Old Nov 02, 2014, 10:42 PM
United States, MO, Fenton
Joined Jan 2012
Originally Posted by bhoov128 View Post
If I remember correctly, it provides a little more thrust and the gws is a bit more efficient so it unloads at a slightly higher rpm
Thanks!
Fentonflyers is online now Find More Posts by Fentonflyers
Old Nov 10, 2014, 09:40 PM
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
So I picked up a GWS 8040 and 8060 to try out
I hope I can this week even with our colder temps...
brushless55 is online now Find More Posts by brushless55
Old Nov 11, 2014, 07:54 AM
ForsheeMS's Avatar
United States, NC, Lexington
Joined Jul 2012
I tried out the 8040 prop about a year ago. Be really careful as it pulls well over 10 amps. Been too long to remember the exact numbers. I went ahead and flew it but didn't like it. It's a little too much prop for the Edge.
ForsheeMS is offline Find More Posts by ForsheeMS
Old Nov 11, 2014, 10:50 AM
Joined Nov 2011
We shall see, as the 7035 really doesn't warm up the esc and motor on static
Old Nov 11, 2014, 11:46 AM
ForsheeMS's Avatar
Joined Jul 2012
Just went back and checked. The 8040 pulled 11.89 amps static but I had installed a 12 amp ESC in mine. It's definitely going to exceed 10 amps unloaded so use WOT sparingly. One thing I found is it didn't have as much vertical punch as the 7035 did.
Old Nov 11, 2014, 02:08 PM
Joined Nov 2011
WOT in the air is much different than static
but interesting you had less punch with the 8040 vs the 7035
I have some different packs I'm going to try, and they have more power vs the stock pack
10amps unloaded ??
Old Nov 11, 2014, 10:03 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Busted a rudder servo on the old workhorse today. But...
I was doing tailscrapes on one of the airframes WITHOUT the little bass-wood mod to tie the rudder to the fuselage. The rudder pulled completely out of the hinges, so needless to say, there were some nasty forces back there.
A quick servo gear replacement, a little glue to put the piece of wood back there, and she's ready to go drag across the field again tomorrow!
Can't wait until it's stable-mate Viking comes in.
tracknoob is online now Find More Posts by tracknoob
Old Nov 11, 2014, 10:52 PM
Exodus 4:13
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Tail drags hahaha! Get some vid of that! That tailwheel /hinge system on the Inverza and EdgeQQ seem like a big oversight to me. I've never seen a tailwheel on anything bigger than a UMX plane that wasn't mounted in some way to the fuselage.
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Nov 12, 2014, 04:12 AM
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
I wonder if they have indeed fixed the issue with the new Viking tailwheel?
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Parkzone Ka8 telemetry install
Old Nov 12, 2014, 12:07 PM
Exodus 4:13
bhoov128's Avatar
Joined May 2012
Nope. Same old story.
http://www.rcgroups.com/forums/showp...&postcount=423
Old Nov 12, 2014, 02:07 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Right?!?!?!?!!!!!!
I mean, they invested in that cool plastic molded 'cap' that runs the length of the bottom of the control surface... and that awesome spring-loaded tail wheel strut...
and then we get NOTHING holding the incredibly huge rudder onto this thing except the foam and paper hinges? Hinges that, btw, usually seemed to come in dry, and only friction-fit together!
I can see them cheaping out on the actual cheesy little tail wheel itself, or giving us just a little bit of wire instead of the nice sprung strut... but for Pete's sakes, at least tie the thing to the main fuse on a plane that is going to see the type of use that this one is intended for. All it would have taken is a little "L' bracket, or a plastic version of the keyhole-drilled wood slat that some of us have been gluing back there.
Old Nov 14, 2014, 11:14 PM
mdv
United States, CA, San Diego
Joined Jun 2009
very sad. I guess they sell more servos this way.
mdv is online now Find More Posts by mdv
Old Nov 17, 2014, 11:02 AM
Exodus 4:13
bhoov128's Avatar
Joined May 2012
cynical!!
Old Today, 05:51 PM
United States, CA, Davis
Joined Sep 2012
so i picked up one of these from HH on clearance. I got rid of the y connector for the ailerons and have them on separate channels. I download the setup for my DX9 from Horizons website. seems to work ok. A couple of questions tho... there are 4 flight modes but i can only access three on my 3 position toggle switch, how do I get the 4th flight mode. Also the aileron differential was set at 3 percent. Is this enough differential for those that do this?
hkgas is offline Find More Posts by hkgas
Old Today, 06:50 PM
Joined Jan 2012
Check your flight mode setup screen. You may need to assign the switch for it. Might be a good idea to put this in the new DX6-9-18 thread. Lots of guys there with more knowledge on the subject than me.
New Product E-flite 300 A6M5 Zero BNF Basic Afraidtoregister Electric Warbirds 1089 Yesterday 05:43 PM
Sold BNIB E-flite UMX Beast 3D BNF Basic AS3X (EFLU4850) plus EXTRAS peterswolf Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Sep 14, 2012 08:43 PM
For Sale E-Flite MSR X BNF Basic edition daign Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2012 09:59 PM
Sold Edge 540 3D ARF by E-Flite freirem Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2012 07:38 PM
Discussion A6M5 Zero 300 BNF Basic by E-flite BlazingStar Micro Ready-to-Fly 2 Feb 03, 2012 03:22 AM
