I had to look that one up as I have never used Sanwa before -- Sanwa RD6000 Super 35mhz
The matching Sanwa Rx would be the obvious choice, plus use the Sanwa xtals to ensure compatibility. That said, probably just about any 35Mhz rx will probably work, but perhaps stay away from the 'micro' sized ones unless the specifically state full range use. |
United Kingdom, Scotland, Argyll and Bute
Joined Oct 2012
There are a few threads in there on the synthesized Corona Rx.
Imagine a 1.2M wingspan model flying off towards the horizon.
At the point where you can no longer determine which way it's heading, or whether it's even the right way up, that's about as far as it gets. For FPV, I think the UK regulation is the need to maintain line of sight between model & controller, not sure if that means knowing which way it's headed or what ! The other thing really, is the new 2.4ghz system 'boasts' in many cases the interference-free bind between TX & RX. There are a number of variables if working 35mhz, interference probably being top of the list. Hope this helps, FPV is an interesting concept but range is something that has many variables which could 'spanner' your ultimate goal. |
| Thread Tools | |
| Discussion What's the BEST 35MHz Rx/Tx combination? | derabbink | Radios | 17 | May 12, 2013 04:23 PM |
| Discussion Opinions on Best 1.2ghz rx as of May 2013? | carl1864 | Video Piloting (FPV/RPV) | 29 | May 09, 2013 04:53 PM |
| Discussion Best quailty TX + RX at this point | LHTPlane | Video Piloting (FPV/RPV) | 5 | May 09, 2013 09:25 AM |
| Discussion if lawmate tx's and rx's aren't the best, which brand is? | cadders | Video Piloting (FPV/RPV) | 9 | Feb 11, 2013 05:39 PM |
| Discussion Best place to buy nicad rx packs | superbox100cc | Batteries and Chargers | 7 | Feb 09, 2013 06:28 PM |
