Old Mar 08, 2015, 01:25 PM
Stef40460 is offline
Find More Posts by Stef40460
FRANCE
Joined Sep 2005
MXS 60"" or EXTRA 300 60'' EF ?
Hi
Among the planes EF, I hesitate between MXS 64 "and the EXTRA 300 60 '' ...
But I do not know which to choose!
Which do you take to 3D aggressive?
Thank you for your opinion.
Best Regards
Stef
Stef40460 is offline Find More Posts by Stef40460
Old Mar 17, 2015, 01:17 PM
FRANCE
Joined Sep 2005
Hello!
I chose the MXS 62 ', and I received it. The building is beautiful and very light.
I do not regret!
I put standard size servos, it was necessary that I magnifies housing, and that I just strengthens (fixation)
I have 3 3300 mAh Lipo 6S, YEP 120 LV, the Torque engine under EF, and a propeller 15x7 wood xoar.
It should fly this weekend if all goes well!
Best regards
Stef
Old Mar 17, 2015, 07:06 PM
Andrew Schear is offline
Find More Posts by Andrew Schear
Andrew Schear's Avatar
United States, AZ, Phoenix
Joined Mar 2013
I've flown both (owned the MXS and Edge) I'd go with the extra over the MXS, it's a little more stable in Harrier, the MXS is a bit more violent (in a good way). Depends on how you fly. The edge is actually my fav for harrier/hover. The MXS pop tops really well, the extra flies like an extra, awesome.
Buy all three!
Originally Posted by Stef40460 View Post
Hi
Best Regards
Stef
Andrew Schear is offline Find More Posts by Andrew Schear
Old Mar 17, 2015, 07:34 PM
superduke1 is offline
Find More Posts by superduke1
Joined Mar 2012
Hi I'm also looking to purchase a extreme flight 60" airframe I have been flying a PA addiction X and want to step up to something bigger. looking for a stable airframe for harrier and hover I can't choose between the edge 540 and extra.
superduke1 is offline Find More Posts by superduke1
Old Mar 17, 2015, 07:45 PM
Doc Austin is offline
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Both harrier well but the Edge definitely does it better.
Doc Austin is offline Find More Posts by Doc Austin
Old Mar 25, 2015, 11:42 AM
kobe_cantin is online now
Find More Posts by kobe_cantin
United States, FL, Delray Beach
Joined Feb 2015
I have an 64" MXS and I have 9 flights on it. I've only had it for two days, that tells you something my vote is the MXS
kobe_cantin is online now Find More Posts by kobe_cantin
Old Mar 25, 2015, 11:56 AM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
For those struggling to get a good harrier going, check out The New Sport Pilot's Guide To 3d and hopefully that will give you a little help.
Also, a spoileron mix really helps tame harrier flight down. I run a 25% mix because it also comes in handy during extreme aerobatics, but you could turn it down to 10% or so and it really smoothes things out. Put it on a switch so if you don't like it you can just flip it off. Don't be afraid to try new things, especially if they can help you.
Laser EXP__The Spoileron Files
While the Edge is the undisputed harrier king of the EXP lineup, the 60" Yak is not that far behind at all, and neither is the Laser. The 48" EXPs each have a pretty distinctive personality, but the 60s are much more closely matched.
Old Mar 25, 2015, 01:43 PM
FRANCE
Joined Sep 2005
Hello!
I tested the MXS Sunday and I made the first flight with the setup of the record (centering on the wing joiner, rudder deflections of 2 flight conditions (normal and 3D).
I loved flying, with several landing and takeoff.
Very docile airplane, very spectacular figures!
I know ... The plane was so docile that I attacked 3D now!
But the second flight (with another lipo), the motor (TORQUE expected) stopped turning after 2 minutes, as if the controller (YEP 120 LV) had cut ...
Result ripped the train ... munched hood, and 2 holes in the wings!
It is almost fixed, and I ordered a 80A AIRBOSS to replace the YEP because I have my doubts about this one ...
My Lipos are new (6S TURNIGY Nanotech 3300 mAh).
I long to return the flight, as this is the best plane I've ever had!
I will test the spoileron mixing as soon as possible!
Thank you for all these opinions on aircraft EXTREME FLIGHT here in France they are not very popular!
Old Mar 25, 2015, 06:53 PM
Eddge is offline
Find More Posts by Eddge
Hey y'all!!! Watch this!!!
Eddge's Avatar
United States, VA, Gloucester
Joined Jul 2007
I would have said stay away from YEP if I had known. I lost my new green MXS after only a few flights with one of those. Now I use Castle and Turnigy exclusively with nary a problem.
Eddge is offline Find More Posts by Eddge
Old Mar 25, 2015, 06:56 PM
Eddge is offline
Eddge's Avatar
Joined Jul 2007
My vote is for the Extra, but it's only based on looks. The MXS is a fantastic plane also. Someday, an Edge will be in my collection.
Old Mar 26, 2015, 01:04 AM
FRANCE
Joined Sep 2005
Hi
Thank's for your answer Eddge...
My new AIRBOSS will arrived saturday !
I have Yep to sold...
Old Mar 27, 2015, 10:06 PM
Drahcir is offline
Find More Posts by Drahcir
Joined Jun 2009
I am considering purchasing an EF 60 inch plane. I've been flying my 48 inch edge 3dhs for the last 3 years and enjoy it a lot. Looking for something bigger now. I have my eyes on the Yak 54. So which 60 inch EF planes do you all recommend and how does the Yak compare to them? Also how much can I expect to spend on a recommended setup?
Drahcir is offline Find More Posts by Drahcir
Sold 60" EF Extra 300-EXP: almost perfect and priced to move $350 bigbookfrank Aircraft - Electric - Airplanes (FS/W) 1 Nov 19, 2014 12:03 AM
Wanted WTT NIB Yellow 3DHS 58" EDGE 540 for 60" EF LASER or MXS or ? xlr8tion Aircraft - Electric - Airplanes (FS/W) 0 Oct 18, 2014 12:23 AM
Wanted 3DHS/EF 48"-65" Edge/Extra/Vyper/MXS /ETC NIB or LPU xlr8tion Aircraft - Electric - Airplanes (FS/W) 6 Aug 21, 2014 12:09 PM
Wanted EF extra 300 exp48" or extra 58" or edge 540 60" Timikosx Aircraft - Electric - Airplanes (FS/W) 2 Mar 04, 2012 07:42 AM
Discussion Comparison 3DHS EXTRA 300 SHP 47 and EF MXS-EXP 48 and PA EXTRA 260 Jack Skip 3D Flying 115 Nov 10, 2011 04:56 PM
