Old Apr 18, 2015, 08:29 PM
rcboosted is offline
Find More Posts by rcboosted
Joined Sep 2006
Question
LemonRx 8Ch DSMX PPM suddenly stopped working
So I've got a tricopter with a LemonRx 8Ch DSMX PPM receiver I've been flying for a couple of months now without issues. Range checked well beyond LOS. Today while I was flying, the tricopter just went into fail safe and fell out of the sky.
Currently, the Rx main body shows a quick flash of red led if I connect 5V to it then it goes dark. The Sat doesn't show any sign of life. Inspection of the PCB and components did not show any physical damage. What gives? I was testing this tri for a trip in 3 weeks, now I don't know if I'll have enough time to order another to make it in time...
rcboosted is offline Find More Posts by rcboosted
Old Apr 19, 2015, 06:28 AM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Disconnect everything from the receiver. Insert bind plug. Apply 5v. If you get rapid flashing, go on to complete a re-bind. If you don't, check that power is applied with correct polarity.
If you can't get the receiver to go into bind mode (flashing), it is faulty.
Daedalus66 is online now Find More Posts by Daedalus66
Old Apr 19, 2015, 05:44 PM
Joined Sep 2006
Thank you for the quick reply. I did what you instructed and the Rx is back to life. Now the real question is, why did it lose binding in the middle of flying? If it some how went out of range, I can see the FC going to fail safe, which it did. But why would the binding be lost?
The only thing I can think of is, it lost signal, FC went to fail safe. I saw it landed upside down with the motor twitching since it couldn't turn. I quickly turn it over. Perhaps some surges in current made the BEC send out some bad power?
Old Apr 19, 2015, 09:03 PM
teamdavey is offline
Find More Posts by teamdavey
Sunnyvale, CA, USA
Joined Apr 2000
What tx are you using?
teamdavey is offline Find More Posts by teamdavey
Old Apr 19, 2015, 10:26 PM
Joined Sep 2006
Devo 7e with Deviation mod, external antenna mod and extended range mod. I was flying at 30mw of power, which I tested to beyond 100 paces. At the time of the crash, it was barely 50 paces away and not much altitude, maybe a couple of stories high at most. I had the antenna pointed to the side so it's the same orientation as the Rx antenna. (both of them)
Wanted LemonRX 8ch DSM PPM Receiver Rdepaz Aircraft - General - Radio Equipment (FS/W) 0 Mar 12, 2015 06:34 PM
Sold Lemon-Rx 8ch PPM only receiver with satellite DSM2™/DSMX™ Multicopter SuperScratchy Aircraft - Electric - Multirotor (FS/W) 3 Dec 31, 2014 12:46 AM
Sold Lemon-Rx 8ch PPM only receiver with satellite DSM2™/DSMX™ Multicopter SuperScratchy Aircraft - General - Radio Equipment (FS/W) 0 Dec 06, 2014 07:19 PM
Question Why does my new Spektrum DX5e suddenly stop working mid-flight? Sun Eagle Radios 8 Nov 06, 2013 04:29 PM
Question Motor 1 suddenly stops working, throttle down and then up and it starts again +videos domingosl Multirotor Talk 7 Oct 14, 2013 06:26 AM
