Old Nov 08, 2014, 03:56 PM
Joined Aug 2009
DA50R and DLE35RA best RPM?
Hello I want to know the optimal peak rpm on the ground for best performance with each of these engines?
I want to use a Menz S 19x8 on the DLE35 (I am getting 7400 with a Xoar 19x8) and a Menz S 22x8 with the Da50. Is that fine? Is Menz 22x8 better than biela 22x8 for a GRp Patty Wagstaff? I want fast spool up and 7K RPM. I will be running the DA50 with a Slimline Pitts muffler (200-300 RPM less than stock muffler).
DuHAst is online now Find More Posts by DuHAst
Old Nov 08, 2014, 08:56 PM
WCB
NC
Joined Aug 2005
''Optimal rpm on the ground'' has no bearing on performance in the air. Forget rpm numbers. The only real way to know what prop works the best for your flying style is to try different ones. Other than that it's just a guessing game.
WCB is offline Find More Posts by WCB
Old Nov 08, 2014, 09:16 PM
ace4rc's Avatar
tampa,florida
Joined Nov 2007
That is true but optimal rpm by prop on the ground is a good start. I like to, for example the DLE 35RA is spec'ed at 8500rpm peak, prop for 7500rpm on the ground and go from there.
ace4rc is online now Find More Posts by ace4rc
Old Nov 09, 2014, 03:09 AM
Joined Aug 2009
What I mean is every engine has a max torque @ some rpm that maybe is not peak rpm so I guess if you stay @7k on the ground in the air there are a hundred more rpm and that gives you max torque. Personally I dont like a prop that gives less than 7000 rpm on the ground as it feels sluggish.
Old Nov 14, 2014, 03:28 AM
United States, IL, Glenwood
Joined Nov 2013
Check out the power systems for extreme flight fanatics in the 3D forum. There's a guy over there multiple times a day he goes buy aeroplayin you can send him a pm. Or ask your question over there. He has lots of test data and first hand expereance with different props on most gass and electric motor combinations.
Gregertman is offline Find More Posts by Gregertman
Question Best RPM sensor: optical, hall, or brushless motor DWS Eagle Tree Systems 3 Jul 15, 2014 01:03 PM
Discussion dle35ra props ryanbe15 Engines 21 May 22, 2014 11:00 PM
Found 2 3/4 Spinner drilled for DLE35RA (for Ultimate Bipe) shannon1978 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Aug 04, 2013 11:43 PM
Sold Dle35ra kirilian2351 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Jul 16, 2013 08:32 PM
Sold Fs dle35ra almost brand new! flameoutgarrett Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jul 12, 2013 10:22 PM
