM
Wanted QAV500 "Clean Frame" Base Plate Lroc130 Aircraft - Electric - Multirotor (FS/W) 0 Jan 30, 2014 12:49 PM
