Old Sep 15, 2014, 12:04 PM
Joined Mar 2012
Wing Washout
I'd like to start hotwiring my own EPP wings and fuselages.
For say a 48" wing on a combat foamie (with eppenage), what amount of washout should I be adding?
wadeg is offline Find More Posts by wadeg
Old Sep 15, 2014, 12:46 PM
That Freeking Laird Guy
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
None! Generally washout is only added on a swept back wing. if you are making a "normal" plane with a tail (P-51 or something like that) then washout isn't needed.
TFLG is offline Find More Posts by TFLG
Old Sep 15, 2014, 05:10 PM
Surf Sucks, Slope Trips
Joined May 2014
I think he was asking about a combat wing ala zagi...which does have a swept wing...
IrieMitch is offline Find More Posts by IrieMitch
Old Sep 15, 2014, 05:22 PM
Confirmed Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
I read "with empennage" (or something close to it) to mean it has a conventional tail.
screamin' eagle is offline Find More Posts by screamin' eagle
Old Sep 15, 2014, 07:04 PM
Joined Mar 2012
Thanks! That makes it simpler! Getting back to sloping but with 2 young daughters now, I can't crunch my old glass and the LZs closer to home are rotten. No way can I justify loading up and driving to Eagle/Kiona for the day. Time to make slope trash!
Old Sep 15, 2014, 07:27 PM
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
None on a combat wing.
The elevons are generally wider at the tip than the root and with the reflex of the elevon, that will give you the washout.
ZIPPER is offline Find More Posts by ZIPPER
Old Sep 15, 2014, 10:07 PM
Slope Nutz, FLY OR DIE
kbstingwing's Avatar
Vista, Ca
Joined Oct 2002
None is correct, it's not needed, I use to put washout on the wings and found out it doesn't help, so now all the wings I cut have no washout, I think on a powered plane with a thicker airfoil washout helps for reducing tip stall, but on a glider with thinner airfoils it is not needed.
kbstingwing is offline Find More Posts by kbstingwing
Question Adding Washout to Wing Cores TomFlyer Slope 21 Jul 09, 2014 11:21 AM
washout in trainer wing mnflyer Fuel Plane Talk 2 Jun 21, 2002 09:30 AM
Washout on flying wing rparigoris Foamies (Kits) 9 Feb 26, 2002 03:22 PM
Washout in a swept wing? MtnGoat Power Systems 1 Aug 07, 2001 10:56 PM
Reflex or Washout best for "flying" wing? hardlock Power Systems 14 Jul 06, 2001 11:50 AM
