Old Feb 22, 2014, 12:29 PM
Skunkwork is offline
Find More Posts by Skunkwork
Land of confusion
Skunkwork's Avatar
Norway, Oppland, Vestre Toten
Joined Feb 2014
F-16XL EDF jet
Hi guys.
I recently started on my F-16XL edf. The size of the plane is 195cm long and a wing span of 120cm. It will be built mainly of foam and some carbon rod for strenght, before glassing the whole plane for a nice finish.
The paint scheme I am going for is nasa`s test plane as in the picture.
Propulsion will be a 12 bladed 90mm fan. Will of course be very happy with any advice around my project from experienced builders in this forum.
Skunkwork is offline Find More Posts by Skunkwork
Old Feb 22, 2014, 12:57 PM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Looks great! you'll love how these fly!
D_FAST is offline Find More Posts by D_FAST
Old Feb 22, 2014, 04:00 PM
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
I hope it will have low wing load, but not to slow in the air. Next step now is to form the nose section and cover rest of the fuselage. My aim is to make look like real thing when it comes to the shape.
Need to work out a descent power setup too.
Old Feb 22, 2014, 04:19 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Sounds like your looking at the CS 90, 12blade--if so, you best read this :
Change Sun 12 blade 90mm
http://www.rcgroups.com/forums/showthread.php?t=1520120
Lots of fiddling around to get it right.
And before you cover rest of the fuselage, you better figure out where and how your going to mount the fan, battey placement, and where the ESC needs to be. You will have to do something with all those buklkheads , to make any fan fit.
Also the intake ducting--- you have lots of things that need to be done, well before you do any more sheeting. And don't for get to figure out the CG.
I would think it would be pretty hard to go any further, untill you have the fan, ESC and batteries ( in hand ) so you know the weights and dimentioins of all the components.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Feb 22, 2014, 04:43 PM
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
Yeah i know Cooler, Some of the bulkheads will be changed to wooden ones, and i even has to make some kind bridge construction to support the wing spar and the under carriage. This Change sun 90mm you mentioned, is it total crap or could it work at all?
What I will do first is still the cockpit section, as i think it needs to have the right shape,
Then I will install the bulkheads and cut open the middle to fit the rear pipe.
The innlet duct will have to bended, going from the mid section in the fuselage down under the nose section.
Have to figure out wether I need to make a hatch behind the canopy or just go for a detachable canopy and place batteries there.
I will concentrate my effort on the top side before I start making the bottom side of the plane
Old Feb 22, 2014, 04:56 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
If it was me, Id just take sloppers joes plans blow them up 200% walla
More fun with the xl (4 min 26 sec)
Old Feb 22, 2014, 05:07 PM
Joined Dec 2008
My opinion, - Plenty of other 90mm fans out there to pick from. All depends on your pocket book, and how good of quality one you want!!
My preference is the JetFan 90/with a Het motor..
I did look over the pics in the first post a little closer, here I thought they were already glued in, My mistake. It would'nt hurt to have the fan for setting up the bulkheads correctly. Also , watch how you set the thrust line. Read this thread:
AoA and thrust line?
http://www.rcgroups.com/forums/showthread.php?t=1730968
good info on 2nd page about it.
And, Glad you got the build thread going. I was wondering when you were going to show up?...
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
His plane looks nice but the fuselage i way to short and the LEX should be shorter
I want mine to have the right proporsions.
Old Feb 22, 2014, 05:09 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
yes scale you have to stretch it. i never bothered. i smashed it together.
Old Feb 22, 2014, 05:26 PM
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
Mine will have a mid mounted fan unit. I gues that means a zero degree thrustline.
What I really like is that I dont have to worry about the stab incidence.
Thanks Cooler.. BTW. i`ll follow your advice and get a fan unit, so i can carry on with the plane.
Old Mar 02, 2014, 06:22 AM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Everytime I see someone do the XL version, I remember I have an old Kyosho F-16 fuselage, that I have planned on doing the XL version for 10 yrs. When I have the time, it's never on my mind...
Good luck with yours. Being a delta, it usually takes more power to get on step.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Mar 02, 2014, 05:53 PM
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
Its nice plane the XL. Remember to stretch the fuse when you decide to build it.
Mine won`t be finished for quite a while, but i`m doing some slow progress with it though.
Old Mar 29, 2014, 07:44 PM
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
I`m finally back. Havent done to much progress with the XL, but I have managed to get some 3mm foam sheets to skin the fuse now. the shape of the nose section with the hump behind the canopy had to be redone 4 times before I was happy. I will stick to my plan and finish the top first, before I start making formers for the belly and the intake.
Old Apr 03, 2014, 10:58 AM
Alien_Tech is online now
Find More Posts by Alien_Tech
Pile-it
Alien_Tech's Avatar
United States, CA, Palmdale
Joined Nov 2007
Let me know if you need any more pics. I drive by it every day at work. Actually, both of them.
Red
Alien_Tech is online now Find More Posts by Alien_Tech
Old Apr 03, 2014, 12:58 PM
Land of confusion
Skunkwork's Avatar
Joined Feb 2014
Great! Need more detail pic`s of the bird. My aim is to make it look right. seen a lot ot look alike XL out there.
what`s the condition of the these two beauties right now? Are they still flying?
Discussion F-16XL (formly lx F-16) N178EZ Foamy EDFs 23 Jun 30, 2014 12:49 PM
Build Log F-16XL EDF jet Skunkwork Foamy EDFs 0 Feb 17, 2014 04:34 PM
Sold Jet Legend F-22 EDF Gra55h0pper Aircraft - Electric - Jets (FS/W) 13 Oct 04, 2013 11:59 AM
Sold F-104 EDF Jet Hossinarizona Aircraft - Electric - Jets (FS/W) 6 Oct 04, 2013 09:43 AM
For Sale Great Planes Micro F-86 EDF Jet BCL Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Sep 23, 2013 09:06 AM
